Question about Brute Garden
650 Brute Pressure washer, wayer comes out of nossle for about 3 seconds with the correct pressure, then stops, after a few times wayer is warm from wand
I have a 650 Brute pressure washer. Engine runs fine, water supply to washer is correct, when I start up the wand (sprayer) it is at full strength for about 3 seconds then goes to a small stream. After a number of tries the water gets very warm. When I first started to use it today the black release value on the bottom was releasing warm water, now it doesn't seem to be releasing anything. I went to home depot and bought a new wand, nozzle, and the necessary fittings, thinking it was a clogged wand and nozzle. The hand trigger doesn't seem to to have any real movement to it. Very weak. I have trouble shot everything that I have read in different post except taking apart the pump. I would like to know more anout the Auto cool down system and the other other brass value on the other side of the pump. I tightened that up, I'm wondering if I could have an air lock. I did make a foolish mistake, the machine stayed out all winter covered, I have always brought it inside prior winters. It is only used a couple times each year. I also have not used the new spray gun I bought, If the gun isn't the problem then it can be returned I will break down the other and check for clogs. Any thoughts on what my problem could be. Did I freeze the values and the insides since it probably had water in it. What should I try next ? Not getting my Mother's Day work done.
  • Brute Master
  • 4,498 Answers
It is true the pump could have been damaged but equally the unloader valve might be stuck wide open. When the lance trigger is released and the high pressure flow stops one of two things would happen without the unloader valve - either the pressure would rise until something broke or burst or the motor would stall so to prevent this an unloader valve is fitted that opens at a preset pressure that is higher than the working pressure but lower than needed for something to break.
When the valve opens to prevent the pressure building to unsafe levels the "surplus" water is generally dumped into the pump intake so the same water is circulated to some extent and it is likely to become warm under those conditions.
An air leak into the pump intake will almost completely rob the output of both pressure and volume. There is often a facility provided where detergent can be added to the intake controlled by a simple valve which if left open with an empty detergent container will be an effective intake air leak.
In the old days all the pumps were made of bronze or bronze and cast iron but these days pumps and components are made of a variety of materials and now unless pressure washers are in continuous use corrosion can be a big problem.
I suggest you run the pump with the hose disconnected to ensure a good volume of water is being moved and if not work backwards...
Posted on Mar 02, 2017
  • Brute Master
  • 20,289 Answers
Leaving it outside may have broken something inside as water freezes, it expands a lot. The wand is unlikely to be the problem. Your problem is indicative of a water supply problem. Some hose fittings has a non-return valve in the middle, and I have seen these foul the fitting on the power washer and cut off the flow. The pump is a simple centrifugal pump that spins very fast. This is why the water is getting warm because of friction. In normal circumstances, the water running through it cools all the parts.
2 Suggested Answers
SOURCE: Ex-Cell VR2500 Builds Pressure but Won't Spray
I have a similar problem and diagnosed it to be a problem with the gun. I spoke to a technician that services this pressure washer and he walked me through all the diagnostic steps. The pump is working because there is pressure being built up and the gun sort of works because you can get water out before the washer is started. The technician said that the mechanism inside the gun is either clogged or broken. I am going to Home Depot or Lowes to purchase a new gun and will try it tonight. Guns are only about $30-40. He said generic is fine as long as the thread matches and PSI is in range. Good luck!
Posted on Aug 14, 2009
On my brute 2500 psi pressure washer when I let go of the trigger it kills the motor. I changed the unloader valve and still does it . Any suggestions? Thanks
Excessive pressure can stall out a motor. Try reducing by adjusting unloader valve. Clockwise turn will increase pressure, counter clockwise turn will reduce.
Oct 30, 2016 | Garden
Brute pressure washer not building up water pressure
I'd love to help but need the model #.
look on the base frame for the model # sticker.
Brute Pressure Washer replacement parts repair kits and upgrade...
look in the link for your model # to find the owners manual and replacement parts
May 03, 2014 | Honda Black Max 3000 Psi Pressure Washer
1650 husky pressure washer starts and then stops
If you are not squeezing the handle to let the water out, it will shut off.
Nov 30, 2013 | Garden
Pressure washer brute
I had one to the same thing and the pump went out on the waser and you can buy a new pressure washer cheaper than the pum itself
Sep 21, 2013 | Garden
Karcher 300 runs great but no water coming through
hose is stopped up you have to plug the ends up when not in use mud dobbers and other bugs like to get inside had same problem before
Feb 03, 2012 | Karcher G3025OH Pressure Washer
I have a Clarke King 100 hot wash with a wiring problem please can you help with the 3 connections from the pressure switch ?
the pressure switch is so the burner goes off when you stop squeezing the gun, there are only 3 different combinations wire1 and wire 2, wire 1 and wire 3, wire 2 and wire 3, it does not matter which way you connect them. You will know when it is correct as the burner will only work when the gun is squeezed and water is coming out of the lance nozzle at high pressure.
Jul 26, 2011 | Simpson King Brute 3030 Hot Pressure...
I have a union power pressure washer it runs for 10 minutes and then cuts off and wont work again, it still needs the choke on when the engine is warm and only runs for a few seconds
"it still needs the choke on when the engine is warm and only runs for a few seconds"
This sounds like a fuel problem such as the carb needs cleaning
Jun 16, 2009 | Garden
Briggs & Stratton 2500 Power Washer Loses Pressure Time to Time
If by "a few minutes" you mean 180 seconds, I really don't know what to say. But if you mean 5-10 seconds, you probably are experiencing air in the water line or normal engine warm-up behavior when the choke has been set to full lean too soon.
May 23, 2009 | Briggs & Stratton 020324 3700 PSI Pro...
Garden Logo
4,027 people viewed this question
Top Brute Garden Experts
Vernon Taylor
Jesse Walters
Jesse Walters
Andrew Taylor
Andrew Taylor
Are you a Brute Garden Expert? Answer questions, earn points and help others
