Question about Sony KS-60R200A
Why my Sony sxrd ks 60r200a projection tv turns yellow green color screen after i used it for 6 years and i already change the lamp?
What seems to be the problem that my sony sxrd ks 60r200a projection tv turns into yellow green color screen after i used it for 6 years and the lamp already been replaced?
  • 556 Answers
SOURCE: Tint is yellow green
bad light engine call sony and see if your tv is one on the extended warranty list.
Posted on Sep 21, 2009
  • 668 Answers
SOURCE: projection sony tv is yellow
Most likely it is the Optical Block. It has been a issue for most of the Sony LCD Rear Projections manufactured over the last 6 plus years. Your Model may still Qualify as a factory recall. What you need to do is to get in touch with Sony's Customer Service at 1800-222-SONY and see if it does Qualify.
If not, it is a expensive repair costing 1200.00 to a 1500.00.
I hope it still does Qualify for a recall,
Skyassoc
Posted on Jan 07, 2010
hardrocko
  • 1476 Answers
SOURCE: My Sony Grand Wega KF-WE50 Projection TV has a
shemk,
You have a serious problem. The optical block is bad. I have a tip at http://www.fixya.com/support/r7851924-sony_projector_yellow_or_blue_dots which explains the problem and what the solution would be.
Thanks for using FixYa and for the great rating. Please consider a testimonial. Thank you.
hardrocko
Posted on Feb 13, 2011
SD Tech
  • 14553 Answers
SOURCE: Sony Tv KS-60R200A..i replaced the lamp and the display still green in colour. any one know the problems? ..thank you.
A lamp will not cause display to change color---I would suspect a issue with the the optical light engine the set has.
Google your model number with "known problems" "light engines" and so on--the information is out there for free.
Posted on Jun 15, 2012
SD Tech
  • 14553 Answers
SOURCE: sony sxrd ks-60r200a diagram
Sony or Google the model number for service manual.
Posted on Dec 03, 2012
My sony tv sxrd has a greenish tint is this worth to fix
Actually what do you want to know? Provide more details please.
Jan 29, 2013 | Sony sxrd projection tv xl 5100 lamp ks...
Sony sxrd ks-60r200a diagram
Dec 03, 2012 | Sony sxrd projection tv xl 5100 lamp ks...
Jun 15, 2012 | Sony Televison & Video
I have the Sony KDS- 60A2020 60 inch TV. Recently, my picture has appeared more yellowish. Everyone on it looks like there dark yellowish or have fairly dark (bronze) sun tans. I changed my lamp yesterday...
I have a older 2006 SXRD rear projection TV. I had the same problem after the TV warmed up this yellow tint started in the corner and crawled its way down the TV. It turned out that Sony had a recall on the optic block of the TV. If you replaced the Lamp and adjusted the color this kinda sounds like the same problem. Here is a link explaining it. In this article it shows up as a green haze and blob, but in my TV it manifested as a yellow tint.
http://www.avsforum.com/avs-vb/showthread.php?t=1086180
Jun 09, 2011 | Sony KDS-60A2020 60" HDTV
My sony sxrd 60 comes on only for a sec than go off and red stanby lamp blinks 4 times,i have cleanned vents and checked bulb door,can only turn tv off and back on ,and still onlly get screen to show...
4 times red light blinking indicates problem with exhaust fan that is not running and tv shuts down instantly due to protection mode activation.
Please check exhaust fan and make sure its connector is plugged in and fan runs freely.
Thanks.
Apr 19, 2011 | Sony KDS-R60XBR1 60" Projection HDTV
DEVOLPING YELLOW LINE ON SCREEN
The yellowing of Sony’s KDF-60WF655 rear projection is a problem with the SXRD optical engine. This turned out to be a big problem on many of the SXRD TV's. Sony actually had a class action lawsuit that covered the optical engine for 5 years. My unit was replaced in June of last year (2009) about 1 month before the coverage ended. My unit had a bad yellow streak on the right hand side. Sony no longer covers the cost of replacement, as the class action suit has now expired. Sorry for the bad news. Its not clear if a new optical engine will suffer the same fate after a few years. Sony’s rear projection TV's are amazing and the picture rivals many of today’s LCD's and Plasma's. Any authorized Sony Tv repair shop will no exactly your problem and will be able to give you a fixed price to repair.
Hope this helps
Apr 01, 2010 | Sony Grand WEGA KDF-60WF655 60" Rear...
The color is off. Everything looks either green or yellow.
This is a light engine that is failing and a VERY common issue. Contact Sony because the warranty on these light engines was extended until June 30th of this year under bulletin E30020889. It is probably worth it as a consumer to call and see what they will do for you since this was really a design flaw. Please take a few moments to rate my answer. Thanks...
Nov 20, 2009 | Sony KDS-R60XBR1 60" Projection HDTV
Sep 20, 2009 | Sony KDSR50XBR1 50" Projection HDTV
TV background in green and most of the people have green tint
http://www.breakitdownblog.com/class-action-lawsuit-against-sony-for-green-haze-or-green-blob-sxrd-problem/
Dec 17, 2008 | Sony KDS-R60XBR1 60" Projection HDTV
SONY SXRD Powers off and on
the tv will cycle the lamp over and over when it goes bad. for some reason, it doesn't spit out the lamp error. the steady green blinking led means the tvs coming on. replacing the lamp will solve your problem.
Nov 25, 2008 | Sony Grand WEGA KDF-55WF655 36" Rear...
Sony KS-60R200A Logo
37 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
