ORION TV32RN10D GIVING MESSAGE ''DATABASE EMPTY''
Moved house recently telly working ok when setting up the above problem happened tried outside arial and indoor digital still no joy
Also when trying to install carrier it is telling me carrier not found
Any help would be appreciated
2 Suggested Answers
SOURCE: i have an Orion TV32rn10d
I had this problem as well.... the TV jsut froze and then it turned onto analogue and when i press the TV/DVB-T button it came up with the following message...
Error
Cannot Access Digital Services
Solution...
I pulled the plug out the back of the TV waited 5 seconds and put it back in...
suprise suprise it works :D
Posted on Mar 31, 2009
Tv remote code for orion tv32rn10d
Remote Control Code for Orion TV32RN10D is "2005".
Comprehensive source for this and many other TV's is
http://www.skymediauk.co.uk/Univeral%20Remote%20Codes%20-%20Nov%202008.pdf
Apr 05, 2012 | Televison & Video
I have a 1980's atari game. How do I set it up?
hi, this round pin with the little pin in the middle this needs to be plugged into the back of your telly it goes into the ariel socket you need to unplug your tv's arial then plug this into where the arial was, now what you need to do is put your telly onto a channel you dont use such as 7 or 0 witch ever one you dont use to watch telly, once you have done this you need to enter the setup mode on your telly to scan for channels so make sure the game is switched on and then start scanning for channels as if you were tuning in the tv channels so do this then you will come across the game so you then save this frequency to this channel.
You can then play the games just remember when you want to play it that you put the telly back onto the channel you tuned in for that game.
Let me know how you get on or if you need further assistance ok
Jan 25, 2010 | Video Game Consoles & Games
Cant seem to fine the sega mega drive2 on my tv
hi, if your plugging the sega mega drive into the airial socket ie same fitting as the arial then what you need to do is make sure its plugged into the arial socket properly now you need to switch it on with a game in wait for minute or so for the game to load up.
Then you need to put your telly onto a channel you dont use such as 7.
Then you need to use the telly remote and enter the setup mode once in this mode you need to use the setting that lets you scan for the telly channels.
Now depending on your telly this will either be an auto tune or manual or both if you can choose then pick the manual type.
Once this is selected you then need to choose witch way your going to tune ie up or down.
Make sure on the menu your tuning the channel you want ie 7 or what ever you want to use.
Now it dont matter witch way you start scanning so start the scanning then just keep going the one way then eventually you will get the screen tuned into the mega drive you then need to save this setting into the channel your using.
Right now you have done all that if by any chance on the lead from the megadrive to the tell it has a switch ok then try it with it in the on possition then scan all the way if after ages you get no picture then press the little switch and scan again.
But depending how old it is you may not have a switch dont worry if not as its less hassle to tune in as you havent got 2 choices.
So their is the instructions if it is an arial socket type connector.
If however it is the three color leads then plug these into the right colors on the telly then make sure you have a game in switch it on wait 1 min or so then get the telly control and find the source or maybe av button depending on your control is will be either of those 2 if it dont have them then look for a small picture on the control it will look like a square box with an arrow running from the right to left this is the av/source button.
Once you have found this button you may need to press it 3 or 4 times untill your on the right input ok then you should have it on(only these instructions if its color leads if not follow first instructions ok)
I know its a lot of info but youll get their in the end (that is if the lead from mega to telly isnt damaged) if after doing what i say you still get no picture then the chances are the lead is damaged and needs replacing but from what i can remember (back in the day) it was just a normal arial lead anyway so you should have one of these lying around.
Nov 12, 2009 | Computers & Internet
I have an Orion TV32rn10d and i have error reporting cannot access digital services although it was working fine this morning
Error
Solution...
Sep 08, 2008 | Televison & Video
I have a sega mega drive with all the relevant pieces but i cant tune it into the tv
Hi. is the lead from mega drive a rf socket that goes into the arial socket on the telly and does the lead have a switch on it?
Plug the rf lead from md into areial socket on telly
then put telly on channel you dont use i used 0 or 9 but use any.
then turn mega drive on
then press setup on tv
enter channel settup then you need to go through the procedure of tuning channel in its best doing it manualy its like when you tune a channel in make sure md is on then keep changing the frequency one way or the other could take few minutes then when you get it on the telly save this setting on the channel you want to use ok.
If it dont work then the chances are the lead is damaged this is often the case with these consoles as the are not made that well so if no good then replace if necesarry.
If your unsure on tuning your telly then give me make and model then i can talk you through the process ok
Apr 22, 2008 | Video Game Consoles & Games
Wiring diagram for sony kdl-23s2010
i can tell you the best way but i need to know what your using ie scart leads things like that also tell me how many scart sockets in telly and in dvd and sky and vcr after you give me this info il tell you what needs pluggging into what
basing it on your telly has 2 scart if not let me know ok
1. dvd to telly via scart lead
2. then sky to vcr via scart doing it this way allows you to record sky using av channel on vcr
3. vcr to telly via scart lead
then if you want your video to record normal telly channels you need to use normal arial leads in this order
1. from arial to vcr then from vcr to telly doin this allows you to record the channels you get through the arial like 1 2 3 4 5 also this way when you choose 1 or 2 or 3 on video it will record that channel allowing you to watch whatever on sky whilst recording normal telly
If your telly only has one scart socket in the back then you need to buy a scart adaptor that converts one scart socket into 2 or even
let me know if you understand what im telling you or if you need further help ok just let me know im going out for 2 hours but will check your reply then so hope you dont mind waiting if you need help ok
Feb 18, 2008 | Televison & Video
Orion tv32RN10D Digital problems
factory reset hold volume button on tv down all the way while holding it down hold number 1 on your remote goes to stanby turn back on..
Jan 08, 2008 | Orion HDLCDVD225 22 in. LCD TV
Televison & Video Logo
156 people viewed this question
Top Televison & Video Experts
