Question about JBL MR-15 CD Player
Replacement for jbl 15b
I would like a replacement with a I-pod jack and I phone. direct replacement ,no wiring , plug and play
2 Suggested Answers
  • 4102 Answers
SOURCE: my i pod no longer charges when i plug it in the
Hi, this is a very common problem, its to do with all the little contacts on the dock that are causing it not to charge, over time and use these little thin metal contacs become warn and you then lose the connection with the device,
check the contacts on the ipod itself first make sure they are totally clean and no fluff or bits of rubbish are blocked in the port.
then check the docking station make sure its off with no power going to it then have a good look to see if you can see the contacts its not easy to fix or even see so you may need a good magnifying glass, so once you have one of these have a good look at each contact and make sure their is no fluff or anything else on one of the contacts, if their isnt then try the following.
make sure docking station is off and has not got any power going to it then using a magnifying glass have a real close look at the contacts then get a long pin and touch each of the contacts as if your tryin to scrape them clean with the pin, then give it a try, now if this still dont work the only other option to try and get it working is to only very slightly bend each pin so its connects with the ipod so if you have a close look at each one and bend it only very slightly outwards then give it a try again, doing this usually gets its working but if you bend them to much they can break and it will then be no good what so ever.
so have a go at fixing it but if it wont fix then the chance of getting it repaired is pretty slim.
let me know how you get on or if you need further assistance ok
Posted on Feb 07, 2011
Jbl speakers turn off on their own
Sounds like you have them plugged into the wrong jack
Jan 01, 2013 | JBL Jembe Two-piece Entertainment Speakers
No dial tone
  • First, try to check every telephone line is properly plugged into its phone jack. If you have a problem with just one phone, plug a different phone into that jack. If the second phone works, the problem lies in the first phone.
  • Then unplug each phone and answering machine in your house, one at a time. Wait 30 seconds after unplugging the first device. Pick up another phone to see if there's a dial tone -- if there is, then the first phone may be faulty. If not, continue unplugging phones in the same way and check for dial tone. If you find a phone that doesn't work, plug all your other phones back in and see if they work properly. The faulty phone should be replaced.
  • or disconnect the plug from the test jack inside the exterior box. This disconnects your inside wiring from phone company's line. If you have more than one line, select the test jack for the line that is causing the problem. Plug your phone into the jack; this plugs you directly into the phone company's line. If you have a cable modem, plug the phone directly into the jack on the modem.
  • Then pick up the phone receiver to see if there's a dial tone. If there's no dial tone, the problem is with your outside wiring. If there is a dial tone, the trouble is caused by your inside wiring, equipment or jacks.
  • Hope it will help you. Thanks for using FixYa.
  • Oct 19, 2011 | Lands Phones
    How do the wires go into the back of the creature?
    First go to this site and download and install this codec pack. Also, make sure you have your speakers set as you default sound device.
    JBL Creature 2 are a computer speaker system designed and sold by JBL. The system is made up of two satellite speakers and an omni-directional subwoofer. The speaker system connects directly to a computer's available sound card output jack or a laptop's stereo output jack. Occasionally, problems can occur with the sound quality and connection with the speaker system. If there is no sound coming from the speakers, check the cable connections. Ensure the satellite speakers are firmly connected to the matching jacks on the back of the Creature's subwoofer. The connections are color coded and, in addition, each speaker connector is shaped differently to fit only into one jack. Ensure the output cable is firmly connected to the subwoofer audio in jack and the computer's audio-out jack. Ensure the power button on the back of the subwoofer is pushed inward. If everything is connected properly, the green lights on the underside of the satellite speakers will glow.If there is still no sound, tap the right-hand side audio-increase button on the right satellite speaker until sound is heard. Also ensure there is audio playing from the computer. Double check the lower right-hand side of the window's main screen and look for a speaker icon. If the icon has a red slash over it, click the icon and uncheck the "mute" option.
    Hope this helps
    Dec 30, 2010 | JBL CREATURE II Computer Speakers
    When I plug my headphones into my iPod, there is no sound, unless I jiggle the cord around and do not plug them all the way in. They worked fine at the beginning, but do not work now.
    I'm not certain it's not the I-Pod socket or the headphone jack that is playing up? If you can get another pair of headphones (a friends etc) and put them in the socket of the I-Pod, to test it that should clear it up. For if they don't work you know it's the I-Pod socket that's faulty.
    If it's the Bose jack that's gone, you better see my tip on dodgy cable/plugs on headphones. You should be able to replace it with the 3.5mm type shown, but I think you can get the thinner type jacks.
    Jul 09, 2010 | Bose in-ear headphones - Black with...
    JBL Speakers won't play
    Check all your connections. it might be that the green audio jack isnt put into the rear of your pc properly.
    Jan 02, 2010 | Audio Players & Recorders
    JBLPro Compac computer speakers wont work
    Well from what you said no device, it was not detected because of your new magic jack. There might be a conflict in your hardware. Try scan plug and play devices if it can detect your jbl or reinstall both you devices.
    Nov 30, 2009 | Computers & Internet
    JBL Creature Speakers have very low volume
    use another device like your i pod to make your jbl sounds louder and then plugged it to your pc without turning it off. after plugging try to test it if works.
    Apr 02, 2009 | JBL CREATURE II Computer Speakers
    Ipod nano connector for Bose 321 GS Series III
    OK! The cheapeast and most simple way would for you is to get a 1/8th inch conector jack that adapts into red/white RCA jacks (it will have a couple feet of wire in between the jacks) plug the 1/8 inch adapter into the jack on I-POD and the RED/WHITE ends into the back of your systems aux inputs RED/WHITE! OR tape input ect! make sure I-POD is turned up! and you may have to adjust I pod eq to get the best sound out of system! (OH you can get this adatper at any radio shack or wall-mart!)
    Please take a second and rate this response
    THANK YOU!
    Jan 19, 2009 | Bose 3 2 1 Series I DVD Home Entertainment...
    JBL Radial Remote stopped working.New battery replaced no avail.
    Turn on the JBL with the ipod in place, turn off at the mains plug, turn back on, turn on your JBL and the remote should work.
    Jan 12, 2009 | JBL (JBLRADIALWHT) Speaker System, Docking...
    JBL MR-15 CD Player Logo
    60 people viewed this question
    Top JBL Car Audio & Video Experts
    hoyzee1
    Rob Beech
    Steve Sweetleaf
    Steve Sweetleaf
    Are you a JBL Car Audio and Video Expert? Answer questions, earn points and help others
