Question about Roundup 1 Gallon Multi-Use Sprayer
How can i get the handle to pull up to pump in air ?
Turning the handle clockwise or counter clockwise does not release it so I can pump it up. It just comes completely out.
Having problems with the 3-speed pull string it doesn't seem to work after installation?
Remove the recoil pull starter rope surrounded by 3 or 4 hold down screws depending on your make then you wind up the coil starter pulley about 5 turns counter clockwise hold it there you feel a tension as you go abouts turning. Which is what you want to do. Once you reach 5 turns hold it do not let go,with one hand and with the other hand take a vise grips and clamp down the rope so that you don't lose your tension install your pull cord handle,take out the vise grips , then you release your cord pull starter rope..
Jan 09, 2018 | Garden
Our hot tub comes but won't heat water
Disconnect Spa from electricity. Remove access panel, remove Spa Pack controller cover, check all fuses. If bad, replace.., If good, replace controller cover and adjust pressure switch which located on the heater tube assembly.
If the heater or pump does not come on you may need to adjust one of these types of pressure switches counter-clock wise to turn on. If the heater or pump is staying on these may need to be adjusted clockwise.
3902.jpg Switch Type One:
There is a slot on the top portion of this switch for a flat head screwdriver, turning this counter clockwise (backing the threads out) will reduce the amount of pressure needed to turn on. Turning this clockwise will increase the amount of pressure needed to turn on. Never turn clock wise all the way in as this may cause damage to the switch.
3029.jpg Switch Type Two:
This Type of switch has a black star wheel to adjust, turning this counter clockwise (backing the threads out) will reduce the amount of pressure needed to turn on. Turning this clockwise will increase the amount of pressure needed to turn on. Never turn clock wise all the way in as this may cause damage to the switch.
800120-3.jpg Switch Type Three:
If the above does not help, check for continuity between the two connections on the pressure switch. If there is NO continuity with the switch in either position, then replace the pressure switch. If there is continuity in either position then the pressure switch is good.
If the pressure switch is good, test for voltage at the two lugs of the heater element. If there is voltage, then replace your heater element or the entire assembly. If no voltage is present, it could be your Spa Side controller keypad or your Spa Pack (main computer board).
Please ensure that your spa controls are set up correctly PRIOR to any troubleshooting.
If none of the above helps, contact me at: sales@oskopoolnspa.com for additional free help.
Danny
Apr 03, 2016 | Pool & Spa
How do I dismantle the push handle on my Hayter R48?
I am assuming you have the lever style ratchet point to fold and unfold the handle for storage. The way these lever bolts work is with a stationary nut or bolt head on the other side from the lever. If it slips when the lever is down then you can tighten it up by putting it in the up position that would be used to fold the handle and then rotate the lever clockwise a couple of times to tighten the joint. Like wise you can loosen it by going counter clockwise and remove it completely by turning counter clockwise until the lever comes off.
This link is a pdf of the manual.
http://www.hayter.co.uk/handbook_files/111-2087-B.pdf
Jun 13, 2014 | Garden
Hood release inoperable
Have someone push down and pull up on the hood while you pull the handle inside the car. Once you get it open, turn the bump-stops (one on each front corner of the area where the hood lands) counter clockwise to raise them. This should add some more pressure to help the hood "pop." Also, put some oil on the latch once it is open.
Jan 29, 2014 | 2007 Chevrolet Uplander LS Minivan
Motomaster motorcycle jack won't raise
Hi Bogdan:
Seems there may be some confusing instructions.
Here's what I would try. My approach would be intended to get the bike off the stand before I tried to trouble shoot the motomaster jack.
1) Use the handle to rotate the release valve to the right (clockwise) until it is snug.
2) Pump the jack to try to raise it. If it raises, then press the release pedal and use the jack handle to slowly rotate the release valve to the left (counter-clockwise) to lower the deck.
3) If it does not raise, I would use a separate jack to raise it, then follow the prescribed lowering procedure, and at the same time, use the control on the extra jack to manage the lowering.
Once you get it partially lowered, hopefully the motomaster jack will start to function and you can lift the bike far enough to remove your extra jack.
Hope this helps.
To let me know if it works for you, please reply as a comment to this post..
Jul 29, 2013 | Motormaster Cv Joint Front Female*-ATV
Super pump 11 keeps blowing the threaded adaptor off the discharge. I replaced the 11/2 inch pvc adapter twice. Both times the adaptor blew off. Any ideas.
Something is causing the pump to "dead head" which means it is trying to pump water through a closed pipe. Check any valves, the filter, heater etc.. downstream from the pump. Your water flow is being severely restricted. Hope that helps.
May 11, 2013 | Hayward Pool & Spa
How to replace headlight on left side of 1996 Dodge ram 2500 truck
Relatively easy, there may be a plastic cover on the back of the headlight aseembly. It comes off by releasing clips. The bulb is removed by turning counter clockwise. Then you simply unplug the wiring plug from the bulb,install the new one. Note : Wear gloves when handling new light, as the oils from your hands will cause the new light to not last long.
Mar 31, 2012 | 1996 Dodge Ram 2500 Club Cab
How do you internally adjust the hot water setting of a Symmons pressure balancing mixing valve?
  • To set the shower valve handle limit stop, remove the screw holding on to the handle and remove the handle.
  • Remove the round dome cover by turning in a counter-clockwise direction. At this point you will see a small slotted screw head that is visible in the valve cap.
  • Place the handle back on the valve stem (loosely) and open the valve turning the handle until the maximum desired position is reached. This may require turning the limit stop screw (T-34) counter-clockwise (see CAUTION above). To most accurately and safely verify the temperature of the hot water, place a thermometer in a tumbler of water filled from tub outlet.
  • Shut off valve and re-attach dome and handle.
  • Mar 02, 2011 | NRS Symmons Temptrol pressure balancing...
    How do you replace the headlight on a 2002 Daewoo Lanos
    Hi there, together with providing you the solution to the problem, I also took the liberty of going one step further in giving you steps on how to remove the headlight bulb.
    • Find the hood release handle and activate it, the hood should pop open.
    • Once the hood is popped open locate the hood secondary or safety latch and release it. Then finish opening the hood.
    • Locate and remove mounting clips for any plastic shields that cover the headlight lens mounting screws or clips.
    • Some headlight bulbs can be replaced by simply grasping the bulb socket behind the headlight lens and turn it counter clockwise to remove it. This will expose the headlight bulb.
    • If the headlight bulb socket is not accessible the headlight lens may need to be remove or obstructions behind the bulb removed to gain access to the headlight bulb socket.
    • To remove the headlight lens remove all mounting screws and clips that hold the headlight lens in place.
    • After the headlight housing has been removed from it's mounts, release the headlight bulb from the headlight lens housing (turn counter clockwise) the bulb will then come out of the headlight assembly. Once removed, visually verify that the replacement bulb is exactly the same as the failed bulb before to ensure a proper repair.
    • Clean the headlight lens free from all debris to help maintain the seal from the bulb to the lens. This will keep moisture out of the lens.
    • Install the new headlight bulb by turning the retainer ring or bulb clockwise.
    • Re-install the headlight lens housing and reinstall electrical connector.
    • Re-install plastic covers.
    After the job is complete turn the ignition key to the "on" position and activate the headlight switch. Observe the newly replaced headlight bulb to ensure proper operation.
    Glad to be of help!!!
    Jan 21, 2011 | 2002 Daewoo Lanos
    Hood release cable hard to pull
    chevys are bad for sticking hood cables i spray wd-40 on the latch and release handle and if you can try to spray some in the casing as well.
    Dec 28, 2010 | Chevrolet Celebrity Cars & Trucks
    Roundup 1 Gallon Multi-Use Sprayer Logo
    29 people viewed this question
    Top Roundup Garden Experts
    Mike
    Matt Olenzek
    Matt Olenzek
    Are you a Roundup Garden Expert? Answer questions, earn points and help others
