Question about Whirlpool Dishwashers
Who i can reset whirlpool dishwasher du1055xtvq1
Reset
5 Suggested Answers
  • 171 Answers
SOURCE: Whirlpool Dishwasher model gu980scgq3
Hi vicyoung0921,
I'm Harvey the Master Plumber.
Your question is: Will not start, seems to have no power at all. You checked the breaker and it's fine. Is there a reset button somewhere on this dishwasher ?
No reset, if breaker is good then check the connection at the d/w. It's under the d/w behind the kick plate on right or center under a cover box. 9 times out of 10 you'll find a loose, broken or burnt connection there. That done, it's time to call in warranty repair. If beyond warranty you might consider utilizing the Repair Directory to find a repairman. If the d/w has a few years on it perhaps it is time to compare the cost of repair verses replacement.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Posted on Sep 14, 2008
SOURCE: whirlpool dishwasher reset code
Yup, found it on another site..I had the same issue today.
Reset code: Push 1. Heat Dry 2. Normal 3. Heat Dry 4. Normal
wait about 2 minutes as the controller resets itself. You should see all the leds flash on and then wash and rinse leds stay on for about 30 seconds. A minute or so later ..presto, my machine worked again.
My machine is not the GU3200XTP, but in the same Whirlpool tall tub series (same manual) so leds may not have the same name.
Mark
Posted on Oct 21, 2008
SOURCE: how to reset whirlpool dishwasher adp4501/5
whirlpool dishwasher problem adp 4501 - I had a problem with this machine not starting properly, hunting, with the start light flashing apparently continuously the pump also going on and off in time with the flashing.
After looking around a number of forums I cleaned out the sump gently with a sponge which did not help, then followed this up by pouring a kettle of boiling water into it. This had no immediate effect, but after a few hours the machine started and ran properly again.
Cost no money and saved me the hassle of taking it out and stripping it down - well worth a try.
Posted on Sep 19, 2009
  • 884 Answers
SOURCE: how do i reset my whirlpool adg 7460 dishwasher ? programme seems stuck on end cycle?
Unplug it, move timer to start and plug back in. If it still seems stuck at the end it is almost certainly the timer. If it starts as normal, suspect the drain pump or pressure switch
Posted on Apr 22, 2012
How to reset wirlpool quiet dishwasher
To reset it, you will have to have the door open. It can not be latched. Press "Heated Dry," "Normal," "Heated Dry," "Normal" within three seconds of the first pressed button. Now close the door, this should reset your dishwasher.17 Dec 2012
SOLVED: Dishwasher whirlpool quiet partner I push start button - iFixit
https://www.ifixit.com/.../Dishwasher+whirlpool+quiet+partner+I+push+start+button+not...
or try this link.
How to reset wirlpool quiet dishwasher Google Search
Oct 28, 2017 | Dishwashers
HOW TO RESET MY DISHWASHER
All you can do is turn the power off at the power point, leave it for a few minutes and then switch the power back on.
Jan 11, 2016 | Dishwashers
Quiet partner whirlpool III gold reset
TRY A RESET CODE
Press the "Sani Rinse," "Heated Dry," "Sani Rinse" and "Heated Dry" buttons on the dishwasher's electronic control panel in quick succession to put the appliance in diagnostic mode.
Close the dishwasher door and engage the door latch.
Wait 10 seconds before pressing the "Cancel" button to reset the dishwasher.
Dec 18, 2013 | Whirlpool Gold Dishwasher with Quiet...
CODES FOR A WHIRLPOOL DISHWASHER DU1145XTPB7
Try pressing "Heated Dry" followed by "Normal Wash" followed by "Heated Dry" followed by "Normal Wash" and then "Cancel"
Read more: How to Reset a Dishwasher ' eHow.com http://www.ehow.com/how_8341155_reset-dishwasher.html#ixzz24HGPvrBG
Aug 21, 2012 | Whirlpool Dishwashers
Whirlpool dishwasher model# DU915PWSS0 S/N# DE3960705 reset procedure? The problem: dishwasher will not start the only buttons that will light up when I push them are heavy, rinse only, and heated dry. I...
  • Turn off the dishwasher and unplug it from the power supply. Wait 10 minutes and restore power.
  • 3
    Select a "Hi Temp" wash cycle, followed by a heated dry setting on the dishwasher.
  • 4
    Repeat step 3. This will reset the dishwasher.
  • May 11, 2011 | Whirlpool Dishwashers
    I have a Whirlpool Dishwasher Model #GU240CXTPB1. The normal light won't stop blinking. Tried turning the breaker to reset, but still blinks. No other button works.
    Whirlpool dishwasher reset sequence is usually to hit the heat dry then normal then heat dry then normal buttons within 5 seconds and it usually resets.
    Mar 22, 2010 | Whirlpool GU2400XTP Built-in Dishwasher
    How do i reset my dishwasher adp4504 . i have kept my finger on the start button but just keeps on flashing
    Hi!
    Try pressing sani rinse and heated dry back and forth. All the lights will light and it will reset itself.
    Please see this link for more information---
    Please rate the solution if found useful.
    Thanks
    Rylee
    Feb 24, 2009 | Whirlpool 18 in. ADP530 Free-standing...
    Whirlpool dishwasher reset code
    Mark
    Oct 19, 2008 | Whirlpool 24 in. GU3200XTP Built-in...
    Model # DU1055XTPQ3 WHIRPOOL DISHWASHER RESET CODE
    chris72 had the solution to my Whirlpool DU1055XTPQ3 not turning on. Per Chris's suggestion, I pressed back and forth between sani rinse and heated dry. All the lights came on as it reset and it was good to go. The dishwasher started up immediately. Saved me a service call, THANK YOU Chris!!
    Aug 07, 2008 | Whirlpool 24 in. DU920PW Built-In...
    Dishwashers Logo
    60 people viewed this question
    Top Whirlpool Dishwashers Experts
    Mike
    Owen Barnes
    Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
