Question about Sharp AQUOS LC60LE847U 60 inch 1080p Quattron Technology 3D LED L
Power light on my sharp 1080p wont go off - Sharp AQUOS LC60LE847U 60 inch 1080p Quattron Technology 3D LED L
How do I fix my sharp TV
This is the board that has the bad part. http://www.shopjimmy.com/sharp-runtka932wjqz-power-supply-led-board.htm
Compare yours with the picture to see if there is anything visually wrong.
May 06, 2016 | Sharp AQUOS LC-60C6400U 60" 1080p LED-LCD...
Our sharp tv model # LC-42D72U power light flashes green but there is no sound or picture. Looking for your expert opinion on what could be wrong so we can get the part ordered. The board with the power...
Green on light is blinking, but no picture - Television - iFixit
https://www.ifixit.com/.../Green+on+light+is+blinking,+but+no+pict..
iFixitOct 3, 2014 - The Sharp LCD TV LC37SB24U set worked until off button on remote ...The green light is blinking any time power cord is plugged into the wall outlet. ... It does sound like either a bad inverter board or a bad power supply. .... On the clad sidethere is no connections or ribbons that indicate hard current draw ...
Oct 20, 2015 | Sharp LC-42D72U 42 Flat Panel 1080p...
I have a Sharp Aquos lc-52d64u TV that wont stay powered on.
Fault to its main board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
Oct 07, 2015 | Sharp 52"" aquos lc-52d64u 1080p...
90" sharp aquos wont power up
If it is not doing anything, pitch black, might be the power supply. In any case, if you don't have the technical testing equipmente, there is not much you can do about a TV not turning on, except to take it to an authorized repair shop or call service to home
May 11, 2015 | Sharp AQUOS LC90LE745U 90 3D 1080p LED-LCD...
My tv wont turn on by power button or remote. white light keep blinking.
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/. If the blinks continues, and non-stop, the fault should be with its main system control IC, and with the memory IC.
Dec 14, 2013 | Sharp AQUOS LC-60LE632U 60-inch 1080p LED...
I have sharp 37 inch LC-37D44U MY PS3 is not working with it it green lights keep blinking power light and OPC. BUT THE HDMi ports work beacause i checked it with other devices. so i dont know why its not...
Does this happen when you input certain signals to the HDMI2_bing.gif ports? Or all signals (e.g. 1080i, 720p, 1080p, etc.)? And which ports are affected - side HDMI, rear component, etc.?
I had this issue and Sharp sent out a local repair tech to install a new main circuit board, then two weeks later, a new side board (where the side inputs connect into the system)... their first visit allowed my TV to accept signals in the rear HDMI ports (all signals worked well), but then I couldn't get a signal processed via the side HDMI port. At first, just 1080p would not display (caused the OPC/power green light blinking), and after a few days, any signal hitting that port would cause the error lights to come on. But as I said, eventually, a new side board resolved that issue.
Sep 11, 2009 | Sharp Aquos LC-45GD4U 45 in. LCD HDTV
Sharp AQUOS LC60LE847U 60 inch 1080p Quattron Technology 3D LED L Logo
16 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
