Question about Konica Minolta Office Equipment & Supplies
How do I separate scans if I put a group of single paged documents into the feeder?
  • Konica Minolta Master
  • 1,087 Answers
After you have chosen File / Print / Properties / and selected your options staple and quantity of copies - Click OK - when the menu returns you to the initial first print window, check the "Collate" option, this needs to be set as "Un ticked" - OK
If you need further help go to the makers website - support at http://www.konicaminolta.co.uk/business-solutions/support/bizhub-customers-support/faq.html
Posted on May 12, 2014
  • 16 Answers
SOURCE: scanning...
What do you mean scan? Is it from the printer to the computer? Or just plain copy? When you want to scan to the computer, you need a software that can scan multiple pages. HP's document feeder can copy and fax multiple pages, so if the software supports multiple pages scanning, then I'm sure it can.
Posted on Jan 05, 2008
marked
  • 6487 Answers
SOURCE: scanning
You can use Abbyy software (whether the freeby version included with a scanner or the stand alone version) is able to copy multiple pages in a document, whether sequential, subsequent or totally unrelated pages.
That software will help on yoru concern...
Hope that helps........
Posted on Jul 18, 2008
  • 1894 Answers
SOURCE: Problem with scanning both from the auto feeder and from scanner glass
this is what HP has to say
This document applies to all HP product models. Issue When the product is turned on or in the middle of an operation, an unexpected noise occurs, such as clicking, thumping, or grinding. Blinking lights and error codes might accompany the noise. NOTE: Noises can be caused by a number of things. This document focuses on isolating, identifying, and resolving known causes of product noises. Solution Noises are subjective and can be difficult to describe. Some noises are normal to the operation of the product and might include the following:
  • The product might make humming and buzzing sounds as the carriage moves around on the right or left side of the product while cleaning the ink cartridges. This is normal when a product is turned on, before and after printing, after a product has been on standby for some time, after replacing an ink cartridge, or in the middle of a large print job.
  • During a print job, the movement of rollers, gears, carriage, and paper (paper feed and ejection) creates some noise.
  • During a print job, if the product is printing in the fast or draft mode, the noise level might be higher than when using the best or normal mode.
  • At the end of the print job, a louder clicking noise occurs as the paper is pushed to the output tray.
  • At the end of a print job, a noise emanates from the left or right side of the product as the pens are capped. The product might try to do this a couple of times.
Abnormal noises are a symptom of a problem. The most accurate way to determine the origin of a noise is to isolate where it comes from and when it occurs. Use the following steps to try to isolate the noise issue. NOTE: Error codes might indicate the source of the noise. Make a note of any error code or blinking lights that appear. Step one: Check for loose or broken parts
  1. Raise the cover of the product.
  1. Check inside for loose or broken parts.
  2. If there are broken parts, the product needs to be serviced.
  3. Step two: Make sure that accessories are installed correctly
  1. Press the power button (c00636182.gif ) to turn off the product.
  2. Remove the power cord from the back of the product and unplug the power cord from the power source.
  3. Check any accessories (duplexer, envelope feeder, automatic document feeder (ADF)) to make sure each is installed and seated correctly.
  4. Plug the power cord into the back of the product and plug the power cord back into the power source.
  5. Press the power button (c00636182.gif ) to turn on the product.
  6. If the noise still persists, remove each accessory one at a time to try to determine if the noise is associated with a single accessory or a combination.
  7. If the noise stops when a specific accessory is removed, that part might need to be replaced. If possible, exchange the accessory with a known good one or a new one to determine if the noise is associated with the accessory. NOTE: If the product is fully functional with the accessory in place, the noise might be normal.
  8. If the noise persists, proceed to the next step.
Step three: Check connection with computer Turn off the computer to determine if the computer is the source of the noise. If the noise persists, proceed to Step four. If the noise stops when the computer is turned off, try to isolate any issues with connectivity:
  2. Disconnect the USB cable from the product.
  3. Unplug the power cord from the wall outlet and from the back of the product.
  4. Wait a couple of minutes to allow static to be discharged.
  5. Plug the power cord into the wall outlet and plug the power cord into the back of the product.
  6. Connect the product to a different USB port.
  7. Turn on the computer.
  8. Press the power button (c00636182.gif ) to turn on the product.
  9. If the noise persists, service the product.
Step four: Check for a paper jam Paper jams can prevent the internal components of the product from moving, which can create unusual noises.
  2. Disconnect the power cord from the back of the product.
  3. Remove the rear access door.
  4. Remove any paper that is inside the product by pulling it out through the rear access door and then securely replace the rear access door.
    1. If a paper jam cannot be removed from the back of the product, raise the product cover, carefully remove the paper jam from the front of the product, and then lower the cover.
    NOTE: Remove any paper jam carefully as it is possible to damage the product when removing a jam from the front of the product.
    1. Reconnect the power cord to the back of the product.
    2. Reload the paper in the paper tray.
    3. Press the power button (c00636182.gif ) to turn on the product.
    4. Try to print. If a jam is cleared and the product prints, but the noise persists, proceed to the next step.
    5. Step five: Make sure that the carriage moves freely
    2. Disconnect the power cord from the product.
    1. Make sure that the ink cartridges are locked into the carriage and have not come loose. Also make sure that there are no obstructions under or around the carriage to prevent it from moving.
    2. Close the product cover and reconnect the power cord.
    4. If the noise persists, proceed to the next step.
    5. Step six: Plug the product into a wall outlet
    If the product is plugged into an uninterruptible power supply, that source might make a beeping or whistling noise.
    1. Unplug the power cord from any power strips or surge protectors.
    2. Plug the power cord directly into a wall outlet instead.
    3. Press the power button (c00636182.gif ) to turn on the product. If the noise persists, proceed to the next step. If the noise stops when plugged directly into a wall outlet, the power strip or surge protector might not be allowing sufficient voltage to reach the product and might need to be replaced.
    Step eight: Service the product If you have completed all the steps listed above and are still experiencing a problem, service the product.
    Comments by scrodamoon in premium
    Posted on Aug 05, 2008
    SOURCE: Bad Scan Quality Using Brother MFC-7820N Document Feeder
    Look to the left side of the flatbed glass for a thin strip of glass by itself. When you scan from the glass, the document stays put and the sensor moves across the document. When you scan from the feeder, the sensor stays in that glass strip and the document moves across the sensor. See what I mean? I would check the small feeder glass for dirt or scratches from staples or other flotsam. Also not a bad idea to blow out the feeder path with some compressed air to ensure the documents is handled smoothly. Hope this helps!
    Posted on Nov 11, 2009
    bbaditz
    • 75 Answers
    SOURCE: Using automatic feeder to scan a multiple page doc into 1 PDF
    Yes you can scan up to 30 files in one pdf , and you have to put documents in auto feeder (face up) and from the pc, scan menu, scan to files, select destination and extension.
    That's all
    Posted on Mar 04, 2010
    How i can scan multiple pages in one file ??
    You need a document feeder. The printer has on or it doesn't. If it does you usually place the documents face up in the overhead feeder and the scan sensor in the printer will detect a load of paper in the feeder and choose to there instead of a single sheet under the glass.
    Apr 17, 2016 | Artronix Technology Artec ViewStation AS6E...
    Multiple pages feed when printing on hp 7410
    • If the automatic document feeder (ADF) does not pick up any pages at all, the rollers inside the automatic document feeder need to be cleaned.
    • If the automatic document feeder picks up multiple pages instead of single sheets, the separator pad inside the automatic document feeder needs to be cleaned.
    SolutionLoad one or two sheets of unused plain white full-size paper into the document feeder tray, and then press Start Copy Black to pull the pages through the automatic document feeder. The plain paper releases and absorbs residue from the rollers and separator pad.note.pngNOTE:If the automatic document feeder does not pick up the plain paper, try cleaning the front roller. Wipe the roller with a soft lint-free cloth dampened with distilled water. If the problem persists, or the automatic document feeder does not pick up the plain paper, clean the rollers and separator pad manually. Follow the procedures below to remove the face plate from the front of the automatic document feeder, access the pick assembly inside the automatic document feeder, clean the rollers or separator pad, and then reattach the face plate.
    Please Click on this link to know more in detail.
    Thanks
    Apr 01, 2012 | HP OfficeJet 7410 All-In-One InkJet...
    How do I scan more than one page at a time so I have a complete document of 6 pages instead of having 6 different document
    you either select add a page, or use the document feeder. The document feeder will try to scan all pages into one file.
    Mar 02, 2011 | Brother MFC 420CN All-In-One InkJet...
    Every time I scan documents on my 1235cn, it puts THREE black lines through my entire scan. I have cleaned the screen and it still isn't working. it only happens when the scan feeds through the top, not...
    You have something on the document feeder scan window. Open the top of the scanner like you are going to scan a book or something large. At one end you should see a section that is separate from the main glass. This section is where the document feeder scan the pages. Use a soft cloth with glass cleaner sprayed on the cloth to scrub the windows and the white strip above on the cover that you opened up. Here is the link to our tip page on Fixya with a picture of the scan window.
    http://www.fixya.com/support/r3639811-black_lines_faxes_or_copies
    This should get you back printing and scanning again.
    We hope this helps, if so please rate our solution.
    BuddyMc
    Dec 10, 2010 | Dell Multifunction Colour Laser (1235cn)...
    That's all
    Mar 04, 2010 | Canon PIXMA MX310 All-In-One Printer
    Sep 18, 2009 | Brother MFC-7820N Laser Printer
    When faxing does paper face uup or down
    You load the originals print side uo on the document feeder tray or print side down on the glass.
    To send a single page fax you can either load the original on document feeder tray or on the glass; to send a multi-page fax you must use the document feeder tray.
    The position of the paper is the same either you copy, fax or scan.
    All this is clearly explained in the user's manual, that you should read and you can download from HP support pages for you printer:
    Aug 09, 2009 | HP Officejet 6310 All-In-One InkJet...
    Brother MFC420cn Document Scanning
    Yes, you save it to a pdf file. Configure scan to file to save as pdf, and it will create a single file
    Apr 30, 2009 | Brother MFC 420CN All-In-One InkJet...
    My Canon MF3240 picks up too much paper and causes a paper jam every time I print.
    Aug 05, 2008 | Office Equipment & Supplies
    Scanning documents
    Has the machine got a doc feeder if so select twain scanning select doc feeder and the scan it will scan all pages in the feeder and then you should be able to save as one file.
    Thanks J
    Jan 24, 2008 | Sharp AL-1551 Laser Printer
    51 people viewed this question
    Top Konica Minolta Office Equipment & Supplies Experts
    Norman  J Weimar Jr
    Norman J Weimar Jr
    Adorjani Laszlo
    carpediemweb
    Level 1 Expert
    Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
