Question about Ironman Exercise & Fitness
What is a SI2 error message - Ironman Exercise & Fitness
I just bought a used Invacare TDX SI2 powerchair. The batteries hold only about a mile's worth of power; and now the charger is not working. No lights when plugged into the wall.
If the batteries truly are new, it could be since the charger was defective it wasn't charging the batteries properly. You can buy a three stage charger designed for gel batteries for around $30 bucks on Amazon. If it is the batteries I am afraid they are quite a bit more for replacement than the charger itself. Good Luck!
Dec 04, 2016 | Cars & Trucks
Why does my ironman 220t treadmill say si2 and give off a burnt scent after replacing a motor control board?
If you wish to get some details About treadmill repair and service; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Sep 12, 2016 | Ironman 220t Motor Control Board Part...
Error code 1 and 3 on my Precor 9.21s treadmill?
Precor Error 01, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicate an upper PCA problem when they are consistently displayed. Failures causing this error message to be displayed are rare.
Corrective Action If the error message is consistently displayed when the unit is powered up, the upper PCA should be replaced. It is possible to see this message displayed intermittently due to external causes. If the units A.C. input significantly dips during the power up test sequence the test could fail resulting in this message being displayed. Treadmills operating on non-dedicated A.C. circuits may see this message displayed on an intermittent basis. Precor Error Code 01
Precor Error 03, Memory, RAM, EEPROM Test Error Probable Cause This error message almost always indicates an upper PCA problem when it is consistently displayed. Failures causing this error message to be displayed are rare.
Precor Error Code 03 E03 EEPROM Test Error
Mar 27, 2013 | Precor 9.21s Treadmill Display Console...
Cardiozone Club HR T Error Code SI2
see the details and fix it. God bless you
Error - "SI2 At Power Up"
Symptom:
Indicates the OVP (Over Voltage Protection) circuit on the controller is active and belt will not move.
Solutions:
  • Check for RAIL and LVS LED's to be lit.
    • RAIL and LVS ok? Replace F2 fuse
    • RAIL not lit, but LVS ok? Replace F1 fuse
Nov 17, 2012 | Exercise & Fitness
HOW TO FIX CAMERA FAILED ERROR MESSAGE.HANDLER.HANDLE MESSAGE(-1)
ERROR HANDLER.HANDLE MESSAGE(-1)...CAMERA GALAXY YOUNG......!
Sep 12, 2012 | Samsung Galaxy Y
The treadmill shuts down and the screan says speed error 12
1) Error - "SI2 At Power Up"
Symptom:
2)
An SI-2 is basically a code that causes the treadmill to shut down. This is generally caused by a fluctuation in the treadmill
Oct 20, 2011 | Exercise & Fitness
Smooth fitness treadmill display after pushing the start button appears to be locked into the words S I 2 for sports interval which is number 2 on the menu and I do not know how to reprogram or reboot
Dear Sir:
I will try to help you, you must need some basic tools: screwdriver, hexagonals, Dvom(DigitalVoltmeter):
Here some soslutions. use your skill+patience+carefully:
SI2 At Power Up Error - "SI2 At Power Up"
Symptom:
Solutions:
Oct 19, 2011 | Exercise & Fitness
Led display stuck on si2
Dear Sir:
I will try to help you, right now.
You must use the some basic tools: Screwdriver, hexagonals, lubricants.
1) See this video and fix it:
http://www.youtube.com/watch?v=E-q-uS4t6so
2)After adjustment, use lubricant for to clean contact and clean ( Radio Schack) has many alternatives for them.
3) If the problem continues, you can replace the Reed Swith.
4) Finally see the power supply in the control board for display, and see if the +5Vdc is o.k, and check the fuse or breaker associates with the power supply, here some vide how to test a fuse.
http://www.youtube.com/watch?v=AFuRo2zHpCg&feature=related
If you need further assistance, please reach me, sincerely. God bless you.
E.CUADRA
MANAGUA, NICARAGUA. C.A.
Minolta 2200 service code 16
(TABP0902037EN00) - magicolor 2200 DeskLaser - What are the steps to fix a service call 16H transfer belt rotate error on a magicolor 2200 series? (TAUS0805552EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'ACC_Getstatusr EC;Code=__D, Resetting ACC to Initial State' (q0601101) (TAUS0805008EN00) - magicolor 2 + - Installing CrownNet code on the Crown monochrome printer (q0499042) (TAUS0803976EN00) - magicolor 2200 + - Flashing System Code to DeskLaser to Correct 'Starting System Firmware Image' Message (q0202107) (TAUS0806277EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Missing' (q0800700) (TAUS0806280EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Missing' (q0800703) (TAUS0806281EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Fuser Missing (q0800704) (TAUS0806282EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Missing' (q0800705) (TAUS0806283EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Low' (q0800706) (TAUS0806284EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Toner Empty' (q0800707) (TAUS0806286EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Fuser Unit' (q0800709) (TAUS0806287EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Transfer Belt Life Low' (q0800710) (TAUS0806288EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Transfer Belt' (q0800711) (TAUS0806289EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'OPC Drum Life Low' (q0800712) (TAUS0806290EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace OPC Drum' (q0800713) (TAUS0806292EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Waste Toner' (q0800715) (TAUS0806293EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Oil Roller Life Low' (q0800716) (TAUS0806294EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Replace Oil Roller' (q0800717) (TAUS0806295EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Input Tray' (q0800719) (TAUS0806296EN00) - magicolor 2200 + - Clearing MC 2200/MC 2210 Status Messages or Error Codes 'Put Media in Upper Bin' (q0800720)
Dec 11, 2010 | Minolta magicolor 2200 DeskLaser Printer
Could not create this file.Shall I try again?
Click Start
Click Run
Type CMD and press ENTER.
Enter CD \ and press ENTER.
Enter CD "program files" and press ENTER.
Do you get an error-message?
If not, that's good. If so, what's the error-message?
Enter CD "PrintMaster 2.0 Gold" and press ENTER.
Enter CD "Components" and press ENTER.
Enter CD "Clip Art" and press ENTER.
Enter CD "Travel" and press ENTER.
Enter CD "Europe" and press ENTER.
Enter ECHO Y > "Rusty Fence.jpg" and press ENTER.
Jan 04, 2010 | Encore Computers & Internet
Exercise & Fitness Logo
155 people viewed this question
Top Ironman Exercise & Fitness Experts
Matt Olenzek
Matt Olenzek
Jim Dowell
Techmotionusa.com
Techmotionusa.com
Are you an Ironman Exercise and Fitnes Expert? Answer questions, earn points and help others
