Question about Sunbeam Retail Supplies
LOOKING FOR MANUAL FOR SUNBEAM ROOM AIR CONDITIORNER SCK5200DR
Sunbeam portable air condition..all things work..compressor runs..but now cold air sunbeam portable air conditoner mode KY25 ..9,000 btu I have it since 2005..I've used it for one year..it's been...
sometimes storing an AC for long periods of time will allow the coolant that it uses to seep out, leaving you with an AC that seems to work, but won'tr cool any air. If you have a user's manual (or can find one) check to see what type of coolant it uses (if it's freon or something else) and if you can refill it. If you can refill the coolant, that should resolve your problem ... if not, you might be able to take it to a repair shop and have them do it for you. Good luck!
May 29, 2011 | Sunbeam SCA082RPC1 Portable Air...
My a/c craped out,how do i measure for a new one--it is in the wall.
From the following website you can download a manual that will give you all the dimensions and installation specifics you need.
http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Apr 13, 2011 | Sunbeam SCA103RWB1 Room Air Conditioner
Sunbeam Model No. SCK 14200 DR no cooling...
Un plug a/c from wall and remove the screws from the electrical compartment of the unit and locate the thermostat, remove the 2 wires of the thermostat and use ohms meter to check the part for continuity, if you dont have continuity with t-stat turned down below room temp., replace thermostat.Good luck.
Mar 05, 2010 | Sunbeam SCA103RWB1 Room Air Conditioner
Warm air
How big of a room are you trying to cool? The rule of thumb is 600 sq ft per 12,000 btu.
Aug 21, 2009 | Sunbeam Heating & Cooling
I'm looking for a free users manual for a Sunbeam floor a/c that I purchased at auction. Works great, but need to know how to hook up the drainage tube thanks
Do you have the exact model number of your Sunbeam A/C? Check the links below and download the free manuals:
http://homeappliance.manualsonline.com/manuals/mfg/sunbeam/sunbeam_air_conditioner_product_list.html
http://safemanuals.com/brand-user-guide-instructions-owner-manual/SUNBEAM
I'm not exact sure if this is the model for your A/C
Hope this helps and have a great day!
Jul 07, 2009 | Sunbeam Heating & Cooling
How to use a SUNBEAM twin window fan with
Intake brings the air outside into your room, exhaust pushes the air inside your room out.
What setting you use depends on your personal taste of temperatures and the temperature inside vs outside. If you set the thermostat to 72 degrees and it is more than that outside then I would use the exhaust setting. If you set it to 72 degrees, and it is 68 outside but 84 inside then I would set it onto intake to cool the inside air.
Jun 21, 2009 | Dryers
Retail Supplies Logo
314 people viewed this question
Top Sunbeam Retail Supplies Experts
Electroboy
Electroboy
Patrick Tinashe...
Are you a Sunbeam Retail Supply Expert? Answer questions, earn points and help others
