My side of the mountain accelerated reader answers
2003 Mercury mountaineer high pitch whining sounds like front passengers side- just started today - worse when you accelerate - husband thinks it might be idler pulley bearing??
If it is the idler pulley for the accessory belt, it would make the sound at all times the engine is running, not just under acceleration. I would look to the wheel bearing or the brakes on that corner of the vehicle.
Feb 11, 2016 | Mercury Cars & Trucks
Location of dtc codeS mercury mountaineer
it is an obdII code reader. the plug that the code scanner ,reader, is under the dash next to the hood release latch its a black plug just to the left
Aug 06, 2012 | 1997 Mercury Mountaineer
Throttle position sensor
Should be on the left or right side of the throttle body opposite side of where the accelerator cable attaches.The TPS is a reostat (Variable resister) that is turned by the armature running through the throttle body.
Jul 18, 2012 | 2000 Mercury Mountaineer
Abs light comes when I accelarate to make a right or left turn from a side street or if I accelerate hard from a dead stop
First get the code that set the MIL Lamp. Will most likely, point to ABS Wheel Speed Sensor or System.
Then have the system diagnosed and repaired
Sep 28, 2010 | 2004 Mercury Mountaineer
2002 s10 zr2 runs rough bogs down when you
First check for any cracked pipes leading into the intake manifold If all OK (with no codes showing it probably is OK) try checking the fuel pressure regulator. If you smell fuel from the pressure regulator vacuum side arm (when the vacuum line has been disconnected) it needs to be replaced.
May 28, 2010 | 2002 Chevrolet S-10
Vivitar camera, vivicam 5022 no instruction manuel
You can download the complete instruction manual in PDF format by clicking this link.
  • You'll require Adobe PDF Reader installed on your computer to view the manual. If it is not already installed on your computer, download it free from: http://get.adobe.com/reader/
Hope this solves your problem. Thanks for using FixYa.
May 16, 2010 | Vivitar ViviCam 5022 Digital Camera
My Mountaineer accelerated while I was braking and
it could be either --throttle body sticking open will cause constant acceleration when u lift off pedal-cableless accelerator [electric gas pedal ]if a sensor or electronic part shorts out can open throttle body causing acceleration- would need to have it diagnosed to find out which problem is correct
Mar 01, 2010 | 2004 Mercury Mountaineer
2001 Mercury Mountaineer won't idle. It will run when I've got my foot on the accelerator, but as soon as I take it off, it dies. What's wrong with it?
Sounds like a faulty, IAC valve (idle air control) which controls your idle under load etc. Normally mounted on side of throttle body.Fairly simple for technician to test with ohmmeter to confirm before replacing. If your familiar with ohmmeter, get back to me and I'll guide you through test, otherwise shouldn't cost much for mechanic to test.
Dec 02, 2009 | 2001 Mercury Mountaineer
2003 mercury mountaineer lose power when
Hi, maybe there's a problem in your starter or your battery consume more electricity.
NephetZ
Jul 08, 2009 | 2002 Mercury Mountaineer
35 people viewed this question
k24674
jasbo
jasbo
