What pick was Tim Tebow in the draft - Computers & Internet
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • Computers & ... Master
  • 102,366 Answers
Tebow was drafted in the first round of the 2010 draft by the Denver Broncos with the 25th overall pick.
Posted on May 12, 2014
Tim Tebow knealing in protest
This is not the place for this.
Jun 01, 2018 | Computers & Internet
Install a attic vent
I know that you need to install the vent but if you can pick a different location it would be better for energy efficiency because of associated downdrafts that may occur. If you can locate the vent to go through a wall to the outside it would probably be better, If that is too big a project maybe consider an indoor venting system. If you wish to use the attic assure that you add a "draft trap" (see link) and assure you clean the dryer vent pipe at least 1/yr. http://plumbing.hardwarestore.com/51-600-dryer-vent-accessories/draft-blocker-inline-damper-602022.aspx
Jan 11, 2013 | Dryers
How do I pick out a drafting table?
The first step is deciding how much money you want to spend. You can find cheap drafting tables for around $150 or really fancy ones for around $800 such as this one http://www.restorationhardware.com/catalog/product/product.jsp?categoryId=cat1850041&productId=prod1617041
A Hann drawing table can cost upward of $1000.
The second step is if you want the table for a short or long period. If you want one for a short-term period then it is wiser to buy a cheaper one than to invest in a great one. If you plan to buy a new one in a couple years, then go for a cheaper one. Cheap and short term tables are generally folding tables. Long term and more costly tables are those with four sturdy legs. The last thing to consider is space. Foldable tables take up much less space than the big, sturdy tables.
Jan 07, 2013 | Furniture
What do I need to consider when picking out a drafting table for my workshop?
There are a few things to consider when picking out whichtype of drafting table to get:1. Determine if you need the table for long termor short term use2. Figure out the largestpossible paper you could use3. Calculate much room do youhave to store the drafting table4. Decide whether you want tosit or stand at your drafting table
May 29, 2012 | Furniture
My goodman furnace 80703 fan comes on ignitor glows burner starts , cuts off in 10 secs,furnace starts cycle again. home no heat
I am not a furnace tech but, there are several inputs to a gas valve. There must be an 1) electrical/mechanical indication that there is a draft fan running (to move potentially explosive gas so it doesn't accumulate), 2) adequate gas pressure to the valve, 3) the thermostat must be calling for heat 4) and electrical indication that there is an ignition source. In your scenario, you have the source of ignition, the gas valve is picking up the burner but the gas valve believes there is something missing so it shuts off the gas to the burner. In this case, I suppose you might not have enough gas pressure (is another gas appliance running or is the line to the furnace too small?), a thermocouple probably isn't the problem since the burner wouldn't pick up if the gas valve didn't believe the ignition source wasn't good enough. You could have a plugged chimney or exhaust pipe if it is direct vented since there is also a pressure switch that detects whether there is enough draft once the burner picks up. Really should call a furnace person especially if you don't have a carbon monoxide detector that you trust. If you think you are capable of continuing, you could jumper the various inputs the the gas valve one by one until the burner picks up and stays picked up. Whichever terminals you jumper that accomplish this, is the culprit. Look at the schematic on the side cover to the furnace for this information. Hope this helps...
Oct 01, 2011 | Goodman GMS90703BXA Heater
I installed a new colman mack thermostat in my camper witch has a colman ac unit now ac unit runs 5 min then shuts off for 3 min then starts again and keeps doing this . so I by past thermostat and it will...
if it is a programmable thermostat you can unhook thermostat and when it comes on select 3 instead of 1. As it sounds as though it is short cycling this happens in older houses with drafts. Hope this helps Tim
Sep 07, 2010 | Coleman Mach III Air Conditioner
Computers & Internet Logo
David Payne
David Payne
