Question about Spectronics Spectrolinker Model Xl-1500 Uv Crosslinker W/ Ac
Braemar heater fault code
Reset door
MY BRAEMAR th5X23E showing reset -05 heater is not working at all
Go to the outside unit and open the door that covers the electrical connections. There will be a reset button on one of the temp switches that needs to be pushed. Now you have to see why it needs a reset.
Mar 21, 2014 | Heating & Cooling
Braemar heater
IS AIR INTAKE BLOCKED BY WALLS, FURNITURE, OR DUST AND DEBRIS?
Jul 21, 2013 | Heating & Cooling
Braemar spectrolink reset error 05
I had the fault code 05 (spectrolink controller) recently on a Braemer TG420 ducted heater. The heater would start and cut out on high temp as the room fan was not starting. I checked under the house and found the cable fitted to the return air thermistor had been chewed. I repaired the section of cabling and restarted the unit and it worked fine. Fault Code 05 is to do with the Thermistor in the return air duct.
Mar 27, 2012 | Heating & Cooling
Braemar spectrolink comfort controller keeps on asking to be reset works ok for a while then goes to reset
Look for the error code on the right hand side of the display above the zone section and below the actual temp displayed.... refer to:
http://www.braemar.com.au/PDFDocuments/Section8_ServiceTroubleshoot.pdf
Jul 21, 2010 | Honeywell Programmable Thermostat Heater
Cannot reset remote for braemar Ecostar Ducted heatin. Need to reset time and day. Would like to reset programmes also however when i hit the set button as per instructions in little book provided the...
The Braemar heater I have is wired directly to the control unit. The only way to reset the time is to turn of the heater for 5 minutes - the remote display should clear, and turn it back on (takes a minute for remote to come back on) the time will be flashing - use the Up and Down arrows to set the time, and SET button to set the day of week.
Jul 18, 2010 | Heating & Cooling
Braemar ducted heating wont switch on
If a used unit check under lid for a pressure hose no thicker than a pen , black or clear, look for splits or if disconnected reconnect
Jul 12, 2009 | Heating & Cooling
Spectronics Spectrolinker Model Xl-1500 Uv Crosslinker W/ Ac Logo
Top Spectronics Science & Laboratory Experts
S J Parkin
S J Parkin
ray gallant
Tom Chichester
Are you a Spectronics Science and Laboratory Expert? Answer questions, earn points and help others
