Question about Peg Perego Baby Gear
Milano capsule handle when driving - Peg Perego Baby Gear
Leaking Milano Dishwasher
check all screws in door,and seals,also you might have a disconnected rinse hose in the door
May 13, 2015 | Dishwashers
Peg perego milano stroller
Here is peg perego's list of stroller manuals but I don't see Milano, there must be a different model name somewhere on the stroller. I will keep digging.
Mar 03, 2008 | Baby Gear
Luna milano crib assembly instruction
Here is the link to the manufacturer's instructions page. Locate your exact model number (they are in alphabetical order) and download your manual. Milano Cribs by Pali Link
Jan 19, 2013 | Sweet Beginnings Bella Luna Milano Crib
Can not remove capsule and lever stuck
I had a similar problem, and it was down to high pressure remaining in the machine preventing the lever from releasing. You can test this by pressing the capsule in the machine (which will be much more solid than normal).
To fix, all you need to do is make a hole in the stuck capsule. I did this by drilling a small hole in the side of the capsule.
That releases the pressure (and a little spurt of coffee!), and the lever will release.
Mar 10, 2012 | Krups Dolce Gusto KP 2100 Espresso Machine
Is there a way to open up a Shure Beta 58A?
Once you remove the grill, there is a C-Clip that holds the cartridge down into the handle. Use some c-clip pliers to pull the c-clip out of the handle. The c-clip will remain around the post on the cartridge, but that's ok.
Feb 27, 2010 | Shure Beta 58A Professional Microphone
Button on handle adjustment is missing
You can order the part for about $7 from perego call them at 1800-671-1701.
Oct 24, 2009 | Peg Perego Milano XL Stroller
I cannot close milano stroller
Above the wheels at the rear of pram there are small levers that you must activate. I'm pretty sure you press the left one first (do not need to hold down) then hold down the opposite side's lever and push forward and down on the handle of the pram. If this doesn't work try pressing the levers in the opposite way first. Originally the pram would have had stickers "1" and "2" on the levers to dirict you how to fold. If in Oz look up Karisles on google and follow the prompts to download instruction manual.
May 28, 2009 | Peg Perego Milano XL Stroller
I read the answers written here and I can see why some people are still confused. So I will try to break it down into steps:
1. With your foot press down on the lever numbered 1 at the bottom of the stroller. This lever holds in place.
2. With your foot press down on the the lever numbered 2 at the bottom of the stroller. Hold this lever down with your foot because it does not lock in like lever numbered 1.
3. While your foot is still pressed on lever number 2, hold the handle bar with both hands and **** it forward. This step is rather tricky. So think of it as punching both hands forward horizontally while holding the handle bars.
At this point the stroller will come apart and fold. Now if you see that the stroller is stuck in position and does not fold or comes apart only with a lot of force then you have to oil the joints. Use WD-40 and spray it on the joints on the side of the stroller located right below where it say "PegPerego" on the body of stroller. That is where the joint where the stroller folds is located.
Hope this helps.
Feb 22, 2009 | Peg Perego Milano XL Stroller
Baby Gear Logo
27 people viewed this question
Top Peg Perego Baby Gear Experts
Jennifer Rock
Jennifer Rock
romney2012
Are you a Peg Perego Baby Gear Expert? Answer questions, earn points and help others
