Question about Daewoo Televison & Video
Yamaha dv c6760
Belts
2 Suggested Answers
crazyhcris82
  • 34 Answers
SOURCE: yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
I do not believe your problem is with the DVD player. It most likely is with your TV. What happens alot is the picture on a TV is set to a different aspect ratio(ie:4:3,16:9). and sometimes it stretches or zooms the picture, allowing part to be cut off the edge of the screen. This aspect ratio problem can have two causes now that I think of it. The TV or the DVD player. To determine and fix, follow these steps.
PART 1-determining problem-
1 Watch regular TV for awhile and get some infomercials(yes, you have to watch Billy Mayes) on the bottom and edges of the screen, are there words and 800 numbers cut off, if so, your problem is with the TV and skip now to part 2(not step 2)
2 If you can see the whole number and everything , determine if your TV auto adjusts or not. Switch to your DVD player and see if the screens seems to move(shrink or enlarge). If it does shrink or enlarge, your problem is with the DVD player and you can now proceed to part 2.
PART 2-solving problem-
1 By now, you have determined whether the problem is with your tv or dvd player. From this point on "it, it's will refer to whichever has the problem
2 Go into it's menu
3 search for "picture" "video" or "setup"
4 Search for "aspect ratio" or anything containing "4:3" "16:9" or the words "stretch" "zoom" or "widescreen"
5 Set to 4:3 (sometimes 4:3 has multiple options such as stretch, zoom, and normal, if so, select normal)
6 ***OPTIONAL*** If you want widescreen, select 16:9(again if multiple choices, choose normal)
7 Insert or select a DVD and test your subtitles
If this does not work, please post a comment and I will help you further.
Hope this helps and please don't forget to rate
-Chris
Posted on May 04, 2009
How to loosen drive belt on 2011 yamaha v-star 950 tourer?
Hi, Anonymous for this scenario you will need your service/owners manual if you can't find the first and best tool you ever bought for your Yamaha, despair not, for a mere $20 you can download another one. For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have a nice day.
Star 950 belt issues or problems Yamaha Star Forum
Yamaha Raider Drive Belt Slack Adjustment Part
YAMAHA XVS950A Owner Manual
OEM parts for Yamaha
https://www.tradebit.com/filedetail.php/278867206-yamaha-xvs950-v-star-950-tourer-motorcycle-2009-2014
Jul 06, 2014 | 2011 Yamaha V Star 950
How to loosen drive belt?
Yamaha XVS950 Star 950 Tourer Motorcycle 2009 2014 Service Repair Shop...
Belt slack
Yamaha DV s-5350
Could be dust on the lens, the disk could be scratched or the lens has developed a fault.
jon
Aug 10, 2009 | Yamaha DV-S5350 DVD Player
My dv s5770 (yamaha)takes a long time to read the disc, if it does at all. sometimes it plays, other times it stops and skips to the next track/chapter. It goes from reading to dvd to info on the display...
The lenses of your dvd has a dust on it. You need to buy a cd cleaner , or you have to open the dvd and locate the lenses. Clean the lenses using cotton buds with alcohol.
Jul 23, 2009 | Yamaha DV-S5770 DVD Player
Yamaha dv-c6760 we can only see the top half of our subtitles
Hello shell
2 Go into it's menu
-Chris
May 03, 2009 | Yamaha DV-C6770 Multi-disc DVD Player
AJ-D250 PANASONIC E-62 PROBLEM
E-62 error on AJ-D250 points to a cassette housing problem. either replace the cassette housing or have it rebuilt (replace gears on the sides that raise and lower the cassette). "replace belts" won't work - the AJ-D250 doesn't have any belts.
Oct 14, 2008 | Panasonic AJ-D230H DV/Mini DV VCR
Region code locked
my v.zon plays but cannot see picture clear it is a portable dvd player.
Apr 19, 2008 | Yamaha DV-C6660 Multi-disc DVD Player
Yamaha dv-s5650
I have a Yamaha DV-S5550 and recently did the same thing. Our players may have the same menu system. Give this a try. Turn the power to the dvd player on. Using the remote, follow this key sequence exactly. Press the onscreen button. Press the down directional key once. Press the right directional key once. Press the down directional key six times. Press the right directional key once. Press the down directional key once. Press the left directional key once. Press the onscreen button. Your player should now be set to NTSC output. Good luck!
Feb 24, 2008 | Yamaha DV-S5650 DVD Player
BLOCKED MESSAGE ON YAMAHA DV-S5450 DVD PLAYER
The DV-S5450 may use a belt-loading mechanism. The belt is typically black rubber band with a diameter of approximately 2 cm. It is commonly found in front-loading CDROMs for computers also. Often, as a result of age, usage, humidity, etc the belt snaps, rendering the loading impossible. The loading motor doesn't just pop the tray in or out. It also engages a clutch assembly that raises an inserted disk or lowers a disk to be ejected; this explains why you can't simply force out the tray. Clearly in your case all the electronic signals are there and the loading motor does turn.
Solution: switch off and unplug the unit and then open it up. Do a quick inspection to see if you can locate the broken rubber band. If you can, remove it and take it along with you to the nearest repair shop for exact replacement. If you are finicky around technical work, simply a competent person do it for you. Good luck.
Jan 18, 2008 | Yamaha DV-S5450 DVD Player
Pink display
It seems the DV-S5950 has an incompatability with HDMI through Samsung TV's.
I work for an electronics store in Australia, and had same problem when running this DVD player on my Samsung KA40A650.
I tried it on my brothers LA40M51 and the same thing happened. Tried it at work on the A650 display model and same thing again. Then I tried it on the LG LCD that was next to it, and no problems. Also tried the DV-S5950 display model at work and it did the same thing.
It's not a general Yamaha issue, as we bought a new (higher model) Yamaha DVD player and it worked perfectly fine. I also tested the cables, and it wasn't them either.
It seems that that specific model of DVD player from yamaha just doesn't like the HDMI inputs on Samsung TVs...
Nov 26, 2007 | Yamaha DV-S5950 DVD Player
Televison & Video Logo
42 people viewed this question
Top Daewoo Televison & Video Experts
 Grubhead
Grubhead
Are you a Daewoo Televison and Video Expert? Answer questions, earn points and help others
