Question about Canon MX300 Office All-In-One Printer
How to 'realign head'? - Canon MX300 Office All-In-One Printer
Printing is not good
Assuming you have ink, you need to clean and/or realign the print heads.
Go to properties on the software for the printer and look for maintenance cleaning and realignment should be in there
Nov 21, 2016 | Office Equipment & Supplies
Keep getting blue lines through the image. i have cleaned heads and realigned and nozzle checked several times
Hey dude,
It's the problem with the printer head.Replacing cartridges and allignment won't help.Try to replace the printer head.it's the only possiblity.
Mar 06, 2011 | Epson Stylus Photo 1290 InkJet Printer
Toner cartiridges are full but pages are printing blank
Turn your printer off. Disconnect from your computer by disconnection of cable, from the back of the printer. Unplug your printer from the wall.
Remove your print cartridges and gently wipe off the connections (copper or brass colored) with a dry lint-free cloth. Check to see if the bottom of the ink gates (holes where ink comes out) are clogged. Wipe gently with an almost dry but damp cloth, once or twice. Ink will continually come out, so only do this once or twice.
Plug printer back into the wall, connect power cable to printer. Turn printer on.
HP Photosmart will run through a series of checklists. First, it will ask if you would like to "realign" the printer heads. Press "enter" or "yes" and allow heads to realign. If you always have your printer and computer on, this realignment never happens, therefore the heads where the ink is dispersed from the modules will get clogged, and ink will never come out.
Nov 15, 2010 | HP Photosmart C6280 Printer
There are horizontal lines on the print. Even after realigning the print head it is still coming. What do i do?
if it's an inkjet printer, the print head is surely dirty. try wiping the bottom sides of the print head gently with a dry piece of cloth without touching the actual print nozzles, which can easily be damaged.
Sep 27, 2010 | Computers & Internet
Technics sl 1200 MK2 WEAK SOUND
Regarding the poor sound quality (and possibly the skipping):
check the needle condition, see if exchanging it with a needle (or the entire pickup head) from a working turntable does any good.
Check the pickup connection pins (contacts on the pickup head and on the end of the wires coming through the arm from the unit), see if there is any dirt or oxydation and clean the contacts if necessary, also check for any damage to the wires.
As for the skipping - a heavily worn needle may affect the sound quality and cause skipping as well - if cahnging the needle (or the pickup head) doesn't make a change, try to realign the weight on the tone arm so that the pickup head will become a bit heavier, this could help somewhat (before you actually try to realign the weight, try to put a small coin or a small weight of some kind on the pickup head while it is playing a record, if the skipping goes away, you need to realign the tone arm weight).
This could also be a problem with the tone arm lifting mechanism (may be obstructed by something or damaged so it won't let the tone arm sit properly onto the record and "grab" the groove).
I just mentioned a few things you might want to check, but don't take anything for granted, the problem may as well be elsewhere in the unit.
regards
Triarcuate
Sep 22, 2009 | Technics SL-1200 Turntable
Epson Stylus r220 prints with white lines... i installed a CIS and it worked fine for about 6 months, now i'm getting prints with white lines (or fine spots) i tried nozzle check, which comes out good......
Nozzle check must perfect for perfect output. There are tranversal lines at vertical straight lines that represent same point of head micro piezo. If tranversal lines no clog at all, but vertical straight lines not perfectly straight, the result not good (like horizontal white banding). Check it? Head aligment is for vertical banding. If your result is horizontal banding, you don't need to realign head. It's caused by some residual at the output of head sprayer. So, the spray of ink not straight to paper. Try to print with photo/best photo.
Jul 18, 2009 | Epson Stylus Photo R220 InkJet Printer
How to realign printer setting
Head alignment? Do head alignment prosedure, check the the thinnest gap at print out, enter number, check again. Repeat until perfect. Or you can print without highspeed option.
Jun 24, 2009 | Epson Office Equipment & Supplies
Getting a white border on printable cds
Once you press print in printcd yyou can adjust the print position, however if you really want the app I have 4 versions, v1.4, v1.5 & v1.6.
Let me know which one you want and I'll email it to you in a RAR file.
pippincp@msn.com
May 17, 2009 | Epson Stylus Photo RX700 All-In-One InkJet...
REPAIR FLOPPY DRIVE
There are a few different applications that can aid you in doing this. Here is one. http://www.accurite.com/AAD.html Most often than not, the heads will not be realigned properly with such software, and the cost of purchasing the mechanical tools to do it manually and the time and energy it takes outweigh the cost of just buying a new drive. If you are having read/write problems, and an inexpensive head cleaner (http://pc-extras.com/prods/cl35ck.html) does not solve the problem, I would recommend replacement.
Nov 22, 2006 | Teac Floppy Drive FD-235HF Internal Floppy...
Canon MX300 Office All-In-One Printer Logo
27 people viewed this question
old marine
old marine
