Question about Whirlpool Washing Machines
Whirlpool washer sm 8525493 fills but doesn't run
Won't start wash cycle and won't drain
RJTech
  • 32 Answers
SOURCE: Frigidaire Front Load Washer
You need to replace the Motor controller speed asm part number 134149220 they are about 165.00. very easy part to replace you have to remove the back panel and the control board is on the bottom left side two scews and two plugs.
Posted on Dec 18, 2007
SOURCE: Whirlpool Model LSV6234AWO
door switch bad?
Posted on Oct 18, 2008
michiganfan9
  • 179 Answers
SOURCE: Whirlpool Washer - Imperial Series Quiet Wash 2
your washers drain hose is too far down the drain pipe which is causing a siphoning action pull the washers drain hose out pipe some you should be able to hear water dropping into the pipe the reason it only happens in the rinse cycle is because the water from wash is being drained and before the water vacuum is broken the rinse water comes in causing it to keep draining
Posted on Dec 30, 2008
  • 61 Answers
SOURCE: water runs into tub but does not fill?
be sure the drain hose is not lower than the wash tub this will caust the water to run out, 2nd be sure the drain hose is not pushed to far into the house stand pipe and the there is rome for air to go inbetween the drain hose and stand pipe eather of these will cause the machine to siphon mostly on rince cycle or on the 2nd and third loads you do. last your house drain could be starting to back up fill the washer with water and listen to it drain if you hear a gurggling sound in the house pipe you may need a plumber to cleanthis out for you.
Posted on Jan 20, 2009
  • 99 Answers
SOURCE: WHirlpool Waser model LSR8133HQ0 - tries to fill for rinse cycle
hellow my name is joyce and It sounds like you have a issue with your cut off valve that controls the water flow to your machine in between cycles, this is controled by your timer switch you may want to call technichian to repair. sounds like the only problem you have with the timer is on the rinse cycle not the wash cycle, but it defently needs to be fixed. if I can help you find a repair person please let me know.
thanks you and let me know if I can further assist you.
joyce
Posted on Feb 06, 2009
I have washer Roper SM 8525493. It will only fill with water when in rinse cycle. Any help would be greatly appreciated. Thanks
comes up my part of the world as as a whirlpool brand of top loader
the actual timer is faulty
water inlet valve must be working to let water in
but timer opens and closes that inlet valve
http://www.repairclinic.com/Shop-For-Parts/a11b122/Roper-Washing-Machine-Parts
Jun 29, 2016 | Roper Washing Machines
Filling with Water and then stops
replace the tub motor drive belt
Dec 03, 2013 | Whirlpool Washing Machines
Whirlpool type 107
Sounds like the clutch may be slipping. Does it go into a high speed spin?
Aug 18, 2013 | Washing Machines
Beko WMP652W washing machine will start cycle but get stuck at end of wash, doesnt go onto rinse or spin any help please?
see the next steps and use the common sense: God bless you
When the cycle doesn't advance, it's probably the timer or a cold-water supply problem: It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer. It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water.
Aug 01, 2012 | Washing Machines
The washer fills agitate but won't spin & drain
Possible fault with the program controller unit. You need to check the program cycle outputs using a multimeter connected to measure the output voltage. On start the inlet should open and then close as the water level sensors works and then proceed to wash. So this much seems OK. Now in the next step the drain valve must open to drain off, then fill once again with the inlet working and water level being sensed. If there is no output in this section cycle then the prrogram controller has errors within the memory . You can remove the panel and reset all connectors and connections.
Oct 30, 2011 | Whirlpool Ultimate Care II LSQ9564J Top...
The rinse cycle won't spin out, it starts but doesn't "spin up" and just runs for ever if you let it.
Possible that the program controller unit is a suspect. So intitially check the inlet valve , check for water flow, if not remove and check INLET valve. after water filling the motor must start, if not the level sensor or the program controller is a suspect. Also if after wash if there is no drain then the drain pump must be checked.
Check the voltage outputs to confirm if the program controller works to the cycle.
Sep 20, 2011 | Fisher and Paykel GWL11 Top Load Washer
Washer wont aggitate, spin or drain
Your drive belt sounds like the problem related to all these, provideing you hear the motor running, and timer is advanceing
Feb 10, 2009 | Roper RAS8445KQ Top Load Washer
Water runs into tub but does not fill?
Jan 19, 2009 | Kenmore 24032\24036 Top Load Washer
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
