Question about Homelite Garden
Homelite blower pull cord frozen how do i troubleshoot it
Blower was running and started to bog down until it died, thought it was out of fuel but it was full. tried to start it but i only got 1 pull then the cord locked up
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 111 Answers
Go buy a new blower, you ran the wrong fuell/oil mixture and seized the motor.
Posted on Sep 04, 2015
chad7houston
  • 62 Answers
SOURCE: Homelite leaf blower bogs down.
I don't mean to over simplify this, but are you using fresh gas? Gas blowers are extremely ticky when it comes to gas. They like it SUPER fresh. And while the gas and oil mixture should be right, it can be off a little bit and still run. Try draining all of the gas out, and then filling up with fresh mix. This is ALWAYS my first step with gas blowers, and it fixes the problem 75% of the time. Also make sure your spark plug is clean. If you are not sure, a new plug couldn't hurt.
Hope this helps!!
chad
Posted on Oct 08, 2008
  • 398 Answers
SOURCE: Homelite 26D leaf blower bogs down in Run position
check the air filter.
Posted on Mar 02, 2009
  • 127 Answers
SOURCE: MY RED MAX EB431 BACK BLOWER STARTS, RUNS FOR A
first replace fuel filter in the gas tank you will need to fish it out with a coat hanger bent on the end to replace if that still does not fix your issue carb needs to be rebuilt
Posted on Sep 06, 2009
  • 430 Answers
SOURCE: Ryobi backpack blower will run all day with choke
Thats a lean condition. Check fuel lines and fuel filter. If the fuel ilnes are discolored or stiff or really super mushy, If the fuel filter has become detatched from the fuel line then the fuel lines need to be replaced.
If the carb can be adjusted you can try to adjust but its likely that the carb should be rebuilt with new diaghrams and gaskets.
Adjust by turning the low speed screw out ( counterclockwise) 1/2 a turn. The low speed screw is always the one closest to the motor and usually marked on the carb body with an 'L'. When you richen a motor up the idle will drop so you will probably have to turn the idle screw in 1/2 a turn. 1 and 1/2 turns out from light bottom is standard starting point ( 2 turns for poulan products). If you get more than 3 and 1/2 turns out on the low speed screw or if turning the screw has little or no effect then the carb should be rebuilt.
Posted on Dec 13, 2009
SOURCE: bogs down at full thouldel tryed to adjust carberator
Hi
This is either a clogged muffler or carb. Take the off and see if it will rev. If not you need to clean carb and install a carb repair kit. Do not run long with muffler off.
Sam
Posted on Jan 07, 2010
Pull cord frozen
if it died while in use and you can't pull the starter cord the engine might have locked up was the oil/fuel mixed properly?remove the cover and see if the flywheel can turn
May 19, 2012 | Poulan Pro 25CC 2Cycle Gas Blower
Ryobi gas blower tuff starting and bogs down, and dies
take the muffle off and run it if ok open the muffler a bur off the screen inside with a tourch
Mar 25, 2012 | Garden
My Ryobi blower starts just fine. I let it run for a minute to warm up and when i pull the throttle it starts blowing ; however, if i pull full throttle the engine bogs down and will eventually die. I have...
this sounds like a carb problem one that needs porfessional help take it to your small engine shop be careful as to not go over the valvue of the blower on repair and parts have them to give you a quote first
Jul 21, 2011 | Garden
My Homelite backpack leaf blower runs until tank is 1/2 full
thats what it is try opening the gas lid look inside to see where the fuel line lies if its up high them try pushing it down to the bottom
Nov 13, 2009 | Homelite Consumer Products Backpack...
My blower runs but does not have great blowing power.
Clean out the intake of the blower, more than likely it is clogged with leaves. Also make sure your fuel mixture is correct, to much oil will bog it down.
Nov 09, 2009 | Homelite Consumer Products MightyLite...
How do I adjust needle valves on a 25cc Homelite UT08111A Backpack leaf blower?
Set the lowend & highend needles to about 1 3/4 to 2 turns each. Choke the carb or prime it, until the carb is wet. Fire up the engine and let it warm up. Let's set the topend first since it's the easier of the two. Go to full throttle. Adjust the topend needle for peak RPM. Leave it wide open for about a minute to see if it changes any. Should the engine go lean, open the lowend needle slightly, if this dosen't work... you will have to adjust the needle valve inside the carb.( I will explain this later) If the topend runs OK, then slowly pull the throttle down until the engine begins to "four cycle" hold the throttle there. Adjust the lowend needle until the "four cycling" barely stops. Now lower the throttle more until it "four cycles" again, and adjust the lowend again. Keep doing this until you reach full idle. Now, from full idle begin to throttle up until the engine starts to bog or hesitate. Open up the lowend needle just enough to eliminate the bog or hesitation.
http://tech.flygsw.org/walbro_tuneup.htm
hope this helps :)
if it does please vote
Oct 23, 2009 | Homelite Consumer Products Backpack...
Homelite chainsaw mod 4620c will start and windup and die
Sounds like it is getting lean (running out of fuel) then dies. Clean and inspect carb and fuel lines.
Oct 08, 2009 | Homelite Consumer Products Backpack...
Homelite 26bp backpack won't run up to full throttle
I have let my leaf blower run and warm up before throttling up and still it bogs down and shuts down. There is no air cleaner to clean should I just blow out the carb. and fuel lines?
It runs and idles just no high speed to blow.
Nov 16, 2008 | Homelite Consumer Products Backpack...
Hope this helps!!
chad
Sep 29, 2008 | Homelite 'Yard Broom' Leaf Blower
Garden Logo
213 people viewed this question
Top Homelite Garden Experts
Jim Parker
Jim Parker
roeb
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
