Question about Home Fencing
How do I fix my floor jack. it just goes up and down a
I have a 8287 series, when I was lifting the jacks a role pin fell out of somewhere and now the passenger side jack will not move up or down, we're was that role pin located so I can fix this
Hello Doug...
No hits on "8287" as a meaningful jack "IDENTITY".
Just a guess here... but if you want to get that jack out... you'd be wise to get a block of wood... a jack stand... and relieve the DISABLED jack... by jacking higher (installment plan).
Stuck jacks can be quite dangerous...
Get it out of there... Then (and ONLY then)
Look to the handle linkage... for your "roll-pin"...
You will be proud
3 ton Low Profile Steel Heavy Duty Floor Jack with Rapid Pump
Aug 23, 2016 | Cars & Trucks
How can i fix a floor jack it does not go up
that depends did it leak oil out of the shaft seal ? if it did you could add more oil to resavor but that would not be safe as oil will continue to leak out seal and jack will fall down , Most auto parts stores sell hyd jack oil in a can
Sep 22, 2014 | Cars & Trucks
My mvp 3ton floor jack will pump p but wont hold
First you need to check and see that it is full of fluid. It could be the release valve is leaking. It is the valve you unscrew to let the jack down. You need to unscrew the whole assembly and inspect it to determine condition, fix as required.
Sep 19, 2014 | Cars & Trucks
Floor jack goes up then comes down slowly
There us a leak inside in one of the internal seals, unless it is a very expensive jack it usually is not worth repairing.
Mar 08, 2012 | Cars & Trucks
2 Tonne Wayco hydrolic floor jack wont stay pumped up, imdieately goes back down. How do i check the oil level.
Lots of times, there is a rubber plug in the side of the casing to remove to check the oil level. Fill up until it just runs out when sitting upright.
Jan 30, 2010 | Hand Tools
Floor jack won't stay
If you are having a problem with the jack slipping...if its Craftsman , they may take it back and provide a replacement. Even if you could fix it, it never works that same. It is not worth your life. I know, I lost my husband when a jack slipped 3 years ago this month.
Jun 01, 2009 | Hand Tools
Craftsman 3 ton floor jack will not stay up
you need to bleed the air from the cylinder. there should be an air bleed or else you bleed it at the relief needle. also, if it still leaks down after you bleeed out the air, the seat for the relief valve or the seals at the relief valve cartridge are worn
Apr 01, 2009 | Home Fencing
Door sag chevy suburban
put a car floor jack under the door and jack it up loosen the screws and try to close the door, you might need shims or washers. tighten each screw top bottom each one til its down so door must be leviled on the jack then bolt it on one at a time
Jan 10, 2009 | 1999 GMC Suburban
1999 passats motor mounts how do i fix them
You will need to jack the car up as far as possible, then put it on jack stands and remove the floor jack, then put a thick piece of wood on the jack pad and take the weight off the Motor Mounts, this will allow you to get the bolts out and remove them, make sure you use jack stands and at least a 3,000 LB capacity floor jack. BE CAREFUL!
Nov 12, 2008 | 1999 Volkswagen Passat
My hp dv1000 fell to the floor and the geek squad at best buys said...
Unfortunately, unless you have the skill to disassemble the laptop and solder a new DC jack onto the motherboard you may be stuck. This is a rather difficult procedure and DC jacks alone can run between 20-80 bucks each. I wish you luck
Apr 23, 2008 | HP Pavilion dv1000 Notebook
Home Fencing Logo
402 people viewed this question
Top Home Fencing Experts
 Russ Hill
Russ Hill
Tom Chichester
ray gallant
Are you a Home Fencing Expert? Answer questions, earn points and help others
