Question about Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656
Why does my cube cadet mower disengage after about 45 min ?
RZT50
    Novelist:
  • 157 Answers
Electromagnetic clutch is starting to go bad.
Posted on Jul 22, 2016
Have 2155 cub cadet when it gets hot spudders then dies wouldn't start until cools acts like it not getting gas what could be the problemn?
To be quite honest it sounds more like a fire issue than fuel. More times than not when a coil starts going bad the hotter it gets the weaker it gets and sometimes stops firing at all until cooling down, occasionally a plug will do this aswell, but I think your coil is going out.
Aug 21, 2014 | Cub Cadet Garden
How to change out an electric clutch on a cub cadet zero turn RZT50?
Removal is simple if you have access to an impact wrench so you can the center retaining bolt.
When re-installing anti-seize compound needs to used on the crankshaft so the new clutch assembly doesn't seize on the shaft. To tighten the center bolt you must hold the flywheel in place by blocking it. This center bolt must be torqued to 45-55 ft fts. Also the new pto clutch needs burnishing in. Most new clutches come with instruction on this procedure.
Jul 23, 2014 | Cub Cadet Riding Lawn Garden Zero Turn...
What causes my cu cadet rzt50 to sputter & die?
water in gas or a dirty carberator put in new gas and rebuild carb
Jun 28, 2014 | Cub Cadet Garden
Why does my cub cadet rzt50 sputter & die at regular mowing speed?
it is running out of gas bad needle and seat rebuild carb
I have a cub cadet rzt50 zero tudn. Blades are new and sharp but when i cut there is a trial of cut grass in the center of the mower tracks that is left behind. Mower is only a few years old with 100 hours...
if this started after the blades where replace make sure you have the right blades zero turn and reg mowers have different blades then check the bearings on the blade mandrels then last is to check for a rotted out deck with the belt tension pulling the blades apart
May 16, 2012 | Cub Cadet Garden
Cub cadet rzt50 dies as soon as you take brake off
you have a plunger switch under mower where the break peddle is change it
Apr 23, 2010 | Garden
I have a cub cadet rzt50 mower...Need to replace a tire
There is a thru bolt, and inside and outside bushing, and center sleeve. Remove those to remove the wheel. Obviously support the frame on a jack. Most tires can be removed using a slight soapy solution and 2 smooth screwdrivers. Replacement, use a soapy solution around the bead, and using only hand pressure put the tire back on. Use a cinch strap around the center of the tire to help keep the tire beads against the rim and air it back up.
Apr 15, 2010 | Mustang Rzt 50" Zero Turn Riding Lawn...
Oregon Scientific Oregon Gator Mulcher 3-N-1 Blade For 50-Inch Cub Cadet Lawn Mowers #90-656 Logo
279 people viewed this question
Top Oregon Scientific Garden Experts
Dennis Key
Dennis Key
Colin Stickland
Colin Stickland
roeb
Are you an Oregon Scientific Garden Expert? Answer questions, earn points and help others
