Question about Google Chrome
How do i fix this error code: ERR_WINSOCK_UNEXPECTED_WRITTEN_BYTES
When i try to access certain websites
2 Suggested Answers
  • 47 Answers
SOURCE: I can't access certain websites,this
Hi Bluedevil588,
Dont worry no problem in your computer, this problem is usually from your internet connection, try checking your router or call you internet provider.
Hope this helps ^ ^,
Webby101
Posted on Sep 16, 2011
Testimonial: "ok thanks :) I did contact my internet provider :) and they took care of it :)"
Tip
Network sharing issue
In Multiwindow platform normal,sharing folder and printer is always big issue.
Error type:
ex:
\\server is not accessible. You might not have permission to use this network resource. Contact the administrator of this server to find out if you have access permissions. The network path was not found.
This method can be used for many network error
Solution:
1)Fixing the winsock and tcp/ip .
On the run command :
for winsock run:
netsh winsock reset
to reset tcp/ip run:
netsh int ip reset c:\resetlog.txt
or
run winsock fix from www.snapfiles.com/get/winsockxpfix.html
2) Enable NetBIOS over TCP/IP
open up Network Connections, under Control Panel.
Right click on your network adapter and click on Properties.
Click on Internet Protocol (TCP/IP), then click on Properties.
Click on Advanced, and click on the WINS tab.
Even if it is set to Default, set the radio button to Enable NetBIOS over TCP/IP.
Press OK on each screen until everything’s closed.
Go back to the client machine and try again.
You should be able to connect!
3)dnsflush
Open Network Connection
Check box File & Printer sharing > ok
Disabled NIC
Enabled it back
Open CMD > ipconfig /flushdns
ipconfig/registerdns
4) Make sure windows firewall and antivirus firewall turn off
on Apr 21, 2010 | Computers & Internet
!!! WARNING: The switch is not usable !!! 3560-24PS
There is a possibility of IOSĀ® corruption, so better check on that before using warranty, RMA or dumpster/recycling
Error Message SW_VLAN-4-IFS_FAILURE: VLAN manager encountered file operation error: call = [chars] / code = [dec] ([chars]) / bytes transferred = [dec].
Explanation This message means that the VLAN manager received an unexpected error return from an IOS file system (IFS) call while reading the VLAN database. The first [chars] is the IFS operation that failed. The first [dec] is the error code, the second [chars] is the textual interpretation of the error code, and the second [dec] is the number of bytes transferred.
Recommended Action Copy the error message exactly as it appears on the console or in the system log, call your Cisco technical support representative, and provide the representative with the gathered information.
Mar 21, 2013 | Cisco Catalyst 3560-24PS Switch
Minolta Dimage S414 does not turn on, displays err message then shuts off? No error code, just err. Been in storage four years, probably stuck lens or something?
Go to this website and try the fixes listed....one of them may "kickstart" your camera.
http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 29, 2011 | Konica Minolta DiMAGE S414 Digital Camera
Hello. I have a unique problem. I have a Windows Vista home premium system that can ping to my gateway and other systems on the local network but can not ping beyond my gateway and can not browse the...
If you can PING your gateway, then there was no need for the 'WINSOCK FIX'.
Access the web-server "inside" the router, and look at the table of DHCP clients -- confirm that your computer's "wired" and "wireless" connections are listed, and that they have been assigned IP-addresses.
The router should have its own 'PING' interface, so try PING-ing to 'ns.watson.ibm.com' -- you should get output like:
Pinging ns.watson.ibm.com [129.34.20.80] with 32 bytes of data:
Reply from 129.34.20.80: bytes=32 time=126ms TTL=241
Reply from 129.34.20.80: bytes=32 time=103ms TTL=241
Reply from 129.34.20.80: bytes=32 time=91ms TTL=241
Reply from 129.34.20.80: bytes=32 time=93ms TTL=241
if your router has an Internet connection.
Oct 23, 2010 | HP Computers & Internet
Webpage error details User Agent: Mozilla/4.0 (compatible; MSIE 8.0; Windows NT 6.1; Trident/4.0; GTB6.4; SLCC2; .NET CLR 2.0.50727; .NET CLR 3.5.30729; .NET CLR 3.0.30729; Media Center PC 6.0; .NET CLR...
If you're having trouble with a website you'll need to get in contact with that website's webmaster. If the error is related to using a web page within a program, you'll need to contact the developer of that program.
We have no control over another website's content or scripts, including that which may cause errors and error messages.
Mar 29, 2010 | Microsoft Internet Explorer 8
Flash player says ''unexpector error: code ad_Billboard
Try re installing your player. It can be the the files you are trying to play does not support by your existing version.
Jul 19, 2009 | Computers & Internet
I CANT ACCESS THE ROUTER'S WEBSITE
if you are not able to access a router page
try to reset your router and then try to access the router page .
if it doesnot work then try to reset winsock
start >run>cmd>netsh>winsock reset catalog
then see it work or not
Jul 07, 2009 | Belkin Wireless Pre-N (F5D8230-4) Router...
I cant open anything it says there is error on page, plesae help. error HM undefined error Expected J
Cannot access or browse websites after being connected to Internet.
This problem is only due to the corrupted Winsock2. Solution is very simple ...just type a command at the command prompt
Type cmd in the RUN
type netsh then type winsock and then reset command at the command prompt
Restart your computer and Winsock2 shall be fixed.
Nov 30, 2008 | Computers & Internet
Google Chrome Logo
198 people viewed this question
Top Google Computers & Internet Experts
Sunil Pratap Singh
Sunil Pratap Singh
David Payne
David Payne
Colin Stickland
Colin Stickland
Are you a Google Computer and Internet Expert? Answer questions, earn points and help others
