Question about Compaq Presario SR1050NX (DW257A) PC Desktop
Internal fan the clips broke and the glue on the back wont keep it in place while my pc is standing. Then it would just shut off. after i turn it back on, it would shut off 3seconds after turning it back on. The process repeated for 10x. trying to turn the computer on. Now i have it laying sidways so the fan stays in place, and it doesn't shut off. Any ideas?
  • Compaq Master
  • 32,281 Answers
You can bolt the fan in place, may require drilling holes in the back. Be careful not to get metal filings inside the computer.
If there are already mounting holes, buy a fan (same size as the old one and usually they are 12 volt fans) and screw the new fan in place. Take a note which way the fan blows and mount it so that it draws air into the computer.
Posted on Jun 23, 2009
  • 256 Answers
Try "Crazy Glue" to glue the fan in place or buy a new fan and install it.
My flat iron one plate has come loose what is the best way to repair and keep the ceramic plate in?
Use a instant adhesive that can stand up on heat without which you need to replace the whole unit.
Jan 08, 2014 | Tigi Pro Session Flat Iron 1 Inch
How do you take the plastic clip off that hold the tone arm
Well be very carefull, since they breal soooo easily. You can get if bu unscrewing the imbuscat the side and the internal you desolder your tonearm wires and with some effort you can pull out the pivot after unscrewing the the height adjustment screw at the the side. They are crappy things and i just glue them together woth some thin bare thin wire to keep it in place, after that i use some kevlar/carbon fibre with the right glue, but not a lot of glue holds on it.... annoying part.
Jun 18, 2012 | Vestax PDX-2000MKII PRO Turntable
The clip that holds the face on broke off can it be repaired
This would depend on the type of clip and how it broke off... At your local Advance Auto, Auto Zone, or Napa they sell replacement automotive clips which are very easy to replace if the connector is still in place. In the past I have used super glue to reattach clips to connectors.
Apr 30, 2011 | Car Audio & Video
Two 512 MB ram with two 1GB, system shuts down by itself
The fan might not be going on and off, rather might be spinning fast and slow. The possible issue might be the heat produced.Try placing the laptop on a high stand with more space for the heat vents. Or buya good cooling pad. If the issue persists, please report back.
Apr 10, 2010 | Compaq Presario R3190US (DZ359U) PC...
61" samsung DLP 3 years old. Keeps turning off by itself.
Get a small but powerful used computer fan and place it in the TV to replace the defective old fan.That's the best way.The factory fans in these TVs don't last.
Sep 09, 2009 | Samsung DLP HL-P5663W 56" TV
When the power on switch is pressed, computer powers up momentarily, then shuts down. Both power supply fans run for only an instant.
I've had the same problem with another computer..
The simple solution, instead of buying and installing a new internal fan is to place the computer on its side and put a small electric clip-on fan directly over the vent. Turn on the clip-on fan and then start the computer; the clip-on fan should generate more than enough cooling so that the computer doesn't overhead.
Two notes:
The clip-on fans usually have the clip on the back of the fan so you can clip it to a bed headboard or to a small pole or shelf; the fan is about six inches across, and they sell at Target, Wal-Mart, Amazon.com, etc., for anywhere from $15 to $25, but you can usually buy them at Big Lots or similar stores for about $5 and you can sometimes find them at the Dollar stores.
You can use a larger fan, but a larger fan will generate too much wind. You want to use an electric clip-on fan and not a battery operated fan because a battery operated fan won't generate enough wind/cooling.
And, if the problem ends up being more than simply a cooling problem, you can at least use the clip-on fan later.
Let me know if this works.
XMinusOne@gmail.com
Dec 10, 2008 | Dell OptiPlex GX270 PC Desktop
Balance Cp4401 Desktop
open the case you will find the power supply fan and/or the cpu fan is not working more than likely the power suply fan
Sep 30, 2008 | Balance CP4401 PC Desktop
Slow, overheating, shuts itself off
sounds like your internal fans are taking early retirement, from all the symptoms..like running a car with no oil, you don't want to run a dell desktop without internal cooling..need to replace that fan..not too hard, actually.
May 04, 2008 | Dell XPS 200 PC Desktop
NP9890 shut down
If it is an overheating problem try turning the laptop off, turning it over and placing a vacum on the fan grill on the bottom. Many laptops get a dirt buildup internally and this will sometimes suck out the dirt.
Jul 29, 2007 | Sager NP9890 Notebook
Compaq Presario SR1050NX (DW257A) PC Desktop Logo
51 people viewed this question
Top Compaq Computers & Internet Experts
pankaj rautela
pankaj rautela
Alun Cox
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
