Question about A.O. Smith SQ1102 Pool Pump Motor
J5s goulds pump froze & busted-welded it and now will not pump
Pressure switch clicks off and on will not stop
could be several things that cause this. I would first try increasing the spread between the upper and lower limits. it they are set too close together you can get this kind of bouncing on and off. Also, how old is the switch? as they age they get less and less accurate at reading the pressure accurately and this could be the problem. Longer shot, could be a leak in the well check valve. Water leaking back down into the well and that keeps turning the pump back on when there are no faucets open.
Jan 08, 2016 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Goulds j5s pump discharging rusty water and green moss particles. how do i flush
If its discharging all the time, I would say its sucking up contaminated water but if only occasionally, that would suggest something is rusting / deteriorating in the system and it "grows" when the pump is not in use. I would have a close look at the source tank(s), the connecting pipework and as a last resort, disconnect the pump and have a look inside the pump chamber.
Jan 04, 2016 | Goulds Pumps Goulds 1/2Hp Shallow Well Jet...
When H2O runs pump keeps cycling every 15 to 20 sec. H2O drops to 30psi and pump stays on until 60psi. Then a couple of seconds does again until H2O is shut off. Pump runs for around 30 seconds.
If you've got the water turned all the way on, it sounds like your setup is operating normal. If the pump where turning of and on say every 5 seconds or so I would say to check the air pressure in the water holding tank that it's at the correct pressure.
Mar 01, 2015 | Goulds Pumps Goulds J5S Jet Pump Shallow...
Why does my goulds pump j5s draw water to the pump but it won't pump out, what could be wrong and can it be repaired?
you will have to prime the pump after working on the lines. You can get just the pump section but I doubt that there is much wrong other than priming the pump
Aug 05, 2014 | Goulds Pumps Goulds 1 Shallow Well Jet...
Our goulds pumps j5s is running very loud after we replaced our sewage ejection pump last week. Could these problems be connected?
Those pumps last a long time. I do not think the problems are connected. I am assuming you are pumping water up from the pump. The pump has a check valve in the discharge that may not be closing. Cleaning that should solve your problem. Be sure water will pass through the discharge line into the drain.
Feb 05, 2014 | Goulds Pumps Goulds J5S Jet Pump Shallow...
My goulds pump plus jet j5s comes on fine win u plug it in and its geting plenty of water just wont gain any pressure
It sounds like a leaking foot valve. Not sure but I have seen this many times on other pumps.
Nov 28, 2013 | Plumbing
Pump will not shut off
could be worn mechanical parts in the pump, or air in the pump. Make sure there is no air leaking into the suction/inlet side of pump.
Nov 14, 2013 | Goulds Pumps 1/2HP J5S Shallow Well...
How do I change the motor side casing on a j5s pump
The motor must be dismantled as well . a bit scary , but I have done one Carefull not to damage the motor axle ie comutator etc.
May 01, 2012 | Goulds Pumps Goulds 1 Shallow Well Jet...
I have a pump that will not pump higher that 40 psi. There seems to have plenty of water to the inlet, it is even gravity flow no suction needed. This pump is about 9 years old and recently during a flood...
The Goulds J5S pump is only rated for 40 psi. Is it possible that is the correct operating pressure? Did you get a higher reading in the past?
Dec 27, 2010 | Plumbing
How do I remove the impeller from a J5S pump?
most pumps arent made to be rebuilt and should just be replaced , its not worth fixing something and have it just go bad again.
Feb 09, 2010 | Goulds Pumps Goulds 1/3 Hp 115V 1 Phase...
A.O. Smith SQ1102 Pool Pump Motor Logo
29 people viewed this question
Top A.O. Smith Plumbing Experts
Donni Steen
Tom Chichester
Are you an A.O. Smith Plumbing Expert? Answer questions, earn points and help others
