Question about Paragon Kitchen Appliances - Others
What is kernel made of - Paragon Kitchen Appliances - Others
LG K5 phone DemiGod Kernel Crash Handler Kernel Panic
This thread should help you ...
https://forum.xda-developers.com/lg-g3/help/demigod-crash-handler-kernel-crash-t3137380
Apr 02, 2018 | LG Computers & Internet
Fix kernel dell xp
There are several different ways that kernel.dll errors can show up on your computer. Here are some of the more common ways that you might see kernel.dll errors:
  • "Kernel.dll Not Found"
  • "This application failed to start because kernel.dll was not found. Re-installing the application may fix this problem."
  • "Cannot find [PATH]\kernel.dll"
  • "The file kernel.dll is missing."
  • "Cannot start [APPLICATION]. A required component is missing: kernel.dll. Please install [APPLICATION] again."
Kernel.dll error messages might appear while using or installing certain programs, when Windows starts or shuts down, or maybe even during a Windows installation.
The context of the kernel.dll error is an important piece of information that will be helpful while solving the problem.
Cause of Kernell.dll Errors
Kernel.dll errors are caused by situations that lead to the removal or corruption of the kernel DLL file.
In some cases, kernel.dll errors could indicate a registry problem, a virus or malware issue or even a hardware failure.
How to Fix Kernel.dll Errors
Important: Do not download kernel.dll from a "DLL download" website. There are many reasons why downloading a DLL file is a bad idea. If you need a copy of kernel.dll, it's best to obtain it from its original, legitimate source.
Note: Start Windows in Safe Mode to complete any of the following steps if you're unable to access Windows normally due to the kernel.dll error.
  1. Restore kernel.dll from the Recycle Bin. The easiest possible cause of a "missing" kernel.dll file is that you've mistakenly deleted it.
    If you suspect that you've accidentally deleted kernel.dll but you've already emptied the Recycle Bin, you may be able to recover kernel.dll with a free file recovery program.
    Important: Recovering a deleted copy of kernel.dll with a file recovery program is a smart idea only if you're confident you've deleted the file yourself and that it was working properly before you did that.
  2. Run a virus/malware scan of your entire system. Some kernel.dll errors could be related to a virus or other malware infection on your computer that has damaged the DLL file. It's even possible that the kernel.dll error you're seeing is related to a hostile program that's masquerading as the file.
  3. Use System Restore to undo recent system changes. If you suspect that the kernel.dll error was caused by a change made to an important file or configuration, a System Restore could solve the problem.
  4. Reinstall the program that uses the kernel.dll file. If the kernel.dll DLL error occurs when you use a particular program, reinstalling the program should replace the file.
    Important: Try your best to complete this step. Reinstalling the program that provides the kernel.dll file, if possible, is a likely solution to this DLL error.
  5. Update the drivers for hardware devices that might be related to kernel.dll. If, for example, you're receiving a "The file kernel.dll is missing" error when you play a 3D video game, try updating the drivers for your video card.
    Note: The kernel.dll file may or may not be related to video cards - this was just an example. The key here is to pay very close attention to the context of the error and troubleshoot accordingly.
  6. Roll back a driver to a previously installed version if kernel.dll errors began after updating a particular hardware device's driver.
  7. Run the sfc /scannow System File Checker command to replace a missing or corrupt copy of the kernel.dll file. If this DLL file is provided my Microsoft, the System File Checker tool should restore it.
  8. Install any available Windows updates. Many service packs and other patches replace or update some of the hundreds of Microsoft distributed DLL files on your computer. The kernel.dll file could be included in one of those updates.
  9. Test your memory and then test your hard drive. I've left the majority of hardware troubleshooting to the last step, but your computer's memory and hard drive are easy to test and are the most likely components that might cause kernel.dll errors as they fail.
    If the hardware fails any of your tests, replace the memory or replace the hard drive as soon as possible.
  10. Repair your installation of Windows. If the individual kernel.dll file troubleshooting advice above is unsuccessful, performing a startup repair or repair installation should restore all Windows DLL files to their working versions.
  11. Use a free registry cleaner to repair kernel.dll related issues in the registry. A free registry cleaner program may be able to help by removing invalid kernel.dll registry entries that might be causing the DLL error.
    Important: I rarely recommend the use of registry cleaners. I've included the option here as a "last resort" attempt before the destructive step coming up next.
  12. Perform a clean installation of Windows. A clean install of Windows will erase everything from the hard drive and install a fresh copy of Windows. If none of the steps above correct the kernel.dll error, this should be your next course of action.
    Important: All the information on your hard drive will be erased during a clean install. Make sure you've made the best attempt possible to fix the kernel.dll error using a troubleshooting step prior to this one.
  13. Troubleshoot for a hardware problem if any kernel.dll errors persist. After a clean install of Windows, your DLL problem can only be hardware related.
Applies To
The kernel.dll error message could apply to any program or system that might utilize the file on any of Microsoft's operating systems including Windows 8, Windows 7, Windows Vista, Windows XP, and Windows 2000.
Sep 12, 2013 | Microsoft Windows XP Professional for PC
WHAT IS REENTRANT KERNEL?
A reentrant kernel enables processes to give away the CPU while in kernel mode, not hindering other processes from entering kernel modes.
If the kernel is not reentrant, a process can only be suspended while it is in user mode(to be more precise, it could also suspend the process in kernel mode, but would block kernel mode execution on all other processes).
The reason for this is that all kernel threads share the same memory and corruption would occur if execution would jump between them arbitrarily.
That is, if the kernel is reentrant, several processes may be executed in the kernel mode at the same time when the process is suspended.
A typical use case is I/O wait.
The process wants to read a file.
>>When the kernel is not reentrant :
It calls a kernel function for this to stop the inside the kernel function. Disk controller is asked for the data. Getting the data will take some time and the function will block during that time.
With reentrant kernel,the scheduler will assign the CPU another process until the interrupt from the disk controller indicates that the data is available and our thread can be resumed.
Hence with this concept, throughput of the system increases rapidly.
A kernel that is not entrant needs to use a lock to makee sure that no two processes are executing in kernel mode at the same time.
Oct 14, 2010 | Computers & Internet
Kernal 1.24 wont load on my r4ds card
Don't bother with Kernel v1.24 i use kernel v1.18 downlad from http://www.r4ds.cn/download/r4ds.html and click on the "R4 V1.18 kernel (English/French/Korean)" un compress with Winrar and put on SD/TF card (delete any previous kernels you may have.
Will also need the "Moonshell 1.71 for R4" on same page as kernel v1.18 just scroll down a little lower.
Get a free account on romulation.net and download whatever games you want
Happy playing.
Nov 14, 2008 | Video Game Consoles & Games
Kernel Cardbus card (YENTA socket) problems
Dear
With many distributions with the later 2.4.x kernels (>2.4.15 I think), the PCMCIA cardbus services has been merged into the kernel with the YENTA socket. While this works with most laptops it also have problems with many others. Usually, the kernel messages will state that the card is detected correctly but then the ard will not respond to any ping messages in or out.
If your laptop does have this problem then you will need the older modular cardbus services through the PCMCIA-CS package. The information and source can be found at the Linux PCMCIA Information page. The solution for this is not for the faint of heart. It requires a recompilation of the kernel in order to disable the kernel PCMCIA implementation and install the PCMCIA-cs as a module. Again, the best source for Linux information such as kernel compilation can be found at the Linux Howtos. Also, Linux on Laptops provides many useful information on installing Linux on laptops
As of 2006/2007, the Yenta socket in the 2.6 series kernel is quite stable. It should now works properly with most if not all previously unsupported laptops.
Screen garbles after changing between X Windows and console
This is a relatively common problem with Linux on laptops. In the kernel call line in Grub or LILO, make sure that the vga=7xx line is included so that the kernel locks to a particular native LCD resolution. Some common vga= values for 16-bit color are:
800x600 vga=788
1024x768 vga=791
1280x1024 vga=794
Oct 19, 2008 | Computers & Internet
Turn the xbox on and where the light is green there is only one red light and it says on the screen system error
An original Xbox? On the error screen there should be a number. Which is it?
2 - bootldr - Eeprom check failed
4 - bootldr - Ram check failed
5 - kernel - HDD not locked
6 - kernel - Cannot unlock HDD
7 - kernel - HDD timeout
8 - kernel - No HDD found
9 - kernel - HDD parameters (
10 - kernel - DVD timeout
Actually its almost the same as error 6/7/8.
11 - kernel - No DVD Found
12 - kernel - DVD parameters (PIO/DMA)
13 - kernel - Dashboard launch fail
14 - dashboard - Error loading dashboard
16 - dashboard - Clock cannot be set.
20 - kernel - The dashboard was attempted to load and failed
21 - anywhere -
Some of these are relatively simple to fix. Some are nightmarish. Let me know which it is and maybe I can help you.
Jul 10, 2008 | Video Game Consoles & Games
Unkown SCSI Problem
Hi Fatoil ,
Have you tried another SCSI port , another SCSI card , another SCSI drive , swopping if it is card problem or drive or both problem ?.
If you have a spare SCSI hd , plug it in to same port and see if it works . Swop to another port and see if the spare SCSI hd works. Swop to another SCSI card and see if spare SCSI hd works.
All this elimination will narrow down the problem .
SCSI cards are not expensive ,.
old working SCSI hds don't cost you anything if you have them.
Sending out the server for servicing will cost you.
I presume you don't have a maintenance contract for this server .
If you have , get them down to settle it .
If you don't , after you settle this matter , make sure you get a maintenance contract for all your critical servers / equipment.
Maint Contracts seem expensive when nothing breaks down. However , when they do , it makes every worry go away.
Good luck,
David
May 26, 2008 | HP CC3310 (a9863a) Server
JFS224 change drive order
You need to get into bios to change the boot order. You can usually get into bios by tapping F12, esc, or whatever depending on who wrote your bios. Once you get into bios, you should see something like change boot order somewhere. If you don't know where it is then just keep scanning each page and you will find it. It will be called something "boot order". Use the directions on screen to change it to whatever drive you desire and you should be good to go. If you can't do it then write back and let me know.
Feb 01, 2008 | Chaparral Technologies CHAPARRAL - JFS224
Kitchen Appliances - Others Logo
32 people viewed this question
Top Paragon Kitchen Appliances - Others Experts
Angel Joseph Jr.
Angel Joseph Jr.
Irene Tulloch
Are you a Paragon Kitchen Appliances - Other Expert? Answer questions, earn points and help others
