Question about iHome iP1 Speaker System for your iPhone iPod iP1 iP1
I turn it on and everything seems fine but it wont play music from my iphone or an audio jack.
It has been playing fine up until today and I never had any problems and I dont think anything would have cause anything to move inside.
When my iWork's is paired with my iPhone 6 splus it plays music for a bit then starts playing a busy signal then plays music for a few seconds then the busy signal again
iPhone 6 not working with hands-free on a Toyot... ' Apple Support ...
discussions.apple.com > Support > Apple Support Communities
Apple Inc.Sep 20, 2014 - I received the iPhone 6 today and registered the device on my Toyota... The iPhone 6 paired with the audio system, but whenever the phone receives a ... I also notice sometimes the vehicle shows 0 signal strength, when in ...Missing: iwork's ‎splus ‎random ‎busy
iPhone 6 dropping WiFi constantly ' Apple Support Communities
Apple Inc.Sep 20, 2014 - Got my iPhone 6 today and it keeps dropping my WiFi signal in my ....kick of wi fi constantly worse part is I was busy listening to music app last ...Missing: iwork's ‎paired ‎splus
Community: Using iPhone ' Apple Support Communities
Dec 25, 2015 | Cell Phones
Rca 5 disc changer rs2130i
Buy a lead with headphone jack to red and white RCA/phono. Jack goes to iPad/iPhone/MP3 player. Red and white goes to Aux/Game/Line input socket if the unit has one. Play your music.
Sep 01, 2014 | RCA RS2130i Shelf System
When i plug my iphone 3gs into the ilive itp100b i try to play my pandora music app and the music plays for 2 seconds and then stops. the music on the app continues to play on the phone but the ilive isnt...
I have this exact same problem... audio I loaded on through itunes play perfectly... songs, audiobooks, podcasts, etc, as well as input from my TV and the build in FM radio, but anytime you try to use any 3rd party radio app on the iphone, you get like 2 seconds of audio and then nothing, and the app usually has some text that says, "No Volume Available".
From research, it seems that the iLive company is to blame as they did not update the firmware to work correctly with iOS 4, so it is their problem and not the iPhone. I am returning my device and getting another brand that supports iOS 4
Dec 21, 2010 | Audio Players & Recorders
Hiya i have recently moved my computer from the front room to a bedroom and plug everything in, i thought everything was fine until i tried to play some music so i checked all the connections/leads and...
Hi try looking over it again with the help of this https://www.download.p4c.philips.com/files/s/spa7300_79/spa7300_79_dfu_eng.pdf just make sure all connections are pushed in properly as those plugs have a tendency to not plug in all the way
May 04, 2017 | Philips SPA7300 2 Speakers
Using iphone ipod with compact audio system.
If your audio unit has an audio input plug and an auxillary function, you should be able to run the 3.5mm jack from the headphones socket on your iphone to the audio input of your audio system, then select aux on the audio system and you should be able to hear any music played on your iphone through your audio unit. Good luck.
Jun 07, 2010 | Sharp KB6024MK 1000 Watts Microwave Oven
For some reason my ipod touch won't play when I plug it into my stereo. It is playing out of the ipod itself. How do I turn this off.
Hello.
This is a very common problem, you may have to get a different jack that works with the headset jack thats on the iPod. iPhones and iPods have a weird style jack on the top that wont allow most headphone or 3.0mm to 3.0mm jacks to go fully inside the jack causing it so there is not connection with the jack itself in the iPod. You can check this by turning the volume up and down using the rocker buttons on the side while you are at the home screen with no music playing and see if it says speaker or headphones when your turn the volume up and down. Speaker means there is no jack connection, headphone means that there should be music playing through the stereo. Thats using the jack.
If your talking about an iHome or other direct plug in stereo specifically for the iPods and iPhones, make sure that the dock is the correct dock for the iPod, and make sure that it is pressed fully down onto the dock. If all that is correct there should be no problem. If the problem still is happening, it may be your stereo. =/ Goodluck! Hope this helps!
Dec 07, 2009 | Apple iPod touch
When I plug my iPhone into the USB it doesn't
ANSWER: The headphone jack will not charge your iPod. Only the USB will charge your iPod. However, the headphone jack will play music, but the USB will not play music from your iPod.
REASON: The headphone jack does not provide any power to charge your iPod. It isnly has enough power to recieve a music signal.
REASON WHY YOU CANNOT PLAY IPOD THROUGH THE USB: The USB is only intended to be used with a flash drive or external hard drive with a folder structure containing either .mp3 or .wma files. The way the USB works on the system is that it reads all the files and folders on the entire device and will say "reading" until it reads all the files and folders. This should only take a few seconds but if there is tons of files it may take longer. Main problem: An iPod contains much more than just music files and folders - it contains an entire operating system. Worse, the operating system which the iPod uses is protected, keeping other devices except for iTunes from reading the music files.
TO PLAY MUSIC FROM USB (NOT IPOD): You will need to use a flash drive or external hard drive with your USB. This device can only contain music, and the music must be organized into folders. Your iPod will not work. However, you can use Auxiliary input using a cable which both ends are 1/4" headphone jacks, one end going to the iPod and other plugged into your stereo.
SOLUTION: To charge your iPod, you need to plug it into USB. However, to play music, you need to plug your iPod into the headphone jack.
Good Luck! - Chris Proia
p.s. Here is the User Manual for your XDM6350 : http://www.dualav.com/support/manuals/xdm6350.pdf
Aug 13, 2009 | Dual Electronics XDM6350 Car CD/ MP3...
Sound problem
if ur usung win xp OS U shold restore OS (pgm-accessories-system tool.restore )to back date while it in workinfg fine
Jul 19, 2008 | Edirol UA-4FX External Sound System
Shaker wont turn on
you have to hold the play pause button until you hear a noise and music starts playing
Mar 04, 2008 | SanDisk Sansa Shaker SDMX9N-512 MP3 Player
iHome iP1 Speaker System for your iPhone iPod  iP1 iP1 Logo
127 people viewed this question
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
