Question about Acer Aspire Z Series All-in-one Touch PC Z5600-u1352
I need parts
I am trying to find parts for my Acer Aspire Z Series All-in-one Touch PC Z5600-u1352 pleas help me find parts
Paeroa
  • 457 Answers
SOURCE: acer aspire t180 pc has parallel and usb ports printer does not work help
Did you update the lexmark printers drivers from their site I think if you do this you should have no prolems.
Posted on Sep 19, 2007
Moe09
  • 18 Answers
SOURCE: Acer Aspire 5315 Touch pad problem
go to the control panel, mouse configuration , and try to turn on the touch pad
Posted on Aug 30, 2009
SOURCE: I just bought an ACER ASPIRE 5532 SERIES LAPTOP
press the button to the left of the power button and it should work again.
Posted on Dec 26, 2009
lynnmar48576
SOURCE: HOW DO YOU TURN ON WEBCAM ON ACER ASPIRE Z5700, I
It's hiding in All Programs -- Silverlight. I just found it.
Posted on Feb 05, 2012
thomas4144
  • 7 Answers
SOURCE: Hi, my Acer Aspire
Hi Friends,
this is a common problem with a simple reason. The copper cooling fins in front of the fans are clogged with dust. Use SpeedFan (download free at http://download.cnet.com/SpeedFan/3000-2094_4-10067444.html) to verify. I bet it suddenly shuts off when you run a cpu intensive program. If the cooling fins are clean you can run 100% cpu for as long as you want. At 25 degrees room temperature the cpu temp will be around 65 degrees C at max. This is also too high, but the cpu they use (Q8200) is a "hot" one and Acer did a very bad job in the cooling solution.Anyway, when the cooling fins are blocked by dust, the temperature at 100% cpu goes in seconds north of 80 degrees C. And the CPU has a safety inbuild. I forgot the exact temperature, I think it was 90 degrees. At that temperature the cpu kills windows and you have a black screen.
Sometimes you can not restart at once or you might land in the BIOS at restart, telling you that the cpu had overclocking problem.You can't force it: if it is too hot, the cpu will not start!
There is only one help. You have to open the **** thing and take out the fans. Than you will see what I mean with clogged cooling fins. Clean them with vacuum cleaner and brush - clean the fans and put it back together. I did it right now again (have to do it every 6 - 12 months depending on how much dust you have around.
Download the SERVICE manual to see how to open it. its just the back panel of the casing, and the metal sheet cover and than you can take out the fans (carefull with the connector - its small and can easily be broken). To take off the rear plastic cover (the very first step in the service manual) is tricky. Do exactly as described in the manual. when you push it down, it will bend a little and the hooks on the back will slide out off their anker holes.
link for service manual : http://www.google.com.hk/url?sa=t&rct=j&q=acer+z5610+service+manual&source=web&cd=5&ved=0CEEQFjAE&url=http%3A%2F%2Fzremcom.ru%2Finstructions%2Fmanual-acer%3Fdownload%3D254%3Aacer-aspire-z5600-z5610%26start%3D100&ei=aco3T_3FA8-SiAeFzKj6AQ&usg=AFQjCNHOiuAEA5Y0-9mLYvJyUTCy1HW0MA
Posted on Feb 12, 2012
My Aspire Z5600 with windows displays application error. NAPP_KM:NAPP7.EXE. Any ideas pleas
Hints:
If you are traying to reinstall the whole system or recovery, on a refurbished PC, this error became critical with your hard disk because its another disk, but the program its not automatically working with your restore partition, you have to recover manually or using the restore CDs (originals only).
good luck
Aug 17, 2016 | Acer Aspire Z Series All-in-one Touch PC...
Wont start up.
maybe a corrupt or missing file,try starting in safe mode
Jun 14, 2014 | Acer Aspire Z Series All-in-one Touch PC...
Keyboard and mouse not working on my acer azs600-ub34 all in one computer
Did you do everything that was i the manual? Switch on the blue tooth connection on the tablet, switch on the keyboard. Do any lights blink on the keyboard when you switch it on?
do you have to put in any key code (0000)?
Jun 09, 2014 | Acer Aspire Z Series All-in-one Touch PC...
Does this have a 3.0 usb port?
Memory Module Specifications Total Memory Size 6GB Memory Type DDR3 Monitor Specifications Display Type Active Matrix TFT Color LCD Screen Size Connection Type HDMI Maximum Resolution Touch Screen No Media Ports LAN Ports 1 - RJ-45 Ethernet Connector USB Ports (Total) 4
USB Ports Powered (Included In Total) 2x USB 2.0, 2x USB 3.0
Audio Out Jacks Processor Specifications Processor Brand AMD Processor Class A6 Processor Number 5200
Processor Speed 2 GHz Hard Disk Drive Specifications Hard Drives Included Capacity Interface ATA Hard Drive Types Hard Disk Drive
Apr 26, 2014 | Acer Aspire Z Series All-in-one Touch PC...
Power on blue light comes on then off again
Why did you buy that laptop man I have it and threw it in bin then I make fire and roast bacon,
Oct 05, 2013 | Acer Aspire Z Series All-in-one Touch PC...
Acer Aspire Z Series All-in-one Touch PC Z5600-u1352 Logo
Mohammed Ebrahim M
Mohammed Ebrahim M
Steve Sweetleaf
Steve Sweetleaf
