Question about Kenmore 91112 / 91114 / 91117 Electric Kitchen Range
Error code E6 on Kenmore dual fuel 665.7596
Dual Fuel kenmore range 665.7596 with E6 error code
Techsim
  • 59 Answers
SOURCE: how do you use the self cleaning option for Kenmore dual fuel ove
Simply press the "Clean" button and set a time (Hi or 4hrs is best) it will the lock the door and burn everything inside. If you have silver colored shelfs remove them fist. After its done and has cooled wipe out the ash that has collected in the bottom of the oven.
Posted on Dec 28, 2008
heatman101
  • 43501 Answers
SOURCE: Kenmore elite dual fuel range - all burners'
Here is a tip that I wrote that will help figure out why the burner spark keeps on clicking...
Gas Range Repair Burners Keep on Clicking
heatman101
Posted on Sep 07, 2010
blueextc3221
  • 15935 Answers
SOURCE: Our range started giving us the error
Here are some juicy pearls of appliantology wisdom from our friends at Maytag for understanding F1 fault codes.
In some models, there are subcodes that make diagnosis even easier.
Here's a simple explanation of what's going on and how to troubleshoot:
The F1 code indicates that:
a. The electronic range control (ERC) is sensing heat in the oven when in a time-of-day (i.e., not cooking) mode.
b. The ERC is receiving information to run multiple heat functions simultaneously.
Although different components (depending upon the model) could generate the code, simple and straightforward testing using your ohm meter is all you gotta do to test for it.
1. Check the oven temperature sensor. The oven sensor has to be within spec or it will cause the F1 code.
As an example of being out-of-spec, the ERC will generate an F1 fault code when the sensor shows 1650 ohms during a time-of-day mode.
This is equivalent to 350°F in the oven.
The resistance isn't high enough to generate an F2 code (runaway temp) or an F3 or F4 code (shorted/open sensor circuit).
The ERC monitors the sensor circuit after a heat cycle and expects the resistance to drop back to 1050-1100 ohms.
The fault code is generated when this doesn't happen. Checking the sensor circuit means also checking the harness,
harness connections and the sensor itself.
2. If the oven sensor circuit checks okay, then turn your inquisitive eyeballs to the touchpad.
If the range has a separate touchpad/keyboard, the keypad may have moisture that is shorting several circuits simultaneously.
If the F1 code is given immediately (instead of during or after a heat cycle),
remove the ribbon connector from the touchpad to the ERC after clearing the F1 code. If the F1 code does not return in five minutes,
then cast a suspicious gaze upon the touchpad/keyboard. Shorts may be caused by using an ammonia-based glass cleaner.
The touchpad surface will absorb ammonia-based cleaners that are sprayed directly on the glass surface. When heat is applied,
the surface material can break down causing shorts.
If you're gonna use ammonia-based cleaners on your control panel, then you should spray it on the rag and then wipe the touchpanel
-don't spray directly onto the surface of the touchpad.
3. On Amana ranges with a rotary temperature dial, be sure that the knob is in the OFF position when performing tests.
4. If these tests all check good, then replace the ERC.
Posted on Sep 25, 2010
  • 794 Answers
SOURCE: I have a Kenmore Dual Fuel 40" range 790 74403.
Hi skip356,
790 74403 is a model number. To make sure you may look inside the oven door on the side or top frame panel, or inside the drawer on the side panel. Look for the complete model number, I think the last 3 digits are missing. You may order parts from Sears at 1-800-252-1698.
Hope this helps.
Thank you for using FixYa.
Posted on Aug 17, 2011
SOURCE: The oven of my kenmore dual fuel range will not heat.
Mine did the same thing, replaced bottom element still not working. the top element & convection element works now what?
Posted on Oct 09, 2012
How to reset error codes
Dual Fuel Range Error Code 07 ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../dual-fuel-range-error-code-07
Sub?ZeroCore Issue: Dual Fuel Range error code 7; ERR 07 displays on Dual Fuel; Error 07 on control panel of Dual Fuel ... Convection Steam Oven Error Code E75.
L Series Built-In Oven Error Code COMM ERR ' FAQ ' Sub ...
www.subzero-wolf.com/.../l-series-built-in-oven-error-code-co...
Sub?ZeroCOMM ERR displayed on an L Series Built-In Oven indicates a communication error.Reset the unit's power at the circuit breaker. Turn the unit back on to see if ...
WWD30 Warming Drawer Error Code 40 - Sub-Zero and Wolf
www.subzero-wolf.com/.../wwd30-warming-drawer-error-cod...
Sub?ZeroError 40 on a Wolf Warming Drawer. Steps to Verify Issue: With error 40 on WWD30 warming drawer try the following before calling service: ... x. PF Error Code on Warming Drawer ... Whether you're shopping for appliances or have questions about those you already own, we've got the resources you need. ... Wolf Cooking.
Wolf DF304 beeping after turning off the oven - The Kitchen ...
appliantology.org > ... > The Kitchen Appliance Repair Forum
Dec 25, 2015 | Wolf Range Kitchen Ranges
I have a code E6. What is the code?
The should be another code with the E6 - Fx.
Dec 02, 2012 | Whirlpool Accubake RF362LXTB (Dual Fuel)...
F1 keeps flashing, top elements work but oven doesn't. What part do i need to replace? I have kenmore electric range
The F1 error code means that the computer thinks a button on the touchpad is stuck. Sometimes this can be resolved by making sure the touchpad connector fits tight into the control board. The F1 code can be cleared by pushing CANCEL/OFF. If it returns the touchpad needs to be replaced . Gene
Aug 29, 2011 | Kenmore 75853 Stainless Steel Dual Fuel...
My Kenmore Elite Gas Range is reading F1 on the display....the gas burners work on stove but the oven wont work....any ideas??
The F1 error code is a failure of the electronic oven control. This could be caused by a stuck keypad or an internal malfunction of the control. You will need to disconnect power and wait at least 30 seconds, reapply power and if condition still exist you will need to replace the electronic oven control.
You will also need to check if the oven is overheating. If the control has sensed a runaway oven temperature it will display an F1 error code. This could indicate a failure of the oven temperature sensor.
Hope helps.
Jul 18, 2011 | Kenmore 79383 Dual Fuel (Electric and Gas)...
Kenmore elite dual fuel range - all burners' igniters are clicking without being in use /trying to ignite the burners
heatman101
Sep 06, 2010 | Kenmore 79383 Dual Fuel (Electric and Gas)...
How do you use the self cleaning option for Kenmore dual fuel ove
Dec 27, 2008 | Kenmore 75503 Stainless Steel Dual Fuel...
Kenmore 91112 / 91114 / 91117 Electric Kitchen Range Logo
29 people viewed this question
Top Kenmore Kitchen Ranges Experts
Dan Webster
Dan Webster
Sal De
Are you a Kenmore Kitchen Range Expert? Answer questions, earn points and help others
