Question about Ruud UBHC Air Conditioner
I have a Ruud 90% furnace (18 yrs.old) Several days ago, I had a complete ice-over of the evaporator coil. Filters are clean, and airflow unrestricted. After defrosting coil (48 hrs.) while testing, I note that the blower only runs for 30-45 sec. before shutting down. When I set the stat to "fan on", it does the same thing. It seems to me that the blower never gets up enough speed (might be my imagination). I'm assuming that the problem is not in my stat or wiring. Does this sound more like a problem in the control module, the blower capacitor, or the blower itself. The blower turns freely by hand. Any help would bemuch appreciated. Thanks, Jim
  • 43 Answers
The motor shutting off after 30-45 seconds means it is probably getting hot and shutting off on thermo overload safety in motor. Two things can cause this: #1 is the motor is defective. #2 the run capacitor has gone bad. If you want to try and save money replace the run capacitor 1st and try it. If that doesn't work replace the motor. You would replace the run capacitor at same time anyway.
Posted on Jun 23, 2009
What causes an air conditioner to ice up
If it is a Heat Pump and you are talking about the outdoor unit, icing is a normal part of the cycle when it is operating in cold weather.
If you are talking about the indoor coil section, ice on the coil is caused by low airflow across the coil. The filters may have to be changed. The blades on the blower may be dirty. These can be cleaned by removal of the blower section. If there has been inadequate, damaged or non-existing filters, the air entering side of the coil may be blocked (dirty) .
Aug 16, 2014 | Ruud Central System Air Conditioner
What causes insufficient air flow across evaporator coils
Dirty filters is number one, other blocked ducts.
Bad or slipping blower motor
Slipping belts , if you model has it/ them.
Jul 20, 2014 | Ruud RGTC07ERBGS N/A Achiever 75000 BTU...
Freezing pipes and water dripping on to motherboard of the heater in a Ruud UAKA-030JAZ system. Help?
More than likely, the system is low on refrigerant and the copper line-set is freezing up and water is dripping onto the board in the furnace (and other things) because it is an upflow system with the evaporator coil on top. Other things to check would be:
1. Dirty/clogged filters in the return air system.
2. Fan motor not working inside furnace. (The Blower)
3. Coil dirty/clogged which could be checked by the amount of airflow coming out of the vents. This would have to be cleaned by a technician.
Most of the time, it is the charge which also means there is a leak in the refrigerant system somewhere and needs to be fixed. Hope this helps you out! Good luck.
Jun 19, 2012 | Ruud UAKA030 Air Conditioner
Evaporator coils are freezing up. I took off the side cover and it is a solid sheet of ice covering 90% of the coils.
Hello, ice will form for one of two raesons, either low airflow or a low refrigerant charge. Start by checking the filter to make sure it is clean, then check the blower wheel and make sure it is clean. If the unit is clean then the unitnis low on refrigerant and will require a hvac tech to come out and recharge the unit.
Jul 10, 2011 | Heating & Cooling
Not cooling
Turn your System OFF and put the Fan switch at your thermostat in the FAN or ON position. Allow it to run like this for 4 hours minimum. Before turning the system back on, ensure the air filter(s) and coils are clean. Also make sure all of the supply registers are open. All of these items affect airflow. Improper airflow is the number one cause of an iced up evaporator coil (as indicated by your observation of ice on the black hose). If, after doing all these things, you continue to have a problem, you most likely have a refrigerant problem (not enough or a restriction). This would require paying a CFC certified electrician to diagnose and repair. Try the air filters, coils, and registers first. :-)
May 29, 2010 | Ruud Central System Air Conditioner
The inside RUUD AC unit has ice and no cold air is blown
it is likely low on coolant or as some say "freon" that or the indoor fan motor has not run properly. let it thaw completely by shutting it off and just turning on your fan switch from auto to the on positon. if you begin to feel air flow eventually you need coolant added b/c you probably have a leak from the system being old
Sep 13, 2009 | Ruud UBHC Air Conditioner
18 year old Janitrol Heat Pump freezing up.
i would get someone to check your refrigerant levels have you ever had the evaporator coil flushed and cleaned? proper refrigerant levels and proper airflow across coils are extremley important not to scare you but 18 yrs is a long time on a heat pump 9-12 years is the point where they really loose there efficiency going for a newer one would probably cut your operating cost in half if not more depending where you live there are a lot of people not familiar with heat pumps so i suggest finding a company that specializes in them to service your unit
Jul 30, 2009 | Ruud UBHC Air Conditioner
Both circuit board lights blink at the same time when unit turns on. Air pressure out of vents is low. Air is cool but not cooling house down.
your filters might be plugged. if you just changed or cleand the filters and they were plugged the evaporator coil might be dirty not allowing the proper amount of air flow. The evaporator is usualy lokated right above or below the furnace in a coil case that has several screws holding the front panels on. Take a look at the filters and evaporator and make sure their clean. Also wash the out side condenser coil with a garden hose with nozzel. make sure you spray strait into the coil and not at an angle. it will bend the fins. start at the top and work your way down. hope this helps you out.
Jun 15, 2009 | Ruud UBHC Air Conditioner
I THINK THIS IS THE RIGHT MODEL. FREEZING UP. NEED TO FIND COILS.
The condenser coil is in the outdoor unit. Turn off the power. Take a garden hose without the nozzle. You want to use gentle pressure. Just simply using your thumb to control the spray. Spray the water up at an angle under the slanted lovers. use a generous amount of water. you should see the dirt coming our. You will have to take the cover off to clean that side of the coil. Be careful so you do not get the electrical controls wet when the door is off. The Evaporator coil is located in the supply air plenum downstream of the airflow. ( the top if its in a basement). You probably will need to open the ductwork.
Good luck.....
May 02, 2009 | Ruud UAKA042 Air Conditioner
Air Conditioning
Open the access panel on the air handler in the attic and take a look at the evaporator coil. If you have no airflow, and you just changed the air filter, then you probably have a buildup of airborne crud on the coil that's blocking airflow. If you do have a layer of buildup blocking airflow through the coil in the air handler, just take a $5 fin comb and scrape all the crud off the coil fins. This can make a dramatic difference. Hope this helps! ;)
Aug 09, 2007 | Ruud UAKA030 Air Conditioner
Ruud UBHC Air Conditioner Logo
209 people viewed this question
Top Ruud Heating & Cooling Experts
Bill Long
Tim Whalen
Dennis Boxerman
Are you a Ruud Heating and Cooling Expert? Answer questions, earn points and help others
