Question about Hotpoint Aquarius WF000 Front Load Washer
Will not move on from wash to spin & therefore empty
I have checked the filter and cleared it but still no joy??? The machine will fill start to wash and just carry on and on stuck on wash and stay full of water. Any feed back will be graetly received. Cheers
  • 57 Answers
Its either your brushes on the motor that are worn out or pump blocked or defective
Posted on Jun 23, 2009
Washing machines problems
please check if the water outlet pipe is clear by blowing down it to see weather the pipe is clear as the machine wont move on until the water is emptied from the last cycle it needs to empty the wash water first before spin cycle can start, its worth a try eric
Dec 09, 2017 | Washing Machines
Will not spin & now will not wash,
June,
unplug it for a minute replug. should reset the cpu.
Best to you.
Jan 04, 2018 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washing machine fills with water but drum won't spin and water won't drain. Checked carbon brushes & cleaned out filter, still no joy.
hello try the module board this control the motor speed it sit at the back of the washer usually as a load of wires coming of it hope it helps
regards
shaun
Mar 20, 2011 | Washing Machines
Water does not empty all out on normal loads have to run quick rinse and spin to try and empty.
Check the filter, located behind the access door on the front lower left of the washer. If clear, replace pump motor. (did you know that you can turn the washer on and NOT select a cycle, but just touch the spin speed button, then start to get a 12 minute or so spin and pump only cycle, with no water fill?)
Feb 01, 2011 | LG WM-2277HW Front Load Washer
Hotpoint WD61 - I have taken back off, emptied blocked filter but having reasssembled the water does not drain and therefore does not spin. If I empty water via a bucket from drain hose the machine does...
hello, is sound like the pump not energizing the pump needs testing with a multimeter. fill it up again then empty it you should hear the pump kick in also check the hoses make sure there not kinked good luck
regards
shaun
Dec 05, 2010 | Washing Machines
Washing machine wont spin
Hiya,
the 1st thing to check on this would be the drive belt most machines have an easy access point at the rear of the machine if you open this you will clearly be able to see the belt comming from the motor to the drum if it is loose or damaged this would stop the machine from spinning..
Always remember to disconnect the power before opening any apliance & a qualified enginer should be considered however this simple check could save you a call out charge & a costly repair bill
Hope this helps
Apr 22, 2010 | Hotpoint WMA30 Front Load Washer
WMA54 won't empty water? We've emptied filter but
Could be the pump, but they do not often fail.
I would check the main hose or the pump itself for a blockage.
Try blowing down the hose to see if it is clear.
Mar 03, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Zanussi ZWF1437W E23
E23 indicates Drain pump faulty; Wiring faulty; PCB faulty.
The service information also says it should stop with the door open.
Unplug the appliance and manually remove the water via the filter or front drain point if it's fitted.
Drain it into a shallow dish, tighten the filter when you need to stop the water (or plug the hose if draining via a hose) while you empty the container.
Once empty, try the door again.
Take the filter out and clean out any debris in it.
Plug the appliance in and put the machine on a drain programe.
Listen/look at the open filter to check that the drain pump is running.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 27, 2009 | Washing Machines
Washing machine not filling with water not washing but will empty and will spin
like the anchor idea?, no sorry, this does sound like the water is not getting to the machine, so, when you turn the machine on does it make a slight buzzing noise, if so the fault is no water in the pipes to the machine (from the house), if no buzzing check the solenoids with a multimeter for open circuit (removing the 2 wires first) oh and the plug obviously / replace solenoid if needed, i am sure this will cure your problem, if so rate me please, thank you
Sep 18, 2007 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
71 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
