Question about Pride Health & Beauty
How do you wire two 12 volt marine battery to make them 24 volts
    Habit-Forming:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 88 Answers
Be careful or sparks will fly! Work out how you want your batteries to sit together while remembering that you will be connecting battery ONE's positive post to Battery TWO's negative post. Measure the short length of heavy connector cable needed and note the battery post type and size buy cable and make clean secure connection. The output from the remaining two posts will be 24 volts. N.B. always use matching batteries of same age.
Posted on May 02, 2016
  • 118 Answers
SOURCE: Pride victory mobility scooter
A fully charged battery should be over 12 volts. You may need to change your batteries.
Posted on Nov 27, 2008
  • 103 Answers
SOURCE: I AM ONLY GETTING 9.3 VOLT TO THE MOTOR
Just to be sure have the batteries tested with a load tester. Then ohm test the brake. It should be around 35 ohms.
Posted on Mar 09, 2009
gewiz
  • 1263 Answers
SOURCE: electric mobility Rascal 265 LE scooter won't run
Are you sure the batteries are charged ? Is the Battery charger charging ok ? Are the batteries connected ? take off seat and cover to check battery leads, does the key fit in the lock okay ?
Posted on Jun 13, 2009
  • 177 Answers
SOURCE: WHAT ARE THE NEWEST AND LONG LASTING BATTERIES I
Hi. When you are looking for good quality batteries, they will have a 1 year warranty on them. If you get offered only a six month warranty, don't buy them. Good batteries weigh more than cheaper batteries, because they have more lead in them.
To get a good distance, you need to fit the biggest batteries that will physically fit in your machine.
Batteries are designed to handle a certain number of "charging cycles". If you run a battery down by approx 75%, you will only get a small number of "charging cycles". If you only use 25% of the batteries capacity, you will get 100's of charging cycles.
Gel batteries seem to be the better choice. Most AGM sealed batteries are designed to be stand-by batteries. They will work fine in your machine but only for light use. I have seen these batteries last for 7 years, but only for light use.
Good luck. Neil.
Posted on Jun 03, 2010
Testimonial: "thanks , most helpful !!!"
  • 177 Answers
SOURCE: batteries die fast on my mobility scooter.
Hi. What size batteries you buy will be limited to the amount of room you have in the machine.
17 amp hour batteries are really a bit small for any mobility equipement. A lot of power chairs have 35 or 40 amp/hour batteries.
Buy the biggest that will fit into the available space.
Batteries are designed to perform a certain number of "charge cycles". If you run your batteries down by 75%, you will only get a small number of "charge cycles". If you only use 25% of the batteries capacity, you will get 100's of "charge cycles".
The best I have seen is 7 years out of a set of batteries. Short trips and recharging after each trip is the reason.
Good luck. Neil.
Posted on Jun 04, 2010
Testimonial: "thanks again"
How do I wire two tandem batteries for an electric scooter
Tandem batteries... is a fairly loose term to be dealing with on batteries... SIMPLY BECAUSE THEY ARE EXPLOSIVE.
TANDEM voltage
(assuming you were trying to achieve 24 volts with 2
12 volt batteries would NORMALLY be called serial...
Where as to increase AMPACITY ... called "parallel."
Rather than risk severe burn, blindness (end of life
experimenting with EXPLOSIVES...
You need to go back to your source for better information ...
or
Provide better information here... Pretty please
Jan 12, 2017 | Electric Health & Beauty
My son and I have 2 12 volt batteries which should be drawing 24 volts to our trolling motor but is not. We have a separate 12 volt starting battery what is going on.
If you connect 2 12 volt batteries in series to get 24 volts and you don't get it, then one of the batteries has a bad cell or you have a poor connection between the two.
Apr 26, 2016 | Boating
Marine diesel 24 volt system, 4x6 volt batteries
If it is a 24 volt starter why not?
Aug 31, 2014 | Cars & Trucks
My motor guide trolling motor died . It was on the new boat that I bought in 2011 . Checked the breaker fuse and it's good, tested the wiring with a volt meter couldn't find anything. Could it be the micro...
do you have it hard wired to pos and neg or does it have the 3 prong plug in switch ..if 3 prong its for a 24/36 volt motor wont work on 12 volt less you have the 12 volt plug
Oct 16, 2013 | Boating
Hooking up a 36 volt charger to three 12 volt batteries in series
first of all do you have 3 or 4 batteries your cranking battery is not to be wired into this 36 volt if you have 4 batteries you have 3 for trolling motor and 1 cranking battery look on your charger see if the banks or numbered 1 2 3 4 .... you got to find what battery is # 1 depends on how they hooked in series if you hook charger on wrong battery most the time a red light comes on telling you wrong battery move wires till green lights come on all batteries.# 4 goes to cranking battery if you only have 3 batteries you don't have 36 volts you have 24 volts and a cranking battery if so # 3 goes to cranking battery
Aug 29, 2013 | Minn Kota Boating
I have a 767P motorguide that is 12/24 volt. The
Yes and ...no. I'd look for one made for marine use... although any good quality switch will work...for a time. Corrosion will catch up with a :cheapie."
Try these guys... http://www.trollingmotorparts.com/default.aspx/MenuItemID/184/MenuGroup/Home.htm
Good Luck and God Bless, Luckymann77
May 10, 2010 | MotorGuide STANDARD MOTOR REPLACEMENT...
No power like it is running on 12 volts need to know how to wire for 24 volts
I would first put a voltage tester on there and see if your getting 12 or 24 volts... You could have bad batteries... As far as running a 24 volt system the best thing to do is to set it up based on the owners manual... My 24v system has the position from battery (1) one going to the motor (put a fuse on that thing), the negative on battery (1) one goes to the position on battery (2) two. The negative on battery (2) two goes back to the motor.
Feb 27, 2010 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Wiring diagram for 12/24 volt system
here is a wire diagram. follow the pictures. you can do fuses but i like inline breakers. you can get them at your local outboard dealer.e9e9f8a.jpg
Nov 05, 2009 | Boating
Converting From 12/24 to Starght 24 Volt
if it is 24v. then you need to connect 2 battery in parallel. since the battery is only 12v.
if one battery is shoing red and the other is sohwing green, that means you are using 12v only, not the 24v.
connetion as follow:
positve of battery 1 to the motor, the negative of battery 1 to postive of battery 2. the negative of battery 2 to the motor.
Oct 20, 2008 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Health & Beauty Logo
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
