Question about Black & Decker 19" Electric Lawnhog Mulching Mower
How to adjust the height of the mower - Black & Decker 19" Electric Lawnhog Mulching Mower
  • 2,321 Answers
If you mower does not have adjusters on the wheels then there should be three holes where the wheels are bolted onto the base. to adjust these you have to take each wheel off and bolt them in the same hole for each wheel. The top holes are the lowest the mower can be set the middle ones bring it up part way and the bottom hole is the highest setting. You should set the mower to cut at least two and a half inches above the ground. The center holes should be good.
Posted on Jun 28, 2016
Height adjustment
Mowers I presume...?
As a child...
I remember the reel (push - manual) movers
had a combination of wheel and roller height
where adjusted.
As these many decades have shot by like a
time machine scene... mowers became 4 wheelers...
self propelled and even battery powered and
Self propelled...
See:
CONSUMER REPORTS recommendation below
May 11, 2017 | Garden
How to level the mowing deck on 2002 John Deere (Scotts) 42 " mower. Mower deck drags on right side. Mower height adjuster doesnt work seems jammed.
Have a look underneath while someone operates the height adjustment. There's probably a link arm come off which does deck height. Go to google images for this machine, type height adjustment and look at the pictures if you don't have a handbook. Google JD handbooks and see if you can find a free download.
Aug 13, 2016 | John Deere Garden
How do I adjust front wheel height?
Are we talking tractors or mowers here? If its a mower we are talking about there should be adjusters on each wheel. Possibly three holes that you bolt the wheels on. Each wheel should be in the same hole as each other wheel.
Jun 04, 2015 | Garden
I need to adjust my scag mower deck
The mower deck can be adjusted from a height of 1.0 inch to 6.0 inches at 1/4-inch intervals. To adjust the cutting height:
1. Disengage the power to the cutter blades.
2. Push the cutting height adjustment foot pedal all the way forward using your right foot until it locks in place
3. Insert the lanyard pin into the cutting height index at the desired cutting height. Push forward on the deck lift foot lever, hold in place and pull back on the deck release lever. Slowly release the foot pedal. A deck height decal is located on the cutting height index as an aid in adjusting the deck to the desired height.
Aug 18, 2013 | Scag STT61V-27CH Hydrostatic, Gas Turf...
Front wheels on manual mower lock when pushing for awhile.
1 Locate the height adjustment lever on the inside of the left rear wheel.
2 Kneel next to the mower and push the left height adjustment lever toward the center of the mower. This will unlock the lever from the locking pin on which the height is currently set.
Read more: How do I Adjust the Height on a Great States Reel Mower? ' eHow.com http://www.ehow.com/how_6834215_do-great-states-reel-mower_.html#ixzz21NOr1e8d
3Rotate the lever toward the front of the mower to lower the height of cut, or toward the rear of the mower to raise the height of cut.
4 Release the lever over the locking pin closest to the desired height of cut.
5 Repeat these steps with the adjustment lever on the right-side rear wheel. Be sure to set the right wheel lever to the same position as the left-side wheel's lever for an even cut.
Jul 22, 2012 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
How to adjust grass cutting height on
some old mowers you need to unbolt each wheel and move them to a different hole
Apr 21, 2012 | Garden
The hover fly mower sits on the grass, being that there are no height settings, it cuts quite low. Are there way's to make the mower sit higher off the ground in order to cut the grass at a higher...
Usually all mowers have height adjustments of some kind. Look around your front and rear wheels, if you have a number of holes drilled into the deck ,these are your adjustment holes.You would unbolt the wheels and put them at the height you would like.
If as you say there is no adjustment, I would say buy new wheels that are an inch or more bigger than your present wheels and install them in place of your old wheels. If you go to any local dealer they will be able to help you with your problem.
Jul 03, 2011 | Garden
How do you set the mower blade height on a riding mower. The mower deck is set by the height adjuster but how about the blade
The blade height is not adjustable on any of the tractors I have worked on or owned. The blade seats against a shoulder on a spindle and held in place by a nut. Sometimes replacement blades are not shaped the same as the original and changes the blade cuttnig height but other than in those circustances there is no adjustment.
Jun 18, 2010 | Garden
John Deere 185 deck height adjustment
having a problem with dive belt being hit by the mower deck 185 john deere suggestions !!
May 08, 2010 | John Deere 420,1020,2010,2020,2510,2520...
Height adjustment on my lawn mower
have the mower on a flat suface and adjust for the height you need on all four wheels then raise the rear of the mower by one hole to give clearance and reduce the loading on the blade
Sep 12, 2009 | Garden
Black & Decker 19" Electric Lawnhog Mulching Mower Logo
Top Black & Decker Garden Experts
Jim Parker
Jim Parker
Nick Olsen
Simon Elder
Level 1 Expert
Are you a Black & Decker Garden Expert? Answer questions, earn points and help others
