Question about Hitachi Televison & Video
What charger 18YGSL pinout - Hitachi Televison & Video
Hitachi tool charger UC 18ygsl, no light, will not charge battery. Was working fine until I went to charge a battery..then light went out
If its not an bad soldering or an passive component , beware almost all brands wenn ordering an electric part for a charger its almost always more expensive then a complete (new charger ) the latest years there are more and more remplacement options to the customer , if there are defect components that are not made for ordering on marketing technical reasons and safety and more reasons. mosnfets (passive component almost sometimes fuse resistors but smd components to repair is not meaningfull . when termical defects are hidden.
Feb 18, 2018 | Hitachi Drills
I need the XLR pinout for my Air Hawk portable wheelchair. The charger fell out of the wheelchair pocket on a flight, I need to charge the 24 V battery Li-Ion so I can make it back home with power.
is this ref any use ?
XLR Style Charging Cable for wheel chairs scooters and electric bicycles
be careful over what charger you use as Li-ion batteries must not be overcharged. most have a sensor that detects the voltage and stops charging when the battery is fully charged. This circuitry is inside the charger, not the pin.
May 22, 2016 | Health & Beauty
Can anyone from owner Motorola headset HS820 (n356) make pinout of charger? I lost charger and want resolder mUSB port instead original, so, i know voltage (5.9 DC) and need polarity of power jack.
I know this isn't exactly what you're looking for; and if we knew the type of connector for the charge unit, we could probably find the power + & - pinouts. I still have a few of these power supplies laying around, and if I find one; I'll try to revisit; but to be honest; I really don't know where they are right now.
Still, it doesn't look that difficult to open up. I'm including a link to an Instructable which shows you how to do this. I've usually found that when it comes to DC, the positive is always red, the negative is usually black, and that always seems to hold true. Once you get a look see, I'm sure it's easy after that. Good luck, and be sure to rate this if you're helped by this response. Cracking Open The Motorola HS820 Bluetooth Headset
Aug 21, 2015 | Motorola Radio Communications
Pinout on-board battery charger 2904-24
buy a new end have someone sodder new one on or buy a new charger
Oct 23, 2013 | Health & Beauty
Garmin Nuvi 750 car cradle/charger does not charge the unit. USB charger works, so not the battery. Replaced the cigarette lighter jack and still does not work. Problem must be in the dash mount cradle...
Hi tbrick
if you dont have the original charger, the 750 take a special car charger because of the traffic feature...it has a flat end about 3/4" to 1" long that fits in the cradle, but you can use a garmin usb charger, you just wont be able to use the traffic feature.
if thats a little confusing ( i tend to do that) i try and explain it another way.
if you think you need or want one of those chargers, just post back to me.
bill
Nov 01, 2010 | Garmin nuvi 750 GPS Receiver
With the zd8210ca off with power cord plugged into laptop also battery is in laptop. Battery light on front panel is blinking. With laptop booted up battery condition show charging at 0%. Does any one have...
Take out the battery and try running it on the power adaptor alone. If this works, you have a dead battery. If not there's something more serious wrong in the machine.
Apr 14, 2010 | HP Pavilion zd8000 Notebook
I need the pinout of the jazzy 1103 ultra battery
The Output voltage 24 - 29v ,Usually 27v. (And 4 Amps)
The Pin arrangement is Negative to the Left, Inhibit in the Middle, And Positive to the Right Assuming your looking into the plug itself from the front.
Always check with a Voltmeter first though because there are some chargers with the Opposite Pin Arrangement.
Dec 11, 2009 | Pride Jazzy 1103 Ultra Standard Power...
Unauthorized charger everytime i plug it in.
There may be a problem with your charger output. Do you have another charger you could try?
A temporary workaround is to reboot the phone with the charger still attached. It should now say "Authorized" and start charging.
Jul 25, 2009 | Motorola Mobility W385 Cellular Phone
Battery
If you tried to make a charger you could have damaged the Pinout or even the charging port on the phone however 99% of the time this common error with razrs is fixed by trying a different battery and or a different charger.
Jan 22, 2009 | Motorola Mobility RAZR V3i Cellular Phone
I have Tomtom 5 Mitac Mio 168 Bundle, I can not charge it because there are some pins broken in the charger connection inside the handset.
If you cant put it in service , you can try to resolder only needed pins for charging. here is a link with pinout : http://pinouts.ru/PortableDevices/mitac_cable_pinout.shtml
Apr 21, 2008 | Mitac Mio 168RS GPS Receiver
Televison & Video Logo
21 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
