Question about Vivitar Office Equipment & Supplies
How to load slides in a vivitar 5000AS? - Vivitar Office Equipment & Supplies
Slides are appearing sideways
That is how you loaded them in the tray. Put them in upside down with the emulsion side facing the screen.
Jun 24, 2011 | Vivitar Office Equipment & Supplies
Vivitar 3000af slide projector. The auto focus does not operate. The focus mechanism light source is on. Does the sensor go bad? Does the mounting warp, causing an alignment/positioning problem? Are...
I can't comment on the projector, but I can tell you that paper-mounted slide will warp, due to the affects of temperature and humidity. Warped mounts will mess up the auto-focus in any projector.
Good Luck !! Jim
Feb 24, 2011 | Vivitar V5000AF Slide Projector
I need a 24V/150W bulb for my Vivitar 3000AF slide projector Where can I get one and how much?
Check the list of available lamps at: www.bulbman.com !! If you have the 3-alpha (a 3-letter ANSI designation unique to each lamp design) lamp code it will be easier to find it.... Good Luck !!
Feb 16, 2011 | Vivitar V5000AF Slide Projector
Where in Canada can I obtain bulbs for a Vivitar 2000AF slide projecter 24 volt 150w Q.I ( hanimex type A1/216
Try www.Bulbman.com. They have an amazing assortment of discontinued lamps! Good Luck !!
Feb 13, 2011 | Vivitar V5000AF Slide Projector
I have Hanimex Rondex 120 rotary magazines. I was told these would work in the Vivitar 5000AF. Is this true, as the slide on mine is jamming on the return?
I have a VIVITAR 5000 AF slide projector.
Occasionally, the slide gets stuck while operating the mechanical hand to change the slide. Most of the time it works when I push the slide carrier by hand. Very very infrequently, the projector actually throws out the slide.
I have ascertained that teh Kodak slides which are mounted on paper frames are much too thin for the mechanical hand pushing teh slide in and out. The solution is to remount teh slides on palstic frames or some how add to the thickness of the slide. I have not tried it yet , though.
Any more ideas?
MNAQUVI@yahoo.com
Jan 23, 2011 | Vivitar V5000AF Slide Projector
Hi! I own a vivitar slide printer. It turns on but the shutter release button does not work. No audible click. Nothing! I tried the timer button and I started getting an annoying whistling sound I could...
Hi, I just got the vivitar too, and had the exact same issue.
The unit WILL NOT FIRE unless the slide is inserted along with the little removable "film holder" frame that comes with the vivitar. Hopefully you got this with your unit. There is some sort of thickness sensor in the slide slot, so both a slide and the holder (or something of similar thickness) to get the unit to work. Mine fires with no problem now. And I found that the "high pitched whistling" goes away if you let the printer sit turned on for a while, I think it's just the flash capacitor getting used to being charged. My unit has no noise anymore. Best of luck.
Dec 12, 2010 | Vivitar Cameras
On my Vivicam 7028, the screen displays Card protected the photos are not saving to my camera. Did I forget to do something before loading memory card?
SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Oct 04, 2010 | Vivitar Cameras
How do i turn Macro mode off my vivitar digital camera?
There's a slide switch on the left of the camera near the USB port. Slide it away from the flower and toward the mountain.
Feb 09, 2010 | Vivitar ViviCam 8025 Digital Camera
50 people viewed this question
Top Vivitar Office Equipment & Supplies Experts
bhargav
Kazim ERGUNEY
Kazim ERGUNEY
Are you a Vivitar Office Equipment and Supply Expert? Answer questions, earn points and help others
