Question about Microwave Ovens
Baumatic appliances Hi I have a Baumatic Oven P629BS. I have got it in manual operation mode as the timer manual operation button is lit up but when i turn the knob for the oven function the power indicator light is not coming on and turning the thermostat control knob doesnt heat the oven up. Any idea how to get the oven working?
MicrowaveSvc
  • 9085 Answers
SOURCE: MICROWAVE OVEN DOES NOT HEAT ALL OTHER FUNCTIONS WORK
Since the light comes on and the turntable rotates, I would suspect a bad magnetron, a loose connection at the magnetron, a failed high voltage transformer, or shorted high voltage rectifier diode.
If it's less than one year old, it should be fully covered under warranty.I'd suggest contacting the manufacturer to get it fixed free.
Ifit's within the magnetron portion of the warranty (usually 5-9 years)but out of the original full warranty (usually 1 year), then yourmanufacturer will cover the part cost, but not the cost to visit you orthe labor charge to do the work.
If you or a friend want to work on it, please see these links first:http://www.microwavedisplay.com/safety.txt& http://www.microwavedisplay.com/disassembly.txt
Here are some links you or someone you know can use (in order given) for test help, but read the safety warnings first:
http://www.gallawa.com/microtech/diode.html (if it is NOT shorted, it's probably fine)
http://www.gallawa.com/microtech/mag_test.html
http://www.gallawa.com/microtech/xformer.html
Thereshould also be a "mini-manual" hidden inside the unit behind thecontrol panel or hidden on the left side behind the grille, which isvery helpful when troubleshooting & testing.
For Frigidaire models, you can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Or you can find your nearest Frigidaire/Maytag-authorized servicer here.
You can visit Daewoo onlineor call them at 1-800-323-9668 or 1-800-553-4355 to find parts or findyour nearest authorized service center to have them do the work.
Posted on Oct 07, 2008
ALIENAMERICA
  • 88 Answers
SOURCE: Mod: BMK 2 SS. Manual has gone missing!
http://www.baumatic.co.uk/products/catalogue/microwaveovens/BTM23.1SS
I beleive this is the same item, not sure why it has a different model number on the website, but you can download the PDF of the manual from the above link.
Posted on Oct 07, 2009
  • 8404 Answers
SOURCE: turn table turns.it sounds like the oven is
check the door safety interlock switch please
Posted on Oct 29, 2009
  • 55 Answers
SOURCE: Hi! Our wall mount micro/oven unit has lost power
CHECK FUSES INSIDE MICROWAVE
Posted on Dec 06, 2009
SOURCE: Microwave Oven EM-804T
When I opened up the microwave cover, noticed that the door latch mechanism was worn and not holding up the interlock switch. A thick piece of tape on the worn piece of plastic and microwave was back to working (I had symptom of the timer counting down without the microwave turning on)
Posted on Nov 01, 2010
Push button on microwave has stopped working
It is easy and cheap to fix this, but you need to know about electricity and electronics. Look for a local appliance repair person if you feel it is worth it, but many ovens are so cheap it may not be worth the repair costs.
Oct 09, 2014 | Baumatic BTM23 900 Watts Microwave Oven
Baumatic oven ba896ss
there is a good chance the electric surge has blown the pcb
Mar 26, 2014 | Microwave Ovens
Can't get out of demo mode Westinghouse oven WVE916SA!
DEMONSTRATION MODE – PROGRAMMABLE CONTROLLER MODELS
For display purposes, the appliance has a demonstration mode to enable demonstration of oven functionality without consuming power. In demonstration mode, the display, the light and the fan only are operational.
When the appliance is in demonstration mode and the display is switched on, the clock symbol will be on.
If the appliance is in demonstration mode, to operate the appliance normally the demonstration mode will need to be deactivated.
To deactivate demonstration mode:
1. Ensure the oven is off by pressing the ON/OFF button. 2. Press and hold the ON/OFF button until the display turns
ON then OFF and a single ‘beep’ is heard. Immediately after press and hold the ‘Timer’ and ‘–’ buttons simultaneously, until a triple beep sounds to confirm
the operation.
Nov 15, 2013 | Microwave Ovens
What microwave replaces the btm25ss baumatic builtin microwave. i need one the same size.help?
Contact Baumatic and ask if they have a "drop-in replacement".
Their contact information will be on your owner's manual or the dealer where you bought it should know.
Apr 08, 2013 | Baumatic BTM25SS Convection Microwave Oven
I"m looking for a wiring
The closet model number I could find was the BT83Al which is a discontinued model. At teh follwoing site you can download a User Manual and Technical Drawing.
http://www.baumatic.co.uk/bt83al_21_106_550.html
If this is not your model other discontinued models can be found here:
http://www.baumatic.co.uk/cooker_hoods_21_106.html
Current Models:
http://www.baumatic.co.uk/cookerhoods.html
Feb 11, 2011 | Baumatic Microwave Ovens
Microwave not heating food up. Had Baumatic microwave for 3 years
Here is a tip that will help you to figure out what is wrong with your Microwave Oven....
Basic
Microwave Oven Troubleshooting Tips
heatman101
Dec 20, 2010 | Baumatic BTM231SS Microwave Oven
How do we replace the light bulb in our Baumatic BTM25SS microwave oven? It seems to be inaccessible....
From Baumatic:
"Unfortunately, the bulb is positioned next to the main working component of
the microwave. This means only a qualified domestic appliance engineer,
trained to work with microwaves can carry out such a repair. If you wish to
have a Baumatic engineer attend, please contact the Baumatic Customer Care
team direct on 0118 933 6911. If, however, you wish to purchase the correct
bulb and have a local engineer carry out the repair, please call the
baumatic Spares team direct on 01235 437 244 for price and delivery
information."
Nov 20, 2010 | Baumatic BTM25SS Convection Microwave Oven
Micro wave is operating but not heating up the food
Basic Microwave Oven Troubleshooting Tips
heatman101
Aug 24, 2010 | Baumatic BTM231SS Microwave Oven
Oct 07, 2009 | Baumatic BTM231SS Microwave Oven
How to replace bulb in baumatic btm25ss microwave oven?
Had the same problem. From Baumatic:
baumatic Spares team direct on 01235 437 244 for price and delivery"
information.
Apr 17, 2009 | Baumatic BTM25SS Convection Microwave Oven
Microwave Ovens Logo
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
