Question about Plumbing
Why will my kitchen faucet pedestal no longer swivel?
Kitchen faucet with pull-out head: pedestal will not swivel. Has been getting progressively harder to turn and now has seized. No corrosion or scale buildup.
frcs68
  • 1605 Answers
SOURCE: single handel kitchen faucet: Over time the
shut-off the water, pull the handle and the spout. change the 2 "O"ring and make sure the spout body has no dirt in them. apply some the plumbing grease bewteen the spout body. put everything back.
Posted on Apr 22, 2009
  • 39 Answers
SOURCE: kitchen faucet leaking pull down sprayer spout type
try tightening the nut that attaches the flex line to the pull out spout
Posted on Aug 04, 2009
  • 3600 Answers
SOURCE: I have a moen pull out kitchen faucet that leaks
You have a bad internal o-ring or the sprayer o-ring is leaking, if you look under the sink turn it off and then turn it back on, if you see it leaking out the center shft where the water pipes go into then the faucet may have a broken pipe or loose pipe. check and tell me where it's leaking at. You can buy kits to repiar them they are inexpensive.
Posted on Aug 30, 2009
  • 35 Answers
SOURCE: Grohe ladylux plus kitchen faucet leaks from
Yes,it sounds like you have to replace the hose.Follow the braided hose under your sink until you come across a yellow and black fitting . it is comparable to an air hose fitting quick disconnection. once that is pulled from the sink port,unscrew the spray head and pull the ose through the faucet body from above the sink
Posted on Feb 23, 2010
1stBSP
  • 52 Answers
SOURCE: I have a Moen Single Handle kitchen faucet, it's
Replace the "O" rings that are behind the spout portion. You will have to remove the top of the faucet and pull up on the spout section. There will be a couple of "O" rings there. It is best to have Moen send the parts to you as locating the proper size "O" rings can be difficult.
Posted on Apr 06, 2010
The handle on my rohl kitchen faucet won't hold its position, how do you adjust or tighten the handle?
under the counter there is a nut that needs tightened . usually need a swivel head faucet wrench to get them tight .
Feb 14, 2015 | Rohl A3608LMPN Single Lever Country...
Am installing a new American Standard faucet. Does it need to be lubed prior to installation?
I think American Standard probably is correct, especially if there is a history of swivel faucets seizing over time.
Dec 11, 2013 | American Standard 4205.104.075 Reliant...
Danze D456513 kitchen faucet will no longer swivel. How do I correct this?
The swiveling part may have corroded. You can attempt repair by disassembling the faucet and removing the corrosion or simply replace the complete faucet
Mar 23, 2013 | Danze Plumbing
Leaking around swivel
http://www.americanstandard-us.com/assets/documents/amstd/parts/Parts_1859.pdf
You need to replace the O-ring that seals the place it's leaking. The part number
M962303-0070A on the diagram above (click the link)
Feb 01, 2011 | American Standard Kitchen Faucet 6310 020...
My kitchen faucet is loss from the bottom and it seems it can not be tightened. The water facet water valves seem to be in the way.
Tightening the nut on a faucet is tough to do in the tight space you have to work with. The proper tool to use is called a 'basin wrench' and is not too expensive. It has a swivel head to let you get it up to the nut and turn it from below. Here's a picture:
http://www.amazon.com/Ace-881041A-WRENCH-BASIN-11/dp/B000H5YESW
Apr 11, 2010 | Grohe Classic Kitchen/Bar Faucet ...
It is not leaking, but it will no longer swivel from side to side.
sounds like you just tighten it too much loosen it a little then see
Jan 15, 2010 | Delta Faucet 470-DST Signature Diamond...
Kitchen faucet single handle pull-out. The base of
I have the same problem with an American Standard Reliant Kitchen Faucet that wont swivel anymore. I called American Standard and they are sending me the replacement parts to fix it free of charge, I have had mine 6-7 years and they said it was under warranty. Call 800-442-1902. Good Luck
Jan 09, 2010 | American Standard Kitchen Faucet 6310 020...
Single lever kitchen faucet with pull out sprayer is leaking.
same here..some duct tape should do the trick or you can pay for a repairman
Jan 01, 2010 | American Standard Kitchen Faucet 6310 020...
Single handel kitchen faucet: Over time the
Apr 22, 2009 | Delta Faucet Delta 470-BL-DST Signature...
Plumbing Logo
23 people viewed this question
Top Plumbing Experts
Donni Steen
Tom Chichester
Are you a Plumbing Expert? Answer questions, earn points and help others
