Question about Troy Bilt 175HP Manual 42" Riding Mower
Troy-Bilt LTX-1842 leaks oil out the exhaust and blows white smoke
SOURCE: belts slippin on troy bilt horse
Have you adjusted the locking cam for forward. This cam is held in place with one bolt. The further you move it down the tighter it will make the belt
Posted on May 05, 2009
  • 10865 Answers
SOURCE: Troy Bilt Trimmer 75SS stalls at full throttle. new gas
Hello. Let me assist you. Since your trimmer runs but stalls at ful throttle it is telling you that there is a fuel problem. Not enough gas is getting through the carbeurator to satisfy the engines needs on full throttle. Most likely the carbeurator is gummed up. A common problem. Let's see if we can un gum it by getting a can or carbeurtor cleaner. Go to any auto parts store and talk to the clerk about your need.
Posted on May 20, 2009
  • 125 Answers
SOURCE: excess white smoke coming from exhaust of TB 75SS string trimmer
This model is a four cycle engine meaning that it does not a mix of gas and 2 cycle oil. You just fill it like your lawn mower, gas and fill the crank case with oil
Posted on May 25, 2009
  • 47 Answers
SOURCE: oil type for troy bilt weeder 4 cycle model #
Non detergent, straight 30 weight.
Sometimes can be found labeled as "Tractor Oil". Otherwise, any premium 10w-30 I find in my experience with these stout 4-cycles to be just fine!
If breaking in engine from new, out of the box? Change oil with 10 hours on the clock with engine is still warm. You only need 3.2 Oz. to fill the crankcase!
So pour slowly. It is full when the trimmer is placed on a level workbench surface with the trimmer head dangling off the end. There is going to be a slight forward tilt away from the oil fill plug. Fill only until it just literally comes to the bottom of the oil fill plug with the trimmer laying flat on your workbench.
*DO NOT FILL IT UP WHILE HOLDING IT VERTICALLY!*
(I warned you. ;D )
Also at this time, clean and re-oil air filter and check your manual - these trimmers after break in require a valve lash adjustment. .005" @ TDC if my memory is correct....The manual I *think* states anywhere from .003 ~ .007 to be within spec. After break in, only need to adjust valves seasonaly. Regular oil changes @ 20~25 hours of run-time keeps them happy.
Posted on May 09, 2010
  • 302 Answers
SOURCE: My troy-bilt 13036 blows 20amp fuse after 15 - 20
Sounds like that circuit there is a bare spot in the wire and when it gets jarred around the bare spot contacts the frame in turn shorting out the fuse and blowing it.
Posted on Jun 30, 2010
How to wire solenoid on Troy Bilt ltx 1842
Didn't specify solenoid of the two so is a link to the wiring diagram.
http://c.searspartsdirect.com/lis_png/PLDM/P0401171-00010.png
Oct 29, 2014 | Garden
I have a troy bilt fronttine garden tiller . Why does it blow whitebsmoke out exhaust?
WHITE smoke is generally associated with antifreeze, but that won't be the case with your air-cooled tiller (it has no antifreeze). It's my best guess that it's blueish smoke, which is associated with oil burning - I suspect that your engine is about ready to be rebuilt or replaced.
Apr 25, 2014 | Troy-Bilt 179cc 24-in Two-Stage Gas Snow...
Need to put a new belt on the rear of the Troy-Bilt LTX 1842
First buy proper belt... Next note how old belt is warped around the pulleys, take a picture or draw a diagram... Remove all covers off deck pulleys, and guards to expose belt completely... Pull and stretch belt off one of the idler pulleys, once one is off the rest will slide off... Reverse procedure for installation... Note: grease all nipple fittings, bearing and shafts to avoid seizing of bearings or bushings.
Nov 17, 2013 | Troy Bilt 25HP VTwin Hydrostatic 50" Zero...
Have a troy bilt trimmer mower 5hp that is at least 10+ years old. very hard to pull start, when it does start it chugs about 5 seconds, and dies. like the spark plug really never gets it fired up. also...
you could have several problems with your engine . one it could be off timing it could have a sherd flywheel key or you could have a stuck ring or bad rings also a scored wall.. white smoke is oil if you have tipped it over you have to let the oil burn out of the cylinder if you believe its your plug take the plug out and clean it off with some gas and a soft wire brush and put it back in see what happens .
Nov 04, 2013 | Troy-Bilt Garden
Why is my exhaust leaking oil and blowing out grayish color smoke
Your piston rings are worn to the point that oil is getting into the cylinder and some is being ejected through the exhaust and some of the oil is being burned causing the grayish smoke.
May 07, 2012 | Troy-Bilt Super Bronco CRT Garden Tiller
My troy bilt 4 cycle gas trimmer,is leaking oil behind the air filter from the top and its alot of white smoke coming from my exhaust.whats wrong
Check to see if the oil was overfilled, or maybe stored in a position that allowed the oil to drain to parts that it was not intended.
Jul 18, 2011 | Garden
I need to locate the fuel filter for a lawn tractor ltx-1842
Locate the fuel line at the carburetor and trace it backwards toward the fuel tank. You will find a (usually plastic) in-line filter somewhere near the back corner of the engine
Aug 25, 2009 | Garden
Smoke and oil coming out of the front exhaust of
chech engine oil level ,if oil level its up carburetor flout neddl valve leak and the fuel run into engine
Aug 22, 2009 | Garden
Troy Bilt 175HP Manual 42" Riding Mower Logo
93 people viewed this question
Top Troy Garden Experts
Matt Olenzek
Matt Olenzek
Mike Squire
Tim Whalen
Are you a Troy Garden Expert? Answer questions, earn points and help others
