Question about Pioneer Audio Players & Recorders
Pioneer panel key lock - Pioneer Audio Players & Recorders
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
Cant get picture when dvd selected on pioneer pdb r040
try a full factory reset then check to see if someone has turned on the mode or channel block, some tv,s you can block the dvd mode through the parental guide lock
Mar 31, 2013 | Pioneer PDP-4280HD 42 in. Plasma...
How do i remove a pioneer deh-p4500mp radio from the car
The removal keys for this unit are not the usual "U" or "HorseShoe" keys. Disconnect the live feed before starting.
You require the Pioneer removal keys to avoid damaging the unit. Your local accessory dealer may loan them but cheap enough to purchase. Once the unit is out you simply gently pry at the locking tabs which retain the cage into the dash facia. I normally use a firm electrical screw driver for this part.
Remove the loom and antenna etc. from the cage connectors and it should be free
Mar 29, 2011 | Pioneer DEH-P4500MP CD Player
When i turn on the video projector and send me this message"the panel keys are locked "
Your projector key panel locked you have two option to operate the projector
1 . Use remote control press MENU the menu window displayed.
use DOWN ARROW key and select SET SETTING.
press ENTER
use DOWN ARROW key to select PANEL KEY LOCK.
press RIGHT ARROW key to OFF the panel key lock
press ENTER and then press MENU key to exit the menu.
now you panel keys are working
2. If you loss your remote control then;
When the key panel lock is ON keeping the power key on the projector key panel pressed for 10 seconds turns the projector ON when it is in standby mode, and turns the projector to standby mode when the power is on. If you keep pressing the MENU key for about 10 seconds when the power is ON, the lock will be released and "panel key lock" is automatically set to OFF.
Feb 05, 2011 | Sony VPL-CS7 Multimedia Projector
Lock control program after open cover lid of Pioneer PDP434 PG
If you had power this set on with the back off it will not work without closing the switch again and entering serv mode and reactvating . Call pioneer customer serv to get info to reset the unit. Must have pioneer remote to do this reset.
Aug 29, 2009 | Pioneer PDP-4360HD 43 in. Plasma...
Lost remote controller of Pioneer VSX-D506S
You can buy Original Pioneer Remote from HERE for VSX-D506S
Feb 10, 2009 | Pioneer VSX-D506S Receiver
IN DASH PIONNEER RADIO
you need pioneer keys. long thin keys with slightly barbed ends. Your local shop will probably do it for free if you stop by.
Dec 25, 2008 | Car Audio & Video
Pioneer deh-p750 locking
Try pressing the reset button. It is usually in a little recessed hole on the front panel.
Aug 28, 2007 | Pioneer DEH-P750MP CD Player
19 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
Ian Summerfield
Ian Summerfield
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
