Question about Whirlpool duet Washing Machines
02 code 4619 702 05521
I need restriction code
Hi, To which network has your Nokia X2-02 has been restricted to? You can unlock a Nokia X2-02 safer and easier using unlock code. You can get the accurate unlock code for a Nokia X2-02 from www.Unlock-Zone.Com at affordable cost with free step by step unlocking instructions. Good luck mate.
Feb 12, 2013 | Nokia X2-02 Mobile Phone - Unlocked/No...
Nokia c2-02 probulam no sim working. Shows enter code undo
Hi, I think your mobile must be network restricted. You must unlock it. The safest and easiest way to unlock a Nokia C2-02 is to unlock using unlock code. You can get the unlock code for a Nokia C2-02 from www.prounlocking.com/nokia-c2-02/rs8wp9/ at affordable cost with easy unlocking instructions.
Here are the steps for unlocking a Nokia C2-02,
1 - Switch on your Nokia C2-02 without any sim card.
2 - Don't bother as to what is displayed on your Nokia C2-02.
3 - Compose #pw+CODE+1#.
4 - The Nokia C2-02 would then display the message "SIM Restriction Off" and will be unlocked!
Note :For Nokia C2-02 mobile phones locked to the network Fido or Rogers in Canada follow these instructions :
3 - Compose #pw+CODE+7#.
Sep 27, 2012 | Cell Phones
I need the unlock code for nokia C2-02
Visit the site Onlinegsmunlock.com/nokia/rs7wp8/ get the unlock code and unlock it easily.
Jun 26, 2012 | Cell Phones
Fix camshaaft timming on 2004 dodge ram1500 47cui
For this problems,check the help links below,click the link to o through its troubleshooting procedure :-----Crankshaft and camshafts timing marks? http://technoanswers.blogspot.in/2012/02/crankshaft-and-camshafts-timing-marks.html---------- dual over cam timing mark details? http://technoanswers.blogspot.in/2012/02/saturn-vue-30-dual-over-cam-timing-mark.html---------- How to replace Adjustable Camshaft timing solenoid? http://technoanswers.blogspot.in/2012/02/how-to-replace-adjustable-camshaft.html------------ How to Inspect Camshaft? http://repairhelpcenter.blogspot.in/2012/02/how-to-inspect-camshaft.html
camshaft Timing specifications? http://technoanswers.blogspot.in/2012/02/ford-mondeo-st220-camshaft-timing.html
Crankshaft Front Seal? http://schematicsdiagram.blogspot.com/2011/12/crankshaft-front-seal.html
How test cam shaft? Testing Car Camshaft? http://repairhelpcenter.blogspot.in/2012/02/how-test-cam-shafttesting-car-camshaft.html
How to service Cam Shaft? Camshaft servicing? http://repairhelpcenter.blogspot.in/2012/02/how-to-service-cam-shaft-camshaft.html
How to replace Camshaft? Replacing Vehicles Cam Shaft Assembly? http://repairhelpcenter.blogspot.in/2012/02/how-to-replace-camshaft-replacing.html
For OBD code problems check the list of help links below. Click the link below to go through its procedure.
Diagnostic Code P2195? http://schematicsdiagram.blogspot.in/2012/02/diagnostic-code-p2195-on-toyota-avalon.html
Diagnostic code P1330? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p1330-on-kia-2wd.html
Diagnostic code P0700, P1330, P1121? http://technoanswers.blogspot.in/2012/02/diagnostic-code-p0700-p1330-p1121-on.html
shows error code P1330? http://technoanswers.blogspot.in/2012/02/2003-kia-sorento-shows-error-code-p1330.html
OBD code P1330? http://technoanswers.blogspot.in/2012/02/obd-code-p1330-on-2003-kia-sorento.html
OBD code P01300? http://technoanswers.blogspot.in/2012/02/obd-code-p01300-on-toyota-rav4.html
OBD code P0768? http://repairhelpcenter.blogspot.com/2012/01/obd-code-p0768.html
Evaporative Emissions System codes details? http://schematicsdiagram.blogspot.com/2011/11/evaporative-emissions-system-codes.html --------------- Engine Misfire codes?
http://schematicsdiagram.blogspot.com/2011/12/engine-misfire-codes-on-chevrolet.html
Misfire on cylinder 4?
http://schematicsdiagram.blogspot.com/2011/12/misfire-on-cylinder-4.html
ABS trouble codes for all models?
http://repairhelpcenter.blogspot.com/2011/11/abs-trouble-codes-for-all-1994-00-acura.html
Diagnostic code P0010? http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0010.html
Diagnostic Code P1396?
http://howtobyme.blogspot.com/2011/11/diagnostic-code-p1396.html
Code P0452?
http://howtobyme.blogspot.com/2011/11/code-p0452.html
OBD code P0172 on Buick?
http://howtobyme.blogspot.com/2011/11/obd-code-p0172-on-buick-park-avenue.html
DTC Code P0321?
http://howtobyme.blogspot.com/2011/11/dtc-code-p0321-on-buick-park-avenue.html
Error Code P0471?
http://howtobyme.blogspot.com/2011/11/error-code-p0471-on-2007-dodge-ram-3500.html
P0304 Error code?
http://howtobyme.blogspot.com/2011/11/p0304-error-code-on-dodge-neon.html
OBDII scan is receiving NO BUS CODE?
http://howtobyme.blogspot.com/2011/11/obdii-scan-is-receiving-no-bus-code.html
How to Clear OBD error Codes?
http://repairhelpcenter.blogspot.com/2011/11/how-to-clear-obd-error-codes-on-acura.html
Diagnosis and Testing Car Components?
http://vwrepairhelp.blogspot.com/2011/11/diagnosis-and-testing-car-components.html
Diagnostic Trouble Codes list?
Part 1.
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura_18.html
Part 2.------
http://repairhelpcenter.blogspot.com/2011/11/diagnostic-trouble-codes-list-for-acura.html
OBD Code is cleared but check engine light will not RESET?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-is-cleared-but-check-engine.html
Diagnostic Code 43 and 71?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-43-and-71-on-1991.html
Code P0132?
http://schematicsdiagram.blogspot.com/2011/12/code-p0132-on-acura-tl.html
P0031 code?
http://schematicsdiagram.blogspot.com/2011/12/p0031-code-on-dodge-dakota.html
How to get diagnostic Code without OBD Scanner on Pre 1995 cars?
http://schematicsdiagram.blogspot.com/2011/12/how-to-get-diagnostic-code-without-obd.html
OBD-II Trouble Code P0300?
http://schematicsdiagram.blogspot.com/2011/12/obd-ii-trouble-code-p0300.html
Getting diagnostic code P0016?
http://schematicsdiagram.blogspot.com/2011/12/getting-diagnostic-code-p0016.html
How to Read Codes from Check Engine Light?
http://schematicsdiagram.blogspot.com/2011/12/how-to-read-codes-from-check-engine.html
Diagnostic Code P0540 continues to return and the MIL light is on?
http://schematicsdiagram.blogspot.com/2011/12/diagnostic-code-p0540-continue-to.html
DTC Trouble Code P0401?
http://schematicsdiagram.blogspot.com/2012/01/dtc-trouble-code-p0401.html
Car misfires and error code P0306 and P0303 is shown?
http://technoanswers.blogspot.com/2012/01/car-misfires-and-error-code-p0306-and.html
Diagnostic code P0463?
http://technoanswers.blogspot.com/2012/01/diagnostic-code-p0463-on-ford-f250.html
Check engine light with codes P2195 and P2197?
http://howtobyme.blogspot.in/2012/01/check-engine-light-with-codes-p2195-and.html
Diagnostic error code P0121,P0505,P1000,P2101,P2104, P2110,P2135,P2106?
http://technoanswers.blogspot.in/2012/01/diagnostic-error-code.html
P0174, P0037 and P2197?
http://technoanswers.blogspot.in/2012/02/p0174-p0037-and-p2197-on-toyota-rav4.html
P0352 Obd code?
http://technoanswers.blogspot.in/2012/02/p0352-obd-code-on-toyota-rav4.html
Error code p0402?
http://technoanswers.blogspot.in/2012/02/error-code-p0402-on-ford-escape.html
Obd Code P0763?
http://technoanswers.blogspot.in/2012/02/obd-code-p0763-on-lexus.html
OBD code P0301, P0430 and P0174?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0301p0430-and-p0174.html
OBD code P0500?
http://schematicsdiagram.blogspot.in/2012/02/obd-code-p0500-on-lexus-rx-300.html
This will help.
Thanks.
Feb 28, 2012 | 2004 Dodge Ram 1500
New 02 sensors but still have codes
massair flow meter or drawing air which confuses 02 sensor cos of wrong air fuel mix
Feb 15, 2012 | 1999 Kia Sportage
Im getting code P2253 on my 04 Saturn vue with 3.5l V6. Anyway to tell which O2 sensor it is? Thxs Bill
P0804 is the highest OBD-II trouble code.
Here's your Oxygen sensor codes.
P0130 02 Sensor Circuit Malfunction (Bank I Sensor 1)
P0131 02 Sensor Circuit Low Voltage (Bank I Sensor I)
P0132 02 Sensor Circuit High Voltage (Bank I Sensor 1)
P0133 02 Sensor Circuit Slow Response (Bank 1 Sensor 1)
P0134 02 Sensor Circuit No Activity Detected (Bank I Sensor 1)
P0135 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 1)
P0136 02 Sensor Circuit Malfunction (Bank I Sensor 2)
P0137 02 Sensor Circuit Low Voltage (Bank I Sensor 2)
P0138 02 Sensor Circuit High Voltage (Bank I Sensor 2)
P0139 02 Sensor Circuit Slow Response (Bank 1 Sensor 2)
P0140 02 Sensor Circuit No Activity Detected (Bank 1 Sensor 2)
P0141 02 Sensor Heater Circuit Malfunction (Bank 1 Sensor 2)
P0142 02 Sensor Circuit Malfunction (Bank I Sensor 3)
P0143 02 Sensor Circuit Low Voltage (Bank I Sensor 3)
P0144 02 Sensor Circuit High Voltage (Bank I Sensor 3)
P0145 02 Sensor Circuit Slow Response (Bank 1 Sensor 3)
P0146 02 Sensor Circuit No Activity Detected (Bank I Sensor 3)
P0147 02 Sensor Heater Circuit Malfunction (Bank I Sensor 3)
P0150 02 Sensor Circuit Malfunction (Bank 2 Sensor I)
P0151 02 Sensor Circuit Low Voltage (Bank 2 Sensor I)
P0152 02 Sensor Circuit High Voltage (Bank 2 Sensor 1)
P0153 02 Sensor Circuit Slow Response (Bank 2 Sensor 1)
P0154 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 1)
P0155 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 1)
P0156 02 Sensor Circuit Malfunction (Bank 2 Sensor 2)
P0157 02 Sensor Circuit Low Voltage (Bank 2 Sensor 2)
P0158 02 Sensor Circuit High Voltage (Bank 2 Sensor 2)
P0159 02 Sensor Circuit Slow Response (Bank 2 Sensor 2)
P0160 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 2)
P0161 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 2)
P0162 02 Sensor Circuit Malfunction (Bank 2 Sensor 3)
P0163 02 Sensor Circuit Low Voltage (Bank 2 Sensor 3)
P0164 02 Sensor Circuit High Voltage (Bank 2 Sensor 3)
P0165 02 Sensor Circuit Slow Response (Bank 2 Sensor 3)
P0166 02 Sensor Circuit No Activity Detected (Bank 2 Sensor 3)
P0167 02 Sensor Heater Circuit Malfunction (Bank 2 Sensor 3)
Note: "Bank 1" is the side of the engine with cylinder 1. "Bank 2" is the other side.
Jul 03, 2011 | 2004 Saturn VUE
11/29/2008 02:19:49 **Smurf** 169.254.255.255->> 169.254.79.64,
The smurf attack, named after its exploit program, is a denial-of-service attack which uses spoofed broadcast ping messages to flood a target system.
en.wikipedia.org/wiki/Smurf_attack
Hope this helps...
May 03, 2011 | SMC Barricade SMC7404WBRA (SMC7404WBRA EU)...
What do the codes 1128, 1129, 1133, and 1134 mean on my Porsche Boxter 2001?
code P1128 02 sensor bank 1 lean
code P1129 02 sensor bank 1 lean to limit
code P1133 02 sensor bank 2 lean
code P1134 02 sensor bank 2 lean to limit
fuel system is lean.
Jan 29, 2011 | 2001 Porsche Boxster
I have 2004 GMC ENVOY XL the engine light stay on. i do a diagnostic on it the code i get is P1133 HO25/025 INSUFFICIENT SWITCHING SENSOR 1 OR BANK 1 SENSOR 1. also code PO133 02 CIRCUIT SLOW RESPONSE(BANK...
P1133 is a slow 02 sensor or a shorted to ground at the PCM to 02 sensor signal. If the 02 sensor does not cycle fast enought it is called a lazy 02 sensor, the only way to test for this is with a digital volt meter or a scanner. if it will not pulse fast enough it will throw the code so Replace the 02 senor on the driver side bank. Bank one. then clear the codes. The code is thrown do to seveal reasons the 02 sensor could be dirty or it just could be worn out, you could pull it and clean it and try it again or just replace it and be done with it. The cost of a heated 02 sensor is $50.00 at a auto parts store or the dealer might charge a little higher but the cost in savings of fuel is well worth it.
Jun 30, 2009 | 1998 Saturn SC
I forgot my security code of nokia 1650
how to breck security code of nokia 1650
Jun 23, 2009 | Nokia 1600 Cellular Phone
Washing Machines Logo
32 people viewed this question
Dan Webster
Dan Webster
Sal De
