Question about Lexmark X1150 All-In-One InkJet Printer
Black section in scans
Hi. Just today we have had a problem where the scanner leaves a large black section in the scanned image.
The first inch or so of a page is scanned, then the next 2 inches are black, after which the scan is OK.
I tried reloading the software and drivers but this did not help, other than the black section sometimes has thin bands of colour in it.
  • Lexmark Master
  • 1,113 Answers
Check/clean scan glass for marks (small section of glass under lid that runs width of copy glass.
Is lamp dim or dark in one section?
at low res. what is the result?
Posted on Nov 04, 2007
Clean the slit glass under the document feeder. Lift the feeder and find the thin piece of glass on either the left or right side and give it a good cleaning - you marks will likely go away.
Here is a how-to for removing lines from Sharp copiers.
How To Remove Lines from copies prints on Sharp copier
Jan 17, 2014 | Sharp Mx-C402sc mx-C402sc
Thick black lines when scanning Samsung SCX-4824FN
The contact image scanner is faulty or the cable from the motherboard to the contact image scanner is faulty. I would bet it is the CIS as this scanner is used in many different machines (canon,lexmark,sagem) and it gives problems in all the machines. You can usually salvage a good one from an elcheapo lexmark inkjet multifunction.
Feb 11, 2013 | Samsung SCX-4824FN A4 Mono Laser Printer
When trying to copy or scan on my HP Photosmart C4400 printer I recieve a large black line down the document. This only happends when using the scanner.
THERE IS A DUST PARTICLE LODGED ON THE PIECE OF GLASS ON THE SURFACE SCANNING SECTION OF YOUR SCANNER. The scanner section has a long 8 1/2 inch or longer piece of glass that is about 3/4 of an inch wide. Clean the piece of dust or whatever off of it and the line will go away.
I normally use a cotton swab with alcohol on it and get it off .
Good Idea is to clean the whole piece of glass off from time to time.
I hope this has been a help to you.
Best Regards,
Dec 30, 2010 | Office Equipment & Supplies
My scanner scans black Does not scan document.
Does the scanning light come on? The light may be burned out. Also Try cleaning the scanning tip.
Jul 17, 2010 | Visioneer RoadWarrior Patriot Handheld...
How can I scan a document then print it with larger print?
You can scan a document or photo or negative film etc.. using a scanner, there a many types of scanners which you can choose as per your requirement. There are dedicated scanners, all in one integrated scanners, or two in one like that.. but if you need it for your professional use or daily use, it's better to get a dedicated scanner not "all in one" since with all in one if the copier fails or fax fails, the scanner will also fail because they are related and built-in integrated.
The process of scanning a document is as follows;
  • > Place the document on the scanner's flatbed.
  • > Press scan button or scan using the integrated software from the computer.
  • > Customize the scan settings/quality.
  • > Save the scanned documents.
Printing a document to a larger size is different, you can use photo editors like photoshop, etc..where you can changed the resolution as well as the size of the image. It's best to change the size or resolution before you give the print command. Or you can also change the print size with the paper size or print size.
If you still need more help, please let me know with more details. I am ready to assist you.
Good luck.
Thanks for using FixYa.
Jul 04, 2010 | Computers & Internet
I am trying to scan a document and it is not working, I have a hp photosmart c4280 printer. How do I install a usb cord
Place the document or image into the scanner for scanning. A scanner with a paper feeder will only receive flat papers and photographs, but a flatbed scanner opens to accommodate books, fabrics and leaves along with flat papers. There is even a attachment for feeding photo slides into flatbed scanners.
  • Step 2 Start the scanning softwaremag-glass_10x10.gif. If the scanner does not engage the software automatically, press the "start" or "scan" button, or click the scanner icon on the computer screen to initialize the software.
  • Step 3 Activate the scan. Click the "file" menu and select "acquire," "import," or another practical choice that applies.
  • Step 4 Preview the item to be scanned. Most scanners have a preview option. This will show the scan area inside dotted lines. The lines can be moved with the mouse to relocate, enlarge or crop the scanning area.
  • Step 5 Set the resolution for images by number of dots per inch (dpi). For computer screen viewing, 100 dpi should suffice. Use 200 to 300 dpi for items to be printed.
  • Step 6 Use the appropriate setting for scanning black and white text. If the scanner does not show a preset for text, use "line art" or "black and white" at 300 dpi. Then use the optical character recognition (OCR) program to convert the image of the text into a file for word processi
  • Jun 09, 2010 | HP Photosmart C4280 Aio Printer
    I need a scanner that will scan 10X14 pictures
    I found some scanners for you listed below but,
    You can also scan large pictures in sections, and then use a program like STITCHES. Basically you scan it in quarter sections and then create a working board in your photo program and then you copy and paste each section into that board and line up the edges.
    This is what most people do rather than buy a very expensive large format scanner.
    Some large companies also have large scanners for maps etc. If you know someone who works for a very large company or one that does surveying etc. They may do this favor for you.
    Though copy stores may have the size you need, copywrite issues will be asked about.
    Here is the list.
    large format scanners
    Microtek ScanMaker 9800XL Scanner
    Price: $1,038.31, 12-by-17-inch tabloid size bed
    Mustek Scan Express A3 1200 Pro USB Large Format Scanner
    $154.69media_size_maximum: A3 (11.7 in x 16.5 in)
    Maximum Scan Width 44in.
    Input Size:Min: 4.5" x 5.5" Max: 42" x 100'
    Thank you and good luck.
    Oct 25, 2008 | HP Computers & Internet
    Help !! ,Microtek scanmaaker 3840 problem
    maybe you have to clean up your scanner.. and ur settings of scanner might have the wrong configuration....
    Feb 24, 2008 | Microtek scanmaker 3840
    Black area above the scanned image.
    If you set Automatic brightness/Contrast this happens. Try manual setting. Adjust different settings and select the best suited for a particular type of drawing. The scanner takes couple of milliseconds to judge the best lighting, by then the paper has moved little. This area appears black. This is easily solvable.
    S. Mohan, Chennai, India
    Dec 06, 2007 | Canon DR-9080C Path-Through Scanner
    Lexmark X1150 All-In-One InkJet Printer Logo
    190 people viewed this question
    Top Lexmark Office Equipment & Supplies Experts
    Don  Farrell
    Don Farrell
    Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
