Question about Toys
How do i build a soakage pit to collect ground water
Is rain water safe to drink?
Rain passes through the atmosphere before falling to the ground. So it can pick up any contaminant present in the atmosphere.
It's not a great idea to drink rain water falling near chemical plants or near the plumes of power plants, paper mills, etc. Don't drink rainwater that has run off of plants or buildings because you could pick up toxic chemicals from these surfaces. Similarly, don't collect rainwater from puddles or into dirty containers.
Jan 04, 2017 | Green Living
Can you get water in LP lines when filling RV w/ propane? Frig quit on propane,worked on electric. Had filled w/ propane two days earlier. mechanic found oily water in line; range still worked.
Yes water can do compensation build up in your propane tank. Some tanks have a drain pit on bottom reclaim propane and open the pit. If your does reclaim the propane and drain tank. If not reclaim propane and remove tank then remove filler valve turn tank over drain access water leave tank up side down over night. Put fill valve back on and mount tank. After lines are back on turn stove on leave on for 48 hours. Turn valves off and refill tank. Best of luck.
Jun 10, 2016 | RVs
To clean a ball pit can I just soak the balls in a water and bleach solution?
Some balls might have small holes in them or cracks that if completely imersed in water can become breeding grounds for mold. To be on the safe side you should never soak them, use a spray bottle to coat them in the solution to disinfect the balls.
Oct 03, 2013 | Toys
Water in bottom freezer
Sounds like possible defrost drain. Water builds up over time. Need to pull evap cover and see if ice is build up in tray. If so defrost drain, should fix issue
Aug 24, 2012 | Maytag MBF2258XEW
Removing chicken feather commercially without human inthe process?
This generally involves the use of a "plucking machine". After the chicken runs through the kill line, it is submerged into a hot bath of water in order to losten the feathers. The bird is then taken through a plucking machine which has rows of rubber "fingers" spinning on each side which pulls the wet feathers from the body of the bird. A constant stream of water washes the feathers down into a collecting pit for disposal.
Dec 17, 2011 | Computers & Internet
My hitachi Ac is leaking
Check the drain which can be blocked and is pitting out the water which has resulted out of condensation.
Usually the water flows out through the drain after falling on the base of the window unit and flows out. If the base plate is worn out it can leak. so check this out.
If this is the split type then the condensation must flow out through the collection tray into the drain tube . If the drain is choked or is worn out the water can leak.
Sep 01, 2010 | Hitachi Heating & Cooling
If i leave it pumping all night and the water dries up will it burn out the motor?
yes besides the water keeping the pump cool it also acts as a lubricant for pump no water can burn up and seize pump
Mar 15, 2010 | Craftsman Professional 1/4 Hp Submersible...
How to drain water from 30gal tank of model #919.167312
bring your air up and (make sure you have safety glass) you should have a pit-**** on the bottom of your tank. after your air builds up shut off the unit, and open that pit-**** value (srew) and let the it drain out.
Oct 16, 2009 | Craftsman Air Tools & Compressors
Have just replaced ink soakage unit MFC425CN
After replacement you need to go into diagnostics and reset the counter. I am not allowed to give that info. but your not done until you reset the counter.
Aug 11, 2009 | Brother MFC-425CN Multi-Function Center...
Ive got a shallow jet pump model sd510 it runs all the time and it pumps the water from our holding tank to sump pit it runs about 250-300 gallons through to the sump pit ive replaced the pressure switch...
Just curious, why do yo9ur run water from a tank to a pit?
Where is the pressure switch located? At the pump I presume? What will increase the pressure? If you are pumping to an open pit, you will never build up any pressure? What is supposed to restrict the pump to create pressure?
You need a restriction to create pressure to turn off the pump. Is there a float valve like in your toilet in the pit? If not this would be required
Good Luck
Jan 04, 2009 | Plumbing
Toys Logo
314 people viewed this question
Top Toys Experts
Andrew Taylor
Andrew Taylor
Are you a Toy Expert? Answer questions, earn points and help others
