Question about Lexmark X2470 All-In-One InkJet Printer
Can't see Paper jam
My lexmark x2400 has a paper jam. I can't see the jamed paper, how do I fix this?
  • 147 Answers
Open the top cover to see the jammed paper. If u wont see the paper then you have to open the cabinet of the printer . After opening remove the paper
cheers
Posted on Jun 23, 2009
Lexmark printer 3600-4600, after paper jamed and took paper out . but it still shows " paper jam " all the time . And printer seems not remove "paper jam" away even reconect box jection behind ...etc....
check that their is no pieces of paper broken off in machine and that all the paper sensors are not still jammed and moving freely then switch off machine for at least 30sec then switch on should work if not check again and make certain all covers and doors are properly closed
Oct 13, 2010 | Lexmark X2600 InkJet Printer
My canon D761 copier does not feed paper. message says "paper jamed" but there isno paper jamed.How do I fix this
paper jam lit when jammed or feeding does not occurs, try cleaning the feed rollers and look if the feed rollers rotates when you copy
Mar 19, 2010 | Canon imageCLASS D761 Copier
The problem is a paper jam
If it says there is a paper jam and there is no paper jamed. Then try opening and closing any compartments on the printer, this resets faults like a "paper Jam".
Sep 22, 2009 | Lexmark X5470 All-In-One InkJet Printer
PAPER JAM IN MY LEMAX X4650
Have you really checked the printer, there may be a small piece of paper jamed inside the printer, this is a common fault and common fix for most printers.
Jun 03, 2009 | Lexmark X4650 InkJet Printer
Lexmark x342n all-in-one printer paper jam
Is any part of the page imaged?
What is happening is that a paper sensor is either hung or jamed so that the sensor is incorectly reporting an error .
I would remove the cartridge and using a flash light search for any scrap of paper that may be in the paper path. If you can't find any, I would next looked for a sensor flag to see if it is jammed out of position.
Of course, you could always call a service tech or even better submit this question to Lexmark Technical Support for more in depth assistance.
May 31, 2009 | Lexmark X342n All-In-One Laser Printer
Frequent jam in Lexmark E232
This can happen a lot if you're using very light weight paper.  Also, if the paper is not flat it can jam up too.  Best thing you can do is get yourself some higher quality paper and keep it in a air tight tub after you open it.
Nov 22, 2008 | Lexmark E232 Laser Printer
On the 5400 lexmark if a paper jam occured, how do you fix it,do you have to unscrew the back in order to get the paper that has jamed?
No just pop of the back tray and you should have access to it from there. Make sure though to unplug your Printer and your printer need you to reset it.
plz rate thank you
Sep 07, 2008 | Lexmark Office Equipment & Supplies
Cannot print anything. Paper goes in halfway and then says 'paper jam'. Checked back - no jammed paper. Keeps on doing this. Have been in to cancel print but keeps saying paper jam. Have tried a print test...
Dear Customer,
you ahve to use batter quility papers for prints,
cause when paper fixed up your printer says its jammed but as realesed its says printing but when ALL THINGS DOIN VERY FAST JAMMING & PRINTING ITS SEEMS LIKE PAPER JAMED ALSO SAW YOU AS PAPER JAMED,
so try to check your inner cartrige,ink & paper rolls,batter quility papers you ahve to use,
THNX
May 18, 2008 | HP Computers & Internet
Paper jam
hi this is some small pieces of paper which had gone inside in ur printer when u prints. this one have to contact printer engineer to clean the printer
Mar 02, 2008 | Lexmark X8350 Print, Scan, Copy and Fax...
Clear paper jam
Sometimes there is little bits of paper stuck inside a sensor causing the printer to detect a jam. Use an air duster can to and shoot some air at all the sensors. The sensors look like little plastic fingers that get pushed down when paper moves over them.
Jan 02, 2008 | Lexmark X5150 All-In-One InkJet Printer
Lexmark X2470 All-In-One InkJet Printer Logo
301 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
