Question about Garden
My john deere 3320 won't move after getting stuck on a bih rock what do I look for and how do o fix it
2 Suggested Answers
wireguy212
  • 1627 Answers
SOURCE: where is the hood release for the 3320
Below the bottom of the hood you will find two metal tabs,push down on either one to release the hood.You will have to release the grill guard pin and roll it forward before the hood will open all the way[if it has a loader on the tractor].Under the hood and to the left of the battery is the prop rod to hold it up.Hope this is helpful.
Posted on Jan 02, 2010
John deere 3320 error code 63
You just go to the link I attached I'm sure you will get the solution of your problem.
John deere 3320
May 29, 2017 | John Deere Garden
John Deere 3320 error codes
John deere 3320
John deere 3320 error code 03
Err 03 Reverse Pedal. Voltage signal out-of-range or not calibrated. Machine does not drive. Contact your John Deere dealer.
Oct 14, 2015 | John Deere Garden
My john Deere 100 series .... Gear stuck in reverse.... And will not start because it is stuck in reverse!
sit on the mower and push the clutch in
start moving the mower by rocking it forward and backward while trying to put it in neutral,don't worry about your neighbors thinking their is something wrong with you while you are doing this.
Oct 10, 2014 | John Deere Garden
My john deer won't go in to gear. It starts and
the drive and the mower deck use different belts
Apr 12, 2012 | John Deere Garden
John deere 3320 starts up,engine runs,pto works however will not drive.error code 01 and 12 keep showing up
Both codes are related to the forward and reverse pedals.To cycle through and clear the codes,turn the key on and then press the forward pedal to the deck within 2 seconds and release and the do the same with the reverse pedal,the code should go away unless the problem persists.If so then you need to check the wiring to the potentiometers on each pedal and also check to see if one has been moved[knocked out of range]If none of the above is the case then either the forward or the reverse solenoids could be stuck there-by letting the tractor think you started it in gear,hence no movement,these checks are not really a do-it-yourselfer type checks so you may need to seek help from Deere,hope this helps,thanks.
Feb 11, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Error code 74 on john deere 3320 tractor
Lcd display switch is stuck in the on position either play with the switch until the code goes away or have the dealer replace the switch,it should still have warrenty.
Nov 25, 2009 | John Deere 3010,3020 Tractor Basic...
My 3320 john deere jerks and also shuts off the
You can call a local John Deere distributer. Talk with the parts department and tell them the error code you are getting. Give them your serial number and model number and they can tell you exactly what the error code means. This will allow you to run a search for the error itself and find a part replacement or fix for the error code.
Oct 10, 2009 | Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
