Miele w3845 eps washing machine fault code f135 what does this mean please
2 Suggested Answers
  • 3 Answers
SOURCE: fisher & paykel washing machine fault codes
I have a Fisher & Paykel GW609AU Smartdrive Excellence 6.5 Washing Machine that would start then stop then start then stop a few more times before eventually beeping.
I fixed it by bypassing(joined the white and yellow wire) the trip out switch which is located under the control module(one screw to remove).Now it Works.
Posted on Feb 20, 2010
What does fault 55 mean?
Hi dear,
I do not know what sort of machine you have but following may help.
F55 Overriding time control overruned
That code blongs following machines.
Washing machine WT series
Tumble dryers TR-HH TR-GW series
Cooking Appliances H series.
If you be more specific about your machine (Type of appliance-Model number-Serial number) I can help more. Thanks.
Jan 11, 2016 | Miele Washing Machines
Miele washing machine w5872 what is fault 16?
Fault 16 means "Overdose". You get this error when you use too much soap. The electronic registers excessive foam building up.
Run a program without laundry, 95°C, extra water and about 200 ml of Acetic acid 16% solution (household vinegar) to neutralize the (alkaline) soap.
Mar 05, 2015 | Miele Washing Machines
Does anyone know what fault 55 is on a Miele washer drier please
The original english Miele descriprion for F55 is "Overriding time control overruned".
The german description is "?berlagerungszeit ?berschritten", meaning something like "Overlay time exceeded".
Feb 25, 2015 | Miele Washing Machines
What is code error F50 on my miele W3725 washing machine mean
I have today purchased a Miele 3985 machine with a know F50 Fault code appearing
Before I went to the expense of calling a Miele technician, I explored the blocked / clogged drain path
I removed the drain pipe and noticed there was a lot of 'residue' / gunk in there
I cleaned what I could, and blew through the pipe back into the machine
Then I did a cotton wash cycle at 90degrees, with a 1litre of bleach to clean the drain path
The wash looked extremely dirty during the cycle
It appears that this resolved the F50 fault code issue with my Miele 3985 Navitronic
Aug 08, 2014 | Washing Machines
What the meaning of f53 ptoblem?
Error code F53 on Miele is a speed sensor fault.
It has detected the drum speed to be wrong at some point and has indicated the problem to you.
Have you tried unplugging it. That will reset the computer.
If it's not coming up again after unplugging it, I'd not worry about it.
If it is coming up every time you use it, then you have either a faulty sensor, motor or pcb.
Miele are extremely secretive with information on their appliances and this makes it hard to diagnose accurately faults on them.
May 16, 2011 | Miele Novotronic W1930 Top Load Washer
Miele washing machine W5740. keeps saying fault f59 please help
There is no F59 error according to me, but there is a F56 error code, this is a tachogenerator error, usually given if the motor is underperforming. This requires either the Carbon brushes to be replaced or even perhaps the motor - Also known as a Spin error.
Hope this helps
* If you found this solution helpful, please vote positively.
Feb 17, 2011 | Miele Washing Machines
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Apr 01, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Washing Machine Code: Check drain
This means that the drain attached to the pump is clogged, remove the drain plug check fro debris and replace...you should be good to go.
Jun 23, 2009 | Miele Washing Machines
Washing Machines Logo
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
