Question about Roku 2 XD Streaming Player 1080p (3050R
How do I unfreeze my roku 2
My roku 2 is frozen and I can't find a reset button
Daughter's dreamtab is Frozen and asking 4 password
She or someone has put a password on it. You will have to Factory Reset it and scrub it clean. Power down. Hold the power button and the volume up button until you see the Recovery Console.
Frozen is different, and it can't be frozen at a password normally. To unfreeze, Hold Power Button and Volume up button until the first logo appears and then let go.
Jan 22, 2017 | Computers & Internet
How do i unfreeze my tablet that is frozen on the android
Full reset: Download and instructions from manufacturers website.
Jan 03, 2015 | Tablets & eReaders
How do i unfreeze my mp6204G?
all you have to do is hold the select button and the power button at the same time for about 5 seconds.
or you can insert a paper clip into the reset button. it wont reset your MP3 it will just unfreeze
Jul 02, 2014 | Coby MP620 MP3 Player
How do I connect my new roku?
You could see something for sure.
Verify the input you have the Roku plugged into is the one you currently have selected on the TV.
If that doesn't work, plug use a paperclip to press the small "reset" button button the Roku.
You can also choose to perform a hard reset:
Hard reset
If a soft reset doesn't fix your problem, a hard reset may be your only option. This will clear all data off the Roku 2 and reset it to factory default settings.
1. Remove all cables except the Power cord.
2. Using a paper clip, press and hold the Reset button on the back of the device for about 15 seconds.
3. Continue to hold the Reset button, then remove the Power cord from the back of the unit.
4. Release the Reset button, then plug all of the cords back into the device.
The Roku 2 should walk you through the setup process again.
You can also accomplish a hard reset by selecting Settings > Factory reset > Factory reset > Yes on the device's menu.
Finally, try using a different HDMI cable.
Let me know if any of this helps.
Source:
How to Hard and Soft Reset the Roku 2
Jun 06, 2014 | Televison & Video
How do I unfreeze my Apple ipad air ?
It's actually very easy, once you know how to do it. Click and hold down the Sleep/Wake button (located on the upper-right corner of your iPad). While you're holding down the Sleep/Wake button, hold down the Home button as well (located on the front of your iPad at the bottom).
Hold down both buttons until your iPad powers off. It will reboot and start again with a small silver Apple image on the screen. It takes about 30 seconds for the iPad completely start up.
May 12, 2014 | Apple iPad (16 GB) WiFi Tablet PC
Roku com
You should find a small button on the back of your Roku device. Press it and reset the Roku to factory defaults.
Mar 05, 2014 | Computers & Internet
It is frozen i have the 1g sansa clip mp3 player how do i unfreeze it
You MP3 player may have a pin hole RESET button on the back of the player, use a pin or straighten paper clip and insert it into this pin hole. This button may be able to unfreeze your player.
Apr 04, 2011 | SanDisk Sansa Clip MP3 Player
My Sony reader prs-600 is frozen. The reset button doesn't do anything. How do I unfreeze it? A part of my screen still works, but a big part doesn't. What can i do?
Try holding the reset for 5-10 seconds, then flip the power switch quickly, three times. If this doesn't work, check the light next to the power switch. If it is flashing yellow, follow the same process. It might take up to three tries.
Jul 21, 2010 | Sony Reader Touch PRS-600
Ipod 120GB frozen
You just needed to reset your ipod by pressing and holding the MENU and the CENTER buttons at the same time. Wait for the apple logo to appear.
Please let me know if you are able to do this successfully. Good luck!
Jul 04, 2010 | Apple iPod classic MP3 Player
Frozen ipod
try a reset
To reset your iPod:
  • 1. Toggle the Hold switch on and off. (Slide it to Hold, then turn it off again.)
  • 2. Press and hold the Menu and Select buttons until the Apple logo appears, about 6 to 10 seconds. You may need to repeat this step.
read more here
http://www.fixya.com/support/r561901-ipod_problems_start_5_solutions
Jun 01, 2008 | Apple iPod MA446LL/A MP3 Player
Roku 2 XD Streaming Player 1080p (3050R Logo
275 people viewed this question
Top Roku Televison & Video Experts
David Payne
David Payne
ray gallant
tomar33
Are you a Roku Televison and Video Expert? Answer questions, earn points and help others
