Question about Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15
Do you fill sand filter wth water to get filter primed
    Top Expert:
  • Hayward Master
  • 8,688 Answers
No just fill pump basket some you should add water before sand just get pump primed you should be fine
Posted on Mar 04, 2015
  • 19 Answers
SOURCE: my pool sand filter pump isnt filtering the water
could possbly be a bad gasket on the vari-flow valve. When is the last time you backwashed?
Posted on Apr 29, 2009
  • 93 Answers
SOURCE: Priming a hayward super pump
IF IT DOES NOT FILL CONSTANT FROM POOL IF IT IS AN INGROUND YOU WILL HAVE TO HELP IT BY PUTING A GARDEN HOSE WATER ON IN SKIMMER PUT A RAG AROUND HOSE FILL CUP TURN OFF RETURNS OPEN BLEEDER VALVE ON FILTER LET WATER FILL START PUMP AND OPEN RETURN VALVE SLOWLY YOU MAY HAVE TO DO THIS SEVERAL TIMES MAKE SURE AFTER YOU GET WATER FROM BLEEDER YOU CLOSE MAKE SURE ALL CONNECTIONS ARE TIGHT INCLUDING CLEAR CAP ON PUMP THESE ARE AIR BLOCKS IF ABOVE GROUND CHECK ALL HOSES AND CAP
Posted on Jul 01, 2009
jharwell668
  • 640 Answers
SOURCE: How to open pool, fill sand filter with water?
I happen to have a copy of the users manual for this pool filter. These are the instructions for operating your filter.
1. Be sure correct amount of filter sand media is in tank and
that all connections have been made and are secure.
2. Depress Vari-Flo control valve handle and rotate to
BACKWASH* position. (To prevent damage to control valve
seal, always depress handle before turning.)
3. Prime and start pump according to pump instructions (be
sure all suction and return lines are open), allowing the filter
tank to fill with water.
WARNING: ALL SUCTION AND
DISCHARGE VALVES MUST BE OPEN WHEN
STARTING THE SYSTEM. FAILURE TO DO
SO COULD CAUSE SEVERE PERSONAL
INJURY.
Once water flow is steady out the waste line, run the pump for
at least 2 minutes. The initial back-washing of the filter is
recommended to remove any impurities or fine sand particles
in the sand media.
4. Turn pump off and set valve to RINSE position. Start pump
and operate until water in sight glass is clear—about 1/2 to 1
minute. Turn pump off, set valve to FILTER position and
restart pump. Your filter is now operating in the normal filter
mode, filtering particles from the pool water.
5. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten
connections, bolts, nuts, as required.
6. Note the initial pressure gauge reading when the filter is
clean. (It will vary from pool to pool depending upon the
pump and general piping system). As the filter removes dirt
and impurities from the pool water, the accumulation in the
filter will cause the pressure to rise and flow to diminish.
When the pressure gauge reading is 8-10 PSI (0.55-0.69
BAR) higher than the initial "clean" pressure you noted, it is
time to backwash (clean) the filter (see BACKWASH under
Filter Control Valve Functions.)
Posted on May 24, 2010
  • 106 Answers
SOURCE: Done every thing suggested. Still doenst prime.
No prime = either impeller problem, air leak, or blockage on output(bad filter or bad valve) My first choice is dirty filter. Second choice is impeller. Both easy to check.
If you have checked those than you probably have an air leak. Hold a very slow running hose over all pipe joints running into filter, while motor is running. Most likely place is the screw in fitting on front of pump. The water from hose will temporarily seal leak and it should prime.
Posted on May 30, 2011
john224
  • 1378 Answers
SOURCE: I have a hayward sand
Fill it half-way with water, cover the stand pipe coming up in the middle so sand cannot get into it, fill the tank with the sand (only use the amount the label says the unit takes), then install the valve and piping.
John
Posted on Jun 01, 2011
My Hayward sand filter vl40t32 will not vacuum. It is only 1 season old, and I have never gotten it to vacuum. It does, filter, but not pulling the water for vacuuming...
Before you hook up the vacuum attachment, you want to flood the vacuum hose with water or your pump will be air locked. Submerge the hose and fill it with water. These centrifugal pumps must be primed in order to work. Another method is to fill the vacuum hose with water from a garden hose.
May 27, 2017 | Hayward Pool & Spa
How to prime a sand filter pump
use a garden hose connected to house supply to fill the housing and pump head , after that Pump should be able to take over and use water pulled from skimmer , if all your joints and seals are good , if it looses prime ,even after resting for a little while , ck all your joints and seals for leaks ,remember not all leaks ,Leak Out some leak In !!
Apr 23, 2014 | INTEX Sand Filter Pump
It depends on the pump but most pumps have a filter bowl with a screw on cover - you need to fill this with water and start the pump. if the pipework connected to the pump and the filter are empty you will usually have to repeat this process a few times, but once the pump is primed it should start up without repriming in future - Hope this helps - Nigel
My sand filter no prime new motor above ground pool
Thank you for posting your question here on Fixya.com.
The most common causes of no prime are that the filter pot is not filled with water (don't forget to put the cover with a gasket on), there is an air leak in the pipes/valves between the pump and the pool, a plug of leaves or other debris in the suction line, or the pump is installed so high in elevation relative to the pool that just a little of the above issues will prevent it from priming. I hope this helps.
If this answer does not resolve your issue, please comment with additional information before rating the answer. Positive feedback is especially appreciated once your problem is solved! Thank you.
Aug 25, 2011 | Hayward SAND FILTER, PRO SERIES
Done every thing suggested. Still doenst prime. should I fill sand filter?
May 29, 2011 | Hayward 1 12 Hp Super Swimming Pool Pump...
My pump isnt priming. I have put water in the area with the basket and it isnt filling up. We have replaced the seal and the tank doesnt seem to be filling back up therefore the water isnt filling up in...
Is there enough water in the pool 1/2 way up the skimmer flap to prime the lines, Are the skimmers clogged? Are all valves in their correct position? Have you checked the gasket on the top of the filter? Is the spring weak/broken, handle should have some tension, has the gasket rolled, torn or slid?
Sep 11, 2010 | Hayward SAND FILTER, PRO SERIES
How do i change the sand in the filter? I am getting sand in my pool.
You will simply remove the old sand from your pool filter and follow the instructions from your users manual like you are adding sand for the first time. In case you don't have it, I am going to paraphrase it for you below.
IMPORTANT: To prevent unnecessary strain on piping system and valving, always shut off pump before switching Filter Control Valve positions.
The correct amout of sand can be determined with this link: http://www.backyardcitypools.com/pool-filters/Filter-Sand-Requirements.htm
2. Set your controls to the backwash position.
3. Prime and start pump according to pump instructions. (be sure all suction and return lines are open), allowing the filter tank to fill with water.
4. Once water flow is steady out the waste line, run the pump
for at least 2 minutes. This initial backwashing of the filter is recommended to remove any impurities or fine sand particles in the sand media.
5. Turn pump off and set valve to RINSE position. Start pump and operate until water in sight glass is clear—about 1/2 to 1 minute. Turn pump off, set valve to FILTER position and restart pump. Your filter is now operating in the normal filter mode, filtering particles from the pool water.
6. Adjust pool suction and return valves to achieve desired
flow. Check system and filter for water leaks and tighten connections, bolts, nuts, as required.
7. Set your filter to the "filter" position.
May 22, 2010 | Hayward SAND FILTER, PRO SERIES
INJURY.
in the sand media.
Apr 16, 2010 | Hayward SAND FILTER, PRO SERIES
No pressure in my sand filter
Sounds like your pump is not primed. That would be the only reason your filter doesn't register any pressure. Try priming the pump by filling the hair/lint pot with water and starting it up. If the pump pot is full while it's running and you still have no pressure, you may have a clogged pump impeller.
Oct 05, 2009 | Hayward SAND FILTER, PRO SERIES
Jun 30, 2009 | Hayward SAND FILTER, PRO SERIES
Hayward 1 12 Hp Super Swimming Pool Pump Sp2610x15 Logo
99 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
