Question about Jabra Cruiser InCar Speakerphone Black
Jabra cruiser2 is not charging - Jabra Cruiser InCar Speakerphone Black
Jabra Cruiser2 Type HFS002. Need help with connecting Jabra to cell phone via bluetooth.
If you have the instruction manual on the jabra, it should tell you how to put the device in pairing mode. Once pairing is turned on you find the device name through the bluetooth settings on your phone. Click pair and they should connect.
Aug 16, 2016 | Cell Phones
How do I get my Bluetooth on droid phone to connect to Jabra system
Turn on the Jabra, then hold down the answer button for 5 seconds until it announces "pairing mode", then open bluetooth on the phone and add there. Are you having trouble with the Jabra or the phone?
You can download the manual from Jabra here: http://www.jabra.com/~/media/Product%20Documentation/Jabra%20CRUISER2/User%20Manuals/CRUISER2_WebManual_EN_NA_2.pdf
Jan 29, 2016 | Jabra CRUISER2 Bluetooth Speakerphone
Jabra wave battery suddenly won't charge
The battery may be shot and incapable of charging. The red light could be merely indicating that the charger is working.
Jan 13, 2014 | Jabra Wave Bluetooth Headset
Jabra sport will not charge
Same problem did you call the 800 number?
Dec 09, 2011 | Jabra Radio Communications
How do I snyc my Jabra Cruiser 2 to my new Blackberry Torch?
On your Torch: Go to options--> networks and connections --> bluetooth connections --> turn on your bluetooth function, touch add new device
Then turn on the Cruiser2 and hold the multifunction button until the light flashes,
On the phone, touch search, touch the CRUISER2 option, and the passkey is 0000
Jun 28, 2011 | Jabra Cruiser InCar Speakerphone Black
My BB Curve 8520 does not connect via Bluetooth with the Jabra Cruiser2. After a very first succesful connection it won't connect anymore. Same problem with my Ford Radio (Galaxy2007). It works with other...
Hello fra pala... Since it is new, it is entirely possible that you got a lemon and will have to return it to the store. This happened to me just last month. That said, here is an excellent link that may be the solution to your issue. Joe
http://www.blackberrycool.com/2009/08/10/the-blackberry-curve-8520-setup-guide-and-tips-and-tricks/
Thanks for choosing Fixya!
Dec 05, 2010 | Cell Phones
I charged the BT350 using the Jabra Charging
I called Jabra Support and they are sending out another unit. The technician indicated that the battery is likely defective and is not field replaceable.
Thank you,
Dec 11, 2009 | Jabra BT350 Bluetooth Headset Headset
Jabra BT8010 doesn't power up
Contact me if you are interested to sell it for parts acidx0 ~(at)~ gmail.com
Aug 09, 2008 | Jabra BT8010 Wireless Headset
Jabra BT500 will not power on or charge
I would also like to know if you find a fix for this problem. I have the BT500 and it will also not turn on.
Sep 17, 2007 | Jabra BT500 Wireless Headset
Jabra Cruiser InCar Speakerphone Black Logo
29 people viewed this question
Top Jabra Cell Phones Experts
Ed Nelson
Ed Nelson
Tom Chichester
Katlin Donnelly
Are you a Jabra Cell Phone Expert? Answer questions, earn points and help others
