Question about Microsoft Windows 7 Home Premium 64BIT Operating System Software OEM DVD
How can i format my lenovo z4600
My laptop will just automatically turn to safe mode. sometimes it just turns off by itself. i think i need to format it but i do not know how. also i do not have nothing with me for formatting. thanks.
    Sergeant:
  • 293 Answers
Start from a cold start, tap F8 repeatedly through the splash screen. This should bring up a startup option. Select the recovery option. This will work only if you have a recovery partition still on your computer. If not, you'll only have access to limited options; restore, troubleshooter, and a few others...
Posted on Sep 10, 2014
  • 624 Answers
SOURCE: Formatting a laptop's c: drive
That all depends on how much preparation you do before hand and how much experience you have installing operating systems and resolving issues that come up. Things to look out for: -Have all the hardware drivers on a readable CD. The manufacturers original CD is best. -Do a test boot to the install CD just to make sure it works. -Make sure you have a legitimate Windows software key. There should be a Microsoft sticker with the key printed on it. -Keys can only be used to install the operating system three times. If you purchased this new you should be OK, if its used the previous owner may have already reformatted a couple of times so be prepared to spend time on the phone with Microsoft. -Do this somewhere where you have access to a broad band connection so you can download the updates and patches. -Remember to pull your data, shortcuts and passwords off the hard drive before you format. -Make sure you document the software you have currently installed. Make sure you have the installation CD and the license key to reinstall them. -Some manufacturers like to create a special partition for diagnostic utilities. Make sure you don?t delete that unless you know what you?re doing. -Allow for plenty of time, it takes about an hour and a half to two hours for a pro to save data, format, reinstall and update software. If this is your first time it may take you a evening if nothing goes wrong. Bottom line is you don?t want to be doing this if you have any major projects, taxes or anything else coming up soon. Good luck.
Posted on Aug 01, 2007
frcs68
  • 1605 Answers
SOURCE: hanging problem
look like the winamp audio porblem.
uninstall it.
try to clean up the hard drive by using defregmentation.
reinstall the winamp again.
Posted on Oct 20, 2008
  • 67 Answers
SOURCE: formatting laptop
Before you start doing anything you should download your drivers from acer's web site. Save them on a cd or a flash drive. Once you put your operating system CD (xp, vista, 98, 2000 doesn't really matter) restart your laptop. It will prompt you with "press any key to start from CD" and you press enter or space bar. This will take you to setup screen. The setup will ask you what you want to do. Repair, or install. You need to select install. Next will be the partition setup. If you want to divide your hard drive two seperate pieces in example you have 80 G hard drive and you can set it up as C drive 40 G and D drive 40 G, you need to do it in this section. If not just follow the instructions. It'll also ask you if you want to delete the partition, I would suggest to delete it. It'll give you a fresh start. Then it'll tell you if you delet the partition you will loose all the documents in your hard drive which is your goal anyways. After you delete the partition it will format the hard drive (it has to) and will install all your operating system components. When its done this is what you need to do. Right click on my computer and click on properties. On the general tab click on device manager. When device manager opens up you will see some hardware devices with a yellow question mark beside it. Those are the ones that you need to install drivers for. That's why we wanted to create that driver CD or Flash drive. Once you intall the necessary driver, you are good to go. If you have any questions let me know, I'll walk you through.
Posted on Feb 20, 2009
Cool_dud 09
  • 206 Answers
SOURCE: My Windows XP computer wont turn on unless I use
Hi Friend,
So you really don't want to format and must have your data's. May i ask you one thing,have you ever created an system restore point...if so you can do the trick. Hw to acess System restore=> start->All programs->Accessories->system tools.And this actually roll-back to your good configuration setting,by this you won't loss any data's....but make sure you do it safe.Do not need to fear that it will damage the OS.Please try on.Click the below links for further deatils:
Hope this helped!
Posted on Oct 11, 2009
Testimonial: "Thanks, this is helpful, but it worked good after restarting the computer, donnu why, it didn't work before after restarting... Still, this is helpful"
EarCandy
  • 93 Answers
SOURCE: DEP userinit logon error..safe mode wont run..help!
I would try a repair install.
http://www.michaelstevenstech.com/XPrepairinstall.htm
Posted on Oct 29, 2009
Safe mode in lennovo g500
When you start your computer. Hit the F8 key, and then a prompt will come up to boot in Safe Mode, Safe Mode with Networking, and Safe Mode in Command Prompt. Make your choice.
Apr 08, 2014 | Lenovo Essential G500 Laptop Computer -...
Get safe mode off
Windows sometimes automatically runs on safe mode if the computer was not shut down properly the last time it was used. There is no turning safe mode off, you just need to restart your computer and everything will be back to normal.
Jul 17, 2013 | Gateway ZX493131e Notebook
Keyboard on laptop is locked
Keyboard is locked? No keys work or are you saying the Mouse and Touchpad is locked?
Try booting up in Safe Mode and see if it is still happening.
Turn off the computer, then hit the power button to turn itback on and immediately start hitting the F8 key repeatedly until you see SAFEMODE. Take the Safe Mode option and let it boot up. Safe Mode will lookdifferent to you, the screen will be darker and the icons bigger, this isnormal.Sometimes a virus hijacks the keyboard or mouse. If any of the above did not solve your problem then run a virus scan.
Apr 02, 2012 | Lenovo ThinkPad T61 Notebook
My Laptop is Lenovo R500 windows 7 when I power it on it stuck on the first screen ( lenovo logo ) I tried to remove the hard disk and install another one ,nothing happen and I tried to check the ram...
Welcome to Fixya
Try to boot the computer in safe mode. Turn off the computer then turn it back on. keep on tapping F8 then select SAFE MODE form the selections. If your computer wont able to boot to safe mode then you have a corrupted operating system. You need to reinstall windows using the recovery disk that came with the sytem.
Thank you for using Fixya!
Jul 09, 2011 | Lenovo ThinkPad R500 Notebook
Automatic re booting
Welcome to Fixya
Try to do system restore first on safe mode. Turn on the computer and keep on tapping F8 key. Select safe mode and press enter. Once you are already booted up to windows safe mode, click start menu then click all programs. Click accessories then click on system tools. Click system restore then choose a date where you remember the computer is working fine. Restore the computer to that date.
Thank you for usng Fixya!
Dec 24, 2010 | Lenovo G550-29583AU Notebook
How do i boot a lenovo Z61t in 'safe mode'?
Once you turn on the computer keep on tapping the F8 key and this will give you an option to boot to safe mode.
May 20, 2010 | Lenovo ThinkPad Z61t PC Notebook
Toshiba laptop running w7, when i turn laptop on it goes straight to start in safe mode or normal, tried safe mode but get a continuous beep, then it switches off, then turns itself back on again, with the...
Thats because your lap top needs to be reebooted in a format to reconfigur itself unfortunatly its not doing that please! do an early system restore to when it was working and save those settings for the next time this happens ok! and save all your current files just in case you need to wipe your whole drive to origibal settings ok!
Mar 26, 2010 | Computers & Internet
Green flickering squares when i turn on my laptop
Something's wrong with the display driver or the display card. You can try opening up the T61. The contact on the display chip or the display connector is probably corroded. Try pressing them a bit (not to hard). if it's the display connector, try removing it and placing it back. I've had this problem before with some other notebook. It's ok when in safe mode because safe mode doesn't use the higher display functions.
Oct 11, 2009 | Lenovo ThinkPad T61 Notebook
Lenovo reboots
Do you have the restore disk? I recommend formatting and completely reinstalling windows. This should help you. If you need further instructions, feel free to ask.
Jan 12, 2009 | Lenovo 3000 Y410 Laptop
Re boots itself
when you turn on the pc keep pressing F8 and it will boot into safe mode. When in safe mode highlight the option 'Last Known Good Configuration' and press enter. The pc should now reboot normally, if not you will need your installation cd to do a system repair.
Mar 18, 2007 | Acer Aspire 3000 Notebook
Microsoft Windows 7 Home Premium 64BIT Operating System Software  OEM DVD Logo
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
