Question about Maytag Neptune MDE5500AY Electric Dryer
How to replace LDE8624ACE Dryer-Ele replace belt
I have a Kenmore Dryer it works but will not tumble i'ts a heavy dudy super capacity 70 series modle 110-64742400 you may need this to dwjr-ele-2406028-fm54
When the drum won't turn and the dryer is otherwise working it's usually due to a broken belt. Open the front of the machine to inspect the belt.
  1. Under the lint door remove 2 screws
  2. Use flathead screwdriver to pry up the top lid
  3. In the middle of the drum should appear a belt, if you see it, pull on it. If it is loose it's fallen off the belt tensioner. If there's no belt of if the belt breaks in your hands, you need a new belt.
A sample of the typical belt routing for your machine is available at the link below:
Kenmore Dryer Belt routing
Sep 08, 2011 | 2007 Toyota Camry
Have a Kenmore Elite Dryer that won't start. Mod 110.65962401 Ser MS0303258 Type DDOT-ELE-2406028-CV54
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Aug 22, 2011 | Kenmore Elite HE4 Electric Dryer
Kenmore electric dryer DWJR-ELE-2406028-FM54 Model 110.64632300. when we close the door the start button doesnt work until we close it 5 or 6 times. Help.
heatman101
Aug 01, 2011 | Kenmore 64722 Electric Dryer
DRYER WILL NOT START. WHIRLPOOL MODEL WED5821SWO SN MT3502452 TYPE DWSR-ELE-2406026-CV54
heatman101
Apr 20, 2011 | Whirlpool Dryers
Have a Whirlpool dryer type cwjr-ele-2306024-fm54 that just up & quit running. Put in new on-off switch, still won't run. Suggestions????
heatman101
Oct 12, 2010 | Dryers
My dryer works but does not heat
ihave a crosley ele. dryer works will not heat take out the drum or take the belt loss and it heats
Apr 08, 2010 | Kenmore Dryers
Why will my Maytag Dryer Model# LDE8624ACE not start?
check the switch. Wire may be out of its post or burnt.
Oct 07, 2009 | Dryers
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Dryer runs no heat
Sounds to me you either blew the fuse or tripped the circuit for the heating element. Try replacing the fuse or resetting the breaker before trying any repairs.
Jan 09, 2009 | Kenmore 64602 Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
