Question about Brother MFCJ220 All-In-One InkJet Printer
Unable to init 4f - Brother MFCJ220 All-In-One InkJet Printer
ITTech7574
  • 85 Answers
SOURCE: init unable 4f
uninstall your printer software under control panel/add remove programs..then reinstall your software again make sure your printer is plug to your pc also...hope this helps..ITTech7574
Posted on Aug 31, 2009
pineworks
  • 4041 Answers
SOURCE: brother mfc240c init 4F & init 5A
Hi there
With some Brother printers you can try this.
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, and then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
This will reset the purge count value. Then the printer will restart, hopefully without the annoying cannot clean message.
Some times this happens because of using cheap compatible ink cartridges if this is the case change the ink cartridges.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Posted on Mar 02, 2010
pineworks
  • 4041 Answers
SOURCE: Unable to Init - Machine error 4f
ok please try this
Access the internal maintenance mode by pressing the Menu/Set button, then press * 2 8 6 4 within 2 seconds. This should put you in the maintenance mode menu. Enter 80, then scroll down with the arrow down (round) key. You'll find an entry listed as purge count. If number is over 6000, enter 2 7 8 3.
All I ask is please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All files on my website are only there for a limited time
Posted on Apr 25, 2010
pineworks
  • 4041 Answers
SOURCE: Brother MCF-5440 machine error 4F
ok
  • 159 Answers
SOURCE: See troubleshoot and routine maintenance
You really should mention the brand and model of the printer, but from the message, I'm guessing this is a Brother inkjet machine. If so, the Init Unable message means that either the printhead is unable to go back and forth, or it can, but the machine doesn't know it can. The most common causes are:
  • A scrap of paper got wadded up in the way of the printhead. It's probably crammed up against one end or the other of the area the head travels through. Usually it's soaked black with ink and stuck in the right-hand end where everything else is black, too. If you unplug the power, you might be able to pull the printhead out of the way by hand to get at the scrap. You'll need a flashlight and maybe long tweezers. See the note below about the gray film strip.
  • Sometimes it's more serious. The right-hand end, where the head parks itself is a cleaning/sealing station. Between jobs, the head rests there, and a motor lifts rubber seals up against the bottom of the head to prevent the ink nozzles from drying and clogging. If that motor died, the head is stuck over there, and a repair probably costs more than a replacement machine.
  • Sometimes it's less serious. You might be able to see a 1/4-inch wide strip of gray film stretched tight across the area the head travels through. The gray is actually fine vertical lines that the head counts with an optical sensor, keeping track of it's location, so every dot of ink goes where it ought to. Sometimes a paper jam pushes that strip up and out of its sensor, so the machine can't see it. If it can't count those lines, it assumes it must be jammed and throws up that error. You might be able to gently lift and drop the strip back into the sensor. It should be straight and vertical, all the way across, without anything rubbing on when the head moves.
  • Be nice to that film strip. It's just photographic film, and not made to be rubbed. Ink smears will blot out the lines and cause the error you already have, so keep dirty fingers off it.
There are other possible causes, but these are the likely ones, two of which you may be able to fix without parts.
Good luck.
Posted on Mar 11, 2011
I have a problem with "brother DCP-J140W" printer, it shown at the LCD "Init unable 4F" i was thinking the problem must be the printer head, can it be repaired or just replace the head ?
Hi
Error 4F means your printhead is RIP, mostly due to bad quality ink, the only one way to fx the printer is changing the printhead but... is that really worth it?
Well, check on ebay.com or isscx.com if you can find your part at a good price!
Best Regards
Jul 22, 2016 | Brother Dcp J140w - Multifunct
UNABLE TO INIT 4F BROTHER DCP-195c CAN'T TO PRINT.LCD SHOW UNABLE TO INIT unable 4F. my brother printer when on the screen show unable to print. how to solve the problem ?
The printer have its own initialization but seem to fail to complete initialization process. Check and clear the carriage jam, open check for motor failure in the carriage system.
Dec 18, 2015 | Brother DCP-195C Inkjet Multifunction...
How can I fix DCP-195C unable to Init 4F?
Could be print head or print head PCB problem .
Sep 06, 2014 | Brother DCP-195C A4 Colour Inkjet...
Unable to init. 4f in Brother MFC j615w
Sorry to say this error refers to a print head failure. It is not a user changeable part. It will need repairing by a Brother service agent and it will probably cost more than the printer is worth.
Mar 14, 2014 | Brother MFC-J615W Compact Wireless Inkjet...
Unable to init. 4F
4F is Main PCB Faulty unfortunately most likely from Power surge. Do you have warranty ?
Feb 25, 2014 | Brother MFC-J615W Compact Inkjet...
Unable to init 4f
Problem with Brother DCP-J125
Unable to init 4f
Aug 06, 2013 | Brother DCP-J125
Unable init 4f
the dcp-130c 3 in one printer not working. message appears on the printer screen is init unable 4f. pliz help me
Jun 22, 2013 | Brother DCPJ125 All-In-One Inkjet Printer
How can i fix mfcj220 unable to init.4f?
Unable to Init.4f see troubleshooting in user guide brother MFC-J220... Please help.. rdfx.pcnet
Jan 23, 2012 | Office Equipment & Supplies
UNABLE TO INIT 4F BROTHER DCP-J125
my brother printer when on the screen show unable to print 4f
model printer brother dcp-j125 how to solve the problem ?
Dec 16, 2011 | Brother DCPJ125 All-In-One Inkjet Printer
Init unable 4f
Aug 31, 2009 | Brother DCP 130C All-In-One InkJet Printer
Brother MFCJ220 All-In-One InkJet Printer Logo
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
