Question about Dell 2330dn Laser Printer
Black ink line down right hand side
Replaced cartridge to no avail??
SOURCE: dell 1710 black marks printing down the sides
if you are technician so you can otherwise call printer service engineer
Posted on Feb 27, 2008
SOURCE: Black Line on Rt side of every printed sheet!
Replace the drum cartridge.
Posted on Oct 07, 2008
  • 3 Answers
SOURCE: Black lines on the right side of every copy
depending on what the lines look like it could be the charge roller or transfer roller.
A defect on the charge roll appears as black areas on the front of the test page, and as light gray areas on the test page.
A defect on the PC drum of the toner cartridge appears as white areas on a dark, full–coverage test print and as black areas on the "text only" test page.
I have also seen a line with a 'ridge' on the paper. This will appear almost like an embossed line. This was caused by the fuser roller being scored by debris.
Posted on Jan 14, 2009
Zigamus
  • 4 Answers
SOURCE: Ink dots on right side of paper
Toner cartridge? So this is a laser printer? In that case I suspect it is not new? This sounds like old age on the main image drum, that will probably give the exact same mark on each page, correct?
Posted on Apr 15, 2009
  • 172 Answers
SOURCE: have a faint black line (about ½mm) down
Check your USB cable?
Posted on Aug 11, 2009
Black line down right side of 3050 laserjet
I would try a few of the following; try a fresh (clean) install of the printer on your pc; or try a firmware upgrade on the printer; or clean the toner cartridge transfer roller (it may even be scratched.)
Nov 23, 2013 | HP LaserJet 1020 Printer
Just replaced black ink cartridge on my Epson TX117 but it prints out very lightly and I need dark black
remove the ink cartridge shake it from side to side (right to lift ) not upside down(not vertically ) and you should do thies every time you replace them
May 26, 2011 | Epson Stylus Multifunction Inkjet Printer/...
White line along right side with black ink only
One of our IT guys came out and said he had figured out the solution on another printer with the exact problem. The problem is that the ink cartridge is not in tightly enough. It LOOKS like it is; the lock is even shut and the drum rolls smoothly. BUT, there is a tiny, and I mean tiny, bit of space between the cartridge and the drum, thus the ink gap. So, the solution is to be sure the cartridge is pushed back into position very tightly. We had been tentative in shoving the cartridge in because of the plastic pieces, but the lock locked just fine and we heard a slight clicking sound. Now we know to put it in carefully, then push hard into place. Problem solved.
Jan 07, 2010 | Dell 3100cn Laser Printer
I have a HP 7580 printer/fax/scanner which will not print in black even though i have installed a new black ink cartridge
I had this same problem, replaced all ink cartridges and problem still remained. The fix for this is actually to replace the print heads not the cartridges. There is a black/yellow and Magenta/Cyan print head in the printer itself under the scanner on the right hand side. Rpelace as needed.
Nov 02, 2009 | HP Office Equipment & Supplies
Replaced print head and cartridges and still not printing.
Open the kodak all in one home center on your desktop and click on [?] on top most right hand side. choose maintenance under general links and choose printhead cleaning. if this does not solve the issue, call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost..
Jul 04, 2009 | Kodak ESP 5 Printer
Black ink cartridge is leaking and black line is running down back of page
if you do your own refill the ink u are using is of the wrong density, get the right ink
May 22, 2009 | Canon Pixma MP500 All-In-One InkJet...
We are suddenly experiencing 2 problems. First,
The fuser needs to be replaced, it is causing your smears and the wrinkling/jamming problem.
Apr 28, 2009 | Lexmark T430 Laser Printer
Black ink is faded
Mar 29, 2009 | Kodak ESP 5 Printer
Striped line down right hand side of printout
all parts are ok just clean the printer it will work
Dec 02, 2008 | Samsung CLP 300 Laser Printer
Brother DCP-115C
good chance....Print head is blocked very common, what sort of inks were used?
 Not economical to repair, buy new!
Oct 19, 2007 | Brother DCP 115C All-In-One InkJet Printer
Dell 2330dn Laser Printer Logo
Top Dell Office Equipment & Supplies Experts
jasbo
jasbo
Are you a Dell Office Equipment and Supply Expert? Answer questions, earn points and help others
